Trivia: Intensively used two-platform terminals
GordonT
26 May 2018
Moorgate (GN) is an obvious example. Are there other examples on National Rail or LU? Minimum 10 minute frequency for much of a weekday for criteria purposes.
greatkingrat
20 Jan 2011
Stratford (Overground) has more trains than Moorgate, at least off-peak. Neither come anywhere near LU stations like Brixton or Elephant & Castle though.
Mcr Warrior
8 Jan 2009
If we can maybe include the Manchester Metrolink system, trams terminating at Altrincham seem to alternate between platforms 1 and 2, at least during the day. Typically there's a service arriving from the Manchester City Centre direction every six minutes.
Class 466
5 Mar 2010
Atherton, UK
Bury or East Didsbury are almost identical examples (except they only has 2 platforms unlike Altrincham’s 4 overall)
Farigiraf
23 Jul 2023
Bridge on the River Cam
Only 4tph out of Moorgate GN platforms at the moment, so with that as the minimum service level, only counting those that are the end of the line (so no Hainault for example):
Tube:
- Brixton & Walthamstow Central (Victoria)
- Ealing Broadway, West Ruislip, Epping (Central)
- Watford (Metropolitan)
- Elephant & Castle (Bakerloo)
- Battersea Power Station (Northern)
- Heathrow Terminal 5 (Piccadilly)
- Bank & Waterloo (W&C)
DLR, Overground, Elizabeth Line:
- Barking Riverside
- Beckton
- Woolwich Arsenal
- Stratford International
- Lewisham
- Tower Gateway (but only 1 track)
- Bank
- Abbey Wood
- Heathrow Terminal 5 (Elizabeth)
Trams:
- New Addington
- Beckenham Junction
- Wimbledon
- Starr Gate
- North Station (Blackpool)
- Edgbaston Village
- Meadowhall
- Middlewood (two separated platforms on the same side, along the same track)
- Edinburgh Airport
- Newhaven
- Phoenix Park
- Hucknall
- East Didsbury
- Manchester Airport
- Trafford Centre
- Ashton under Lyne
- Bury
- Rochdale Town Centre
- Altrincham
- MediaCityUK
Could spend some more time listing National Rail stations that qualify but that'd ruin the fun of the thread ;)
Edit: I see the OP has specified minimum 6tph, so that means Watford, Starr Gate, Heathrow T5 (Elizabeth) and some of the Metrolink termini no longer qualify.
Horizon22
Jobs & Careers
8 Sep 2019
Abbey Wood?
Up to 12tph in the peak on the Elizabeth line.
Both Waterloo & City Line stations
I’d suggest the Waterloo end doesn't operate as a conventional 2 platform terminus (as in the context of this thread), but it is effectively a through station albeit without passengers. The trains terminate in and reverse from a single siding in the depot.
Taunton
1 Aug 2013
The old Wirral electric terminus at Liverpool Central, until 1977, used to turn round a 2 1/2 minute frequency, 24 tph, peak service at a single island platform. with a shunting neck beyond for reversal, which must be the most intensive ever (I believe the W&C frequency was 3 minutes, 20 tph).
vic-rijrode
31 Aug 2016
St James on the Tyne & Wear Metro is a 2 platform terminus (unfortunately with no possibility of extending westwards anymore). Ostensibly trains arrive and depart every 8 minutes although during the current replacement of the old unit by the new 555s there are gaps in this service.
Kite159
27 Jan 2014
West of Andover
Although Stratford does have the option of the LO services using platforms 11 or 10A. Bit similar to the Lizzy line platforms at Shenfield which have 8tph split across 2 platforms
Mattplans
27 Sep 2024
London, UK
Abbey Wood?
- Abbey Wood
I was about to say they use the siding to alleviate some of this pressure but it's not used as much as I thought it was. Anyone know the purpose of Abbey Wood Crossrail Sdg- looks like a couple trains are dumped here for parts of the day.
- Barking Riverside
- Beckton
- Woolwich Arsenal
- Lewisham
Some of these DLR terminals very weirdly have 1 min turnarounds. It will even sometimes look as if they aren't using one of the platforms.
DanNCL
17 Jul 2017
County Durham
Heathrow Terminal 5 is two platforms shared between Elizabeth Line and Heathrow Express, combined that makes 6 trains per hour.
St James (and Airport for that matter which is a very similar setup) have been 5tph for a long time now so wouldn’t count. However, at some point in the next few years that should increase to 6tph which would make both of those stations count.
A S Leib
9 Sep 2018
Given that Mill Hill East is every 15 minutes off-peak, is Stourbridge Town the only one-platform terminus with a service at least 6 tph?
Horizon22
Jobs & Careers
8 Sep 2019
Just extra resilience and capacity. It also provides a connection to the North Kent line, although outside construction of the line it has seldom been used.
In the peak though at Shenfield, P4 is also used occasionally so not quite the same metric.
Class15
30 Dec 2021
North London or Mildmay line
Moorgate has up to 10tph in the peak though, and I’m not totally sure what ‘large parts of a weekday’ means exactly.
Mcr Warrior
8 Jan 2009
Which hour of the day does Moorgate actually have 10tph terminating there? Much of the day it seems to be only 4tph.
Spekejunction
14 Aug 2014
The old Liverpool Central Low Level turned 24 trains per hour..admittedly with a head shunt ..weekday peak hours..
