Surely Liverpool Moorfields to Liverpool Central has more?14tph (16tph peak) Liverpool Central - James St - is this considered like the tube (as it's underground)?
A few for the longer distances - not checked all but these seem to work:
200miles
Preston - Euston 66 a day (beats Newcastle due to sleepers!)
300miles
Edinburgh - Kings Cross 48 a day (To Bhm is 42, though only via Newcastle trains are over 300 miles, and Glasgow - Euston is 45)
400miles
Edinburgh - Bristol 23 a day
500miles
Edinburgh - Plymouth/Totnes/Newton Abbott 20 a day (XC here trounces any other route - Aberdeen to Kings Cross is best I could fine at 6 a day)
600miles
Edinburgh - Redruth/Cambourne/Penzance 5 a day
700miles
Aberdeen/Stonehaven - Bodmin Parkway and beyond, 1 train per day![]()
huh? not sure how you've got to these figures??
Edinburgh to Kings cross is about 20
Edinburgh to bristol is more like 12
preston to Euston 66?? there are 2 Virgin services an hour max!
Clapham Junction to Waterloo has 37 trains departing 0700-0759, so technically beats off-peak then. This drops to 33 in the 0800-0859 slot though, which is the same as Stratford to Liverpool Street. This should be slightly higher once full Crossrail operation starts, but that is subject to speculationOverall, definitely Waterloo to Clapham Junction 36tph off-peak (which I believe is more frequent than the peak, fewer fast trains stop in the peak).
For tube+NR combinations, from Finsbury Park to Kings Cross in the 0700-0759 slot there are 10 (Great Northern) + 24 (Piccadilly) + 35 (Victoria) = 69tph. I appreciate this doesn't quite match Kings Cross to Euston (Square), but I would argue Euston Square is a different station, whereas Kings Cross St Pancras is one big complex.Including the tube, it's probably King's Cross St Pancras - Euston (incl Euston Square), which is 34 tph Victoria, 18 tph Northern, 12 Met, 6 Circle, 6 H&C, which adds up to 76 tph.
No, Piccadilly-Stockport beats that (14tph off-peak, as I make it...):
-3tph VT to Euston
-2tph XC via Birmingham
-1tph Stoke stopper (2tph in the peak)
-2tph Hazel Grove/Buxton
-2tph Hope Valley fast (Cleethorpes/Norwich)
-1tph Mid-Cheshire
-2tph Alderley Edge/Crew
-1tph South Wales
Adding tube+NR combinations, from Finsbury Park to Kings Cross in the 0700-0759 slot there are 10 (Great Northern) + 24 (Piccadilly) + 35 (Victoria) = 69tph. I appreciate this doesn't quite match Kings Cross to Euston (Square), but I would argue Euston Square is a different station, whereas Kings Cross St Pancras is one big complex.
200miles
What about Euston - Watford Junction
3TPH LO
Lots of LM services stop there ( at least 6TPH )
1TPH VT
You've omitted the Central Line from your Stratford - Liverpool St total, I think
Ah that was intentional, as the OP mentioned they were interested in NR rather than tube, so thought I'd address that first, though I take your point that it would be one of the highest frequencies with the Central line as well. Have edited for clarity.
