Trivia: Quantity of TOCs between two stations
nicolaboo
19 Jun 2018
Locally, I can go from Manchester Piccadilly to Stockport with…
Northern
Transport for Wales
TransPennine Express
Virgin
Cross Country
East Midlands Railways
Any other two stations beat that?
(Sorry if already done, I couldn't find one)
Mex I can
6 Aug 2019
I was thinking about this recently and I guessed there must be a couple of stations near London that would take it.
Personally, I’ve got Northern, TP Express and Cross Country running between Swinton and Mexborough, passing where I work. DB Cargo and GBRF also pass between the two.
I’m way off track for TFW and East Midlands and I’ve never seen a Virgin in Swinton or Mexborough.
johnnychips
19 Nov 2011
There is the odd EM train that runs from Doncaster to Sheffield, one very early and the other from Scarborough or York. So that makes four operators between Doncaster and Sheffield. I think the OP may be hard to beat.
Kite159
27 Jan 2014
West of Andover
Although a slight twist on that question as it's TOCs between stations, somewhere like Crewe might have 7 operators but the overlap is small
Liverpool Lime Street to Liverpool South Parkway gets five operators which call at both
East Midland Railways
London NorthWestern
Northern
Merseyrail (assuming you count the low level platforms as part of the same station)
Transport for Wales
24 Sep 2017
Haymarket to Edinburgh has 5:
Scotrail
CrossCountry
Transpennine Express
LNER
Virgin
If the sleeper stopped there it would match the OP with 6 (I’m assuming we’re not counting ones that run non stop through one of the stations?)
VT 390
7 Dec 2018
Scotrail
CrossCountry
LNER
Virgin
Don't the TPE services stop to pick up/set down only st Haymarket though so you can only use 4 operators between those 2 stations.
IrishDave
30 Jun 2009
Brighton
London NorthWestern
Northern
Transport for Wales
The Merseyrail trains at Liverpool South Parkway don't serve Liverpool Lime Street - they serve Liverpool Central and Moorfields.
naverag
10 Dec 2018
Another with 4 is Selby-Brough-Hull, which is served by Hull Trains, TPE, Northern and occasional LNER services.
gnolife
4 Nov 2010
Johnstone
Motherwell - Glasgow Central has 5 that you can actually use for the journey, plus the sleeper whichyou can't board at Motherwell heading North
Virgin Trains
LNER
CrossCountry
TPE
Scotrail
pne508
17 Oct 2018
If you treat the two WM trains brands as different operating companies, then the Wolverhampton, Birmingham New Street, Birmingham International corridor also has 5. Also TfW, West Coast and Cross Country.
Mag_seven
1 Sep 2014
here to eternity
Oddly enough London has not featured at all (so far) in this thread - does that imply that multi TOC operation between two stations is mainly a north of England / Scotland thing?
Ianno87
3 May 2015
I guess all the main radial lines out of London are specified, at most, generally as two TOCs per terminal (local and long distance).
Liverpool Street-Stratford has Greater Anglia, TfL Rail and c2c. (Plus Southeastern, albeit St Pancras-Stratford International).
London-Stevanage has Thameslink/Great Northern, LNER and Hull Trains (couple of Sunday trains).
VT 390
7 Dec 2018
I would say this is mostly correct as in London TOC's generally operate within there own areas.
Although if you count the Underground there some good London examples such as 4 operators between Harrow & Wealdstone and Wembley Central: Underground, Overground, London Northwestern Railway & Southern.
Kite159
27 Jan 2014
West of Andover
Southampton Central to Southampton Airport (Parkway) with 4
SWR
XC
GWR (1 service each day)
Southern (a couple services)
