Trivia: Platforms you never see certain trains depart from
bigfoote
5 Jan 2013
I'm surprised no one's mentioned P2 at Portsmouth Harbour (yes, I have inserted my tongue firmly into my cheek)
BestWestern
6 Feb 2011
Any passenger trains at Worthing platform 1.
FGW used to terminate late running Brightons in there from time to time, once it was established that a long running Appendix instruction banning Class 158s was nonsense!
BestWestern
6 Feb 2011
Talking about platforms, how much effort, time and money would it take to bring Platform 5 at Southampton back into full working passenger use? I’m aware it’s usually only used to stable stock, and the fact it’s only got a GPL, rather than an actual signal with relevant OFF indicator etc.
It's probably more a question of what would use it, does anything much terminate coming from the west? The same question and answer probably applies to Platform 2 at Bristol Temple Meads.
There are a few a day terminate from the west - mainly GW short workings (other than the normal hourly Portsmouth Cardiffs), and a couple of SWR, but they'll probably cause less conflicts leaving them on the P2/P3 island, rather than crossing them over to the down fast on arrival.
P5 would have been useful space when GW were terminating their whole service from the west a year ago, when they were shunting into P5 to lay-over between arrival and departure, but that sort of blockade (Fareham wasn't it?) doesn't come round that often.
I expect the signalling changes (and PIS additions) that have been talked about for years come at quite a hugely inflated cost.
Never seen any Thameslink or Swr service departing fro m Wimbledon platforms 1,2,3,4 and 10a and b... strange.....................
I think SWT have used P4 in fairly recent memory, during some sort of blockade that involved running via East Putney.
sd0733
7 Nov 2012
Plat 2 at MIlton Keynes I've only ever seen used for terminating services I've never seen working use it
61653 HTAFC
18 Dec 2012
There is no access into Platform 1 for passenger trains, so unlikely to see any additional use. Not sure any changes to that are planned either.
Whenever something like that comes up, I can't help but wonder why, and on what basis. Presumably at some point in the past it was decided that that platform wasn't needed so maintenance didn't need doing. The infrastructure then falls out of use and it costs an awful lot to bring it back if needed. :roll:
Kite159
27 Jan 2014
West of Andover
Didn't it get used by the Southern services when they were operated by single 377/2s?
[although I was thinking about the South Bay platform rather than the main platform)
Ianno87
3 May 2015
Not sure if there still is, but a few years ago there used to be one train in the evening that arrived from Euston in Platform 2, terminated, and then continued through ECS to Northampton.
I have also been 'through' Platform 2 in both directions to/from the north during various disruptions. Still very rare, however to do so (MKC does have a very flexible layout*!).
*Best one was watching a pair of Class 325s pass Platform 3 in the *Up* direction at 75mph (crossing Up Slow to Up Fast through the station). Caught a few folks on the platform by surprise!
30907
In this case there is no physical route from the Up side into the Down Bay, and a quick Google suggests there never has been. The present layout is simplified steam-era rather than fully remodelled.
Terminating trains would have run into P4 and be shunted across to P1 To depart so as to maintain cross-platform connections. (Off the top of my head, Crowhurst and Wareham on the SR were worked that way.)
Crossover
4 Jun 2009
Platform 6 at Wolverhampton. Never seen it used except one ECS.
From memory, I am sure there is a signalling limitation on that platform - movements one or another are not signalled for passenger use
EDIT: I think it is "inbound" - there is a service out in the morning, but in the evening, the service terminates into another platform from Shrewsbury before running ECS from that platform into the bay, stabling overnight to run the morning service
sw1ller
4 Jan 2013
You won't see a 158 in the parcels bay at chester. And if you do, someone's messed up!!
Nean
28 Dec 2013
Sheffield
I've yet to see a Merseyrail service in P2 at Hunts' Cross. It's signalled and has a juice rail to act as an alternative to P3 but I've yet to see a 507/8 in there!
SpacePhoenix
18 Mar 2014
Juice rail rusted up at all there?
Skipness
18 Dec 2015
North Yorkshire
I have only seen Derby platform 5 used once when a failing train from the Matlock branch pulled into the usual platform 6 to transfer its onward passengers into a waiting unit in 5
gazr
24 Mar 2014
A few booked services from what I can see. Definitely looks like being used on SUN 15/22 as engineering block north of Derby.
Crossover
4 Jun 2009
I think it is booked once a day - whether it actually happens, I'm not sure.
In reality, terminating Merseyrail into p2 at Hunt Cross doesn't make much sense, as it still has to cross back onto the Up/Down Electric - I suspect it is there more for flexibility in case something jams up p3 for any reason
XCTurbostar
13 Sep 2014
I use Birmingham New Street a lot.
I have never seen platform 13. where is it located, I can't picture it at all.
Its not really a platform but more just a loco stabling (or used to be) during the New Street platform works some of the speakers and cameras reference 'Platform 13' although the platform itself is only big enough for 2 coaches.
The platform is on the south eastern side of the station at the derby end of platform 12.
Thanks,
Ross
61653 HTAFC
18 Dec 2012
Thanks,
Ross
Speaking of little-used 2-coach platforms, earlier this evening I arrived on a service into Huddersfield platform 5 for the first time in years (I've departed from there more recently). RTT had the service down as routed into Platform 1 until the last moment which I thought odd, but I figured this might be an effect of the "Lime Street control" which prevents anything too long being routed into P5 (40m) or P6 (circa. 70m) and how RTT deals with the data feeds it gets. Was I right, anyone?
Kite159
27 Jan 2014
West of Andover
RTT sometimes gets confused,
For example this service departed from platform 2, not platform 1:
http://www.realtimetrains.co.uk/train/Y62394/2017/09/30/advanced
61653 HTAFC
18 Dec 2012
I know it does- but this was the first time I've checked for the allocated platform on an arrival at Huddersfield that I was actually on. My reasoning was that the service was a 142 (ex-Wakefield) so could arrive at any of 4, 5 or 6 (Or technically 1, but unlikely) and as I was near the centre of the unit I wanted to know which side of the unit to stand on. Had it been anything longer than a 150 I'd have known to stand on the right (in the direction of travel) to get a quick exit to run for my bus! I checked RTT as we left Deighton and was surprised to see platform 1 indicated, in red (which I took to mean a late alteration to the "usual" platform) and was refreshing every few seconds to see if it changed.
RTT updated to indicating platform 5 just as we passed over the "Unna Way" on the viaduct, i.e. just before the points leading to 4/5/6. Upon seeing when this was, I was reminded of the mechanism which prevents long trains in the short bays:- the "Lime Street control" as I understand it is termed.
BurtonM
3 Feb 2014
Manchester
Never seen a TPE service in P5 at Stalybridge (is it even possible?), in a similar vein P2 isn't used for much except terminating the Denton Flyer, and reversing ECS moves coming from Newton Heath TMD to head towards Piccadilly. I have however boarded a starting TPE service in P2.
(similarly, TPE in the Manchester Victoria bays).
ATW services in P1-4 of Manchester Piccadilly.
GatEx in the not-GatEx platforms at London Victoria (especially SE side)?
Peter Mugridge
8 Apr 2010
Oakham
I have seen that happen during engineering work albeit that was about 15 - 20 years ago - I actually traveled on one from platform 7 once. Pretty sure they used 8 as well at the same time.
Welshman
11 Mar 2010
OK - I'll ask - what's the "Unna Way"?
At least if your train had arrived on platform 1, you wouldn't have had as far to run for your bus.:D
