Trivia: Most connected TOC
pokemonsuper9
20 Dec 2022
Greater Manchester
Does anyone know what the TOC that connects to the most other TOCs is?
I'd think it might be EMR connecting to 12
Northern, TPE, Avanti, WMT, Crosscountry, LNER, Grand Central, Hull Trains, Greater Anglia, Thameslink, Southeastern and Eurostar
But maybe there's something I'm not thinking of or that seems less obvious, or have I gotten something wrong with my count?
If anyone knows of any other threads that've already explained this please send a link as I couldn't find any
Edit for clarity:
TOC = train operating company that holds a passenger license to operate trains and is a party to the Ticketing Settlement Agreement (TSA)
Mat17
17 Aug 2019
Barnsley
Cross country must be a contender, it travels the length and breadth of the country.
Horizon22
Jobs & Careers
8 Sep 2019
Surely it's Crosscountry?
Everyone but Southeastern & C2C*?
Peterthegreat
22 Feb 2021
South Yorkshire
Cross country connects with Scotrail, LNER, Avanti, Caledonian Sleeper, Northern, EMR, TfW, Greater Anglia, GWR, SWR, GTR (Southern / Thameslink brands), MTR Elizabeth Line, Hull Trains, Grand Central, West Midlands Trains
CAF397
15 Sep 2010
Lancashire
XC wins, as others have said, but EMR also connects with TfW (Crewe and Manchester/Stockport)
pokemonsuper9
20 Dec 2022
Greater Manchester
EMR - 15
Northern, TPE, Avanti, Merseyrail, WMT, Crosscountry, LNER, Grand Central, Hull Trains, Greater Anglia, Thameslink, Southeastern, TfW and Eurostar, Caledonian Sleeper
London Underground - 19
Avanti, WMT, EMR, Thameslink, Eurostar, LNER, Southeastern, Hull Trains, Grand Central, Greater Anglia, C2C, Southwestern, Heathrow Express, GWR, Chiltern, Overground, Elizabeth Line, Lumo, Caledonian Sleeper
Crosscountry - 19
Scotrail, LNER, Avanti, Caledonian Sleeper, Northern, EMR, TfW, Greater Anglia, Thameslink, GWR, SWR, Southern, Elizabeth line, Hull Trains, Grand Central, WMT, Chiltern, Lumo, TPE
OrangeJuice
4 Jun 2018
EMR - 14
London Underground - 17
Crosscountry - 18
EMR also have Caledonian sleeper at Crewe.
Cross-country also have TPE at many places.
JamieL
6 Aug 2022
EMR - 15
Crosscountry - 19
London Underground connects with Caledonian Sleeper at Euston. It also connects with the dreadful Lumo if that counts as a TOC.
plugwash
29 May 2015
Asside from the fact that I'm pretty sure London Underground are not a TOC (they accept some rail tickets, but only under specific arrangements, not in the way a regular TOC does), this raises the question of what exactly a "connection" means? If you are going to count underground and NR stations that are joined together as "connections" should you also consider Kings Cross and St Pancras mainline stations as "connections"?
pokemonsuper9
20 Dec 2022
Greater Manchester
Edit made, thanks for the suggestion.
I was just wondering how they compared to Crosscountry.
For the tube I do count them, which yes is a bit off from how I treat St Pancras and Kings Cross, but more in line with how I treat Liverpool Lime St high/low level.
The Underground would be at 7: Greater Anglia, c2c, Elizabeth Line, Overground, Southern, WMT (Through LNW) and GWR if that kind of connection was dis-allowed. Either way allowing Kings Cross - St Pancras probably doesn't change the answer as crosscountry see all but 3.
Mike99
4 Mar 2011
G E M L
Is Southern being included with Thameslink for London Underground? There's the obvious connection at London Victoria
London Trains
9 Oct 2017
London Underground:
GTR (all 4 of its brands), Southeastern, SWR, GWR, Heathrow Express, Chiltern, Avanti, WMR (only LNWR), Caledonian Sleeper, EMR, Eurostar, LNER, Hull Trains, Grand Central, Lumo, Greater Anglia, C2C, London Overground, Elizabeth Line.
So that's 19 (or 22 if counting Southern, Thameslink, Great Northern and Gatwick Express separately)
It doesn't connect to Northern, TPE, Merseyrail, Crosscountry (since the Elizabeth Line isn't part of LU), TfW or Scotrail.
pokemonsuper9
20 Dec 2022
Greater Manchester
EMR - 15
Crosscountry - 19
London Underground:
The underground was counted in my main count, which has been buried a bit by this point
miklcct
2 May 2021
Cricklewood
London Underground is a TOC at least for the part on Network Rail metal, if Eurostar is also counted as a TOC. Using the same reasoning Tyne & Wear Metro and Sheffield Supertram should also be counted as TOCs as well. The criteria inferred is "scheduled passenger service in the Network Rail timetable".
Eurostar doesn't accept any normal rail tickets at all, it's a separate system. If you have to count Eurostar as a TOC, the above is the only reasoning available.
scrapy
15 Dec 2008
The OP specifies trains, so it's debatable whether tram-trains meet that criteria to allow Sheffield Supertram to count. If they do count is also open to debate as to which stations count for interchange as the train/tram meets just Northern at Rotherham Central, whereas the trams also meet TPE at Meadowhall, and TPE, XC and EMR at Sheffield Station (although some may consider them to be seperate stations). Only the OP can answer this.
