Trivia: Return Trips most different to Outward Trip.
GrimsbyPacer
13 Oct 2014
Grimsby
Hi everyone.
I'm asking for journeys where the return part of the journey takes a much longer/shorter time or a very different route/service or any other large variation. In short which return trip is most different to the original trip?
For the purposes of this thread:
1, only permitted routes are allowed.
2, the comparrison is between a train arriving at the end destination before 9am and a train leaving the same destination after 5pm, both on the same day.
3, the entire route is in the UK.
4, It's a current 2015 timetable service.
5, It's all 'heavy rail' no low floor trams/ferry/buses etc.
Like I said above any large variations in any way are allowed.
D6975
26 Nov 2009
Bristol
So, you're looking for journeys where there are two possible and valid routes.
Bristol Parkway - Ledbury springs to mind.
Valid via Worcester or Newport, making it a circular trip if you want, only covering the same bit of track as you arrive back at Parkway. (and the short distance between the Usk and Newport)
Dundee to London via Edinbugh/York v Preston/Glasgow. It's a ~450 mile journey with about 1/4 of a mile in common.
Missed the arriving by 9am requirement. Make it Edinburgh to London via Sleeper and ECML - 400 miles and no track in common.
GlosRail
18 May 2012
Ashchurch to London Stations. A valid £56 off peak ticket is:
9.56 Ashchurch
10.24 Worcester
11.30 Birmingham New Street to London Euston.
Return Either London Paddington to Gloucester via Stroud, or via Bristol Parkway, or maybe even via Oxford.
The only bit of track the same would be at Ashchurch station as you could have gone around in a big circle.
Although you can't get there before 9am.
Philip C
21 Feb 2013
Can no moderator shift this and similar "Trivia" items to the "Quizzes and Games" area which seems designed for them?
FQ
Quizmaster
4 Oct 2013
I wouldn't really call it a quiz or a game so not really...
GrimsbyPacer
13 Oct 2014
Grimsby
Does it have to be the exact same station at each end?
The destination on the ticket has to be the same, ie Gainsborough All Stations etc.
It's not just the routing I was looking for, price variation on the ticket back/type of train needed for the trip/ anything else etc.
Yesterday I went to Nottingham via Lincoln, and I needed to come back via Sheffield as the Lincoln trains stopped running earlier.
I noticed the price varied, the trains were 153/156 & 158/185 on the trip hence more comfort later, the conductor was alot less active on the return part. And other contrasts so I throught I ask if they are more varied return trips needed.
185143
3 Mar 2013
Penrith to Durham/Thornaby/Middleborough/Darlington. Fare set by Northern, however is also valid via Manchester, making the £6 weekend first upgrade exceptional value! Also allows a circular trip out via the Tyne Valley and back via Manchester or vice versa
Kite159
27 Jan 2014
West of Andover
Grateley - Bedwyn
Outward via Basingstoke & Reading
Return via Westbury/Trowbridge & Salisbury
Although the return is only valid in the evenings when HSTs call at both Bedwyn & Westbury/Trowbridge
Messages to moderators regarding a particular post/thread should be made by using the report button, but to answer your question, it appears to be not quite a quiz or game, though I agree it is similar. I've moved it to trip planning as that appears to be the best fit.
