Trivia: maximum number of consecutive 4-aspect signals viewable from a location
trevwilliams
22 Feb 2012
Ireland
Having spent an hour at Bletchley (BLY), I was watching the southbound pendolinos fly through and was enjoying seeing the 4-aspect signals changing as the train passed each one. From BLY it's possible to see 4 signals. Can anyone tell me whether there is a stretch of track where it's possible to see more?
jopsuk
13 May 2008
Not sure how many are in sight, but from Ponders end must be a good bet- big long straight there with 4-aspect auto signals, lots of services non-stop
David Dunning
27 Oct 2009
York
When I lived in a house by the R/G light crossing known as Beningbrough 7.1 miles north of York you could just about see 4 sets in each direction from the crossing at night. However because of the curvature of the earth effect and no doubt my eyesight that was about it. Looking north you'd see one double yellow , one single , and two reds if the route wasn't set thru Tollerton. The double yellow proved to be a great help during morning power cuts as it would give just enough light thru the bathroom window :)
tsr
15 Nov 2011
Between the parallel lines
You'll usually see the whole four-aspect sequence very clearly if you stand on Sutton Platform 1 and look towards Cheam. However, there is currently nothing particularly exciting about the signalling of the Sutton area. (Many people would say the same for everything to do with Sutton...)
SpacePhoenix
18 Mar 2014
Don't know if either is 3 aspect or 4 aspect but Waterloo and Clapham Junction might be contenders
There's a long straight from just east of Trent Junction almost to the Nottingham ring road, with 4-aspect signals and relatively low speed so they should be closely spaced. I've never tried it but the footbridge at Attenborough or the road bridge at Beeston might be a good bet.
LowLevel
26 Oct 2013
Next time I'm on the ECML through Stoke etc I'll have a look - you can see a pretty long way in places.
30907
Tonbridge to Ashford must have potential, depending on overbridges etc.
driver_m
8 Nov 2011
If you want to see the full set then the long straight on the down heading towards Weedon on the WCML is your friend. Make sure you're not on a Manchester and the chances are you'll get all 4 aspects. (Sit on the right side to see it)
15 Nov 2008
Southend Stations
Gidea Park on the Down Main. I think you can see 5 or 6 consecutive signals. Definitely can from the cab, imagine you'd have to stand on the Up Electric platform and look down the main.
In a sunny afternoon you can see the tail of the train ahead of the last red too.
Assuming the OP means consecutive signals, ie on the same line applying to the same track in the same direction...
Looking south from Slipe Lane Level crossing (near Broxbourne) you can see down to Brimsdown, there's about 8 or 9 signals in that sequence.
16 Sep 2013
Signal sections are short in the Knottingley area. When driving from Knottingley towards Pontefract Monkhill, you can see four 4-aspect signals on the straight before Monkhill (after your pass under the A1(M). If you are routed down Cutsyke those signals show double yellow, yellow, red, green (the red clears with a number four junction indicator as you approach Monkhill station, the Green is not yours - it is for trains towards Wakefield). So you get to see all main aspects, but not in the correct order!
trevwilliams
22 Feb 2012
Ireland
Thanks for all the replies.
That is indeed what I mean, so 8 or 9 signals in sequence is much more than I expected and, if correct, will take some beating.
That's two votes for that stretch then.
Sounds interesting, I'll look forward to reading about what you find.
Surely London Bridge is a contender?
Beat me to it.
The view down the Deptford line is a double digit signal count. They are very close together.
That was my thought to.
So London Bridge sounds the most promising so far. Can anyone confirm?
