Yes, and Neasden Junction?
Quiet for trains perhaps. Rather noisy because of the neighbours.
That's like Clapham Junction compared with some mentioned here!Wainfleet sees 2 an hour if its lucky.
Now i come to think of it i might have seen a road closed sign there once, and maybe this is what prompted me to think it probably isn't in use anymore, or maybe i'm just imagining things now you've said it. It doesn't surprise me to be fair. It's a job i'd consider when iv'e had enough of my current job but i suspect it WILL be closed by then.hi rob, I was actually offered an interview for a Crossing keeper job there last year. Apparently the previous chap took to sticking up the road closed sign then going to the pub - he got caught and sacked! Its fully manned 24/7 apart from Sunday when they don't start till 14:00.
Blimey! I haven't been there for years. Had to do a Health and Safety visit there a number of years ago. Got a few photos of the small frame. A re-org of the area a number of years ago saw the administration/rostering of the location pass from Doncaster to York.It's not long had some money spent on replacing the (very unusual) groundframe with a switch panel so I assume it isn't due to close imminently.
Think I read somewhere Longannet was only open as required.??Longannet?
Yes can’t be a particularly nice box to work because of that.
Thanks for that. An unusual location in its own right.As I understand it the frame was unpopular with it's operators as you had to push the levers normal to clear the signals which is a particularly unnatural movement. The stop signal on the down needed replacing anyway so it got a horrible new semaphore worked for a short period off the frame and then it all went on a panel, the down distant being motor worked anyway, shortly afterwards. So now it is unusual again for having semaphores worked off a panel![]()
Even in pre-Covid timetables, there weren’t that many trains between Girvan and Stranraer which is still manual signalboxes despite the more remote highland and west highland routes being RETB (Radio Electric Token Block)
Given that a train in the High Level platform can be signalled towards Alrewas (by Trent Valley Junction box) or towards Birmingham (by Aston box) presumably the signaller at Trent Vallley Junction has to be aware of terminating Cross City trains on the track circuit for the northbound signal.
Crag Hall. Still a fair few trains down there, lot of Q / Y paths though.Think I read somewhere Longannet was only open as required.??
Craig Hall, Boulby Branch?
Garsdale must be quiet now. Only 4 each way at the moment, and no freight that I have noticed. There again some days there are the Skipton-Appleby excursions. or is it switched out?
