mjmason1996
- Joined
- 12 Aug 2019
- Messages
- 55
Was just curious about this one. The most obvious one i can think of is Peterborough with 7 platforms and no bays but there must be a better one somewhere?
Cardiff Central and Gatwick Airport equal that (although if you count 3a and 3b as separate platforms then Cardiff beats Peterborough).Was just curious about this one. The most obvious one i can think of is Peterborough with 7 platforms and no bays but there must be a better one somewhere?
Platform 1 is a bay platform there.Clapham Junction?
I thought about clapham junction, but according to Wikipedia it has a bay.Clapham Junction? 17 numbered platforms (though 1 and 2 are the same structure so 16 really).
Yes. There seems to be much less use of P1 than others on the Windsor side, and P5/6 on the main fasts see little normal use, but AFAICT they are all usable.Does Vauxhall have 8, or are some disused?
10 if you count the Underground...Does Vauxhall have 8, or are some disused?
Finsbury Park has 8
New Street has Platform 4C which is a bay.Birmingham New Street?
Depends on how you define "bay". Any track with a buffer stop at the end or one where the platform wraps around the end of the track?Platform 1 is used by terminating London Overground trains form Stratford. It’s a bay platform.
It has 14 (ignoring the U-bahn). Duesseldorf Hbf has 16 with no bays, Hannover and Duisburg 12 - the Prussian military insisted on through stations, and these 3 are clearly rebuilds post-WW2. Koeln Hbf is 11. But Nuremberg beats them all at 21.Does Berlin Hbf have any bay platforms? That’s pretty big over two levels?
I think here "bay" is being used as short for "platform that a train cannot run through to a line or siding beyond"- so eg at Clapham 1 is a bay but 2 isn't, as there's a sidingDepends on how you define "bay". Any track with a buffer stop at the end or one where the platform wraps around the end of the track?
Does Omskirk have two bays?
Platforms 1-4 at New York Penn are bays, the other 17 are through.Wonder if New York Penn is another possibility or how about Madrid Charmatin?
