Trivia; Busiest single-track station?
Mikey C
11 Feb 2013
Heathrow T4 station on the Underground is on a single track loop, with trains every 10 minutes. Well over 2m people a year use it
The question says "single track".
So Dyce and even Castleford don't count by that definition.
I don't think Moorfields, a station with multiple lines, one of which is a single track, qualifies, but we could do with a little more clarification in the opening post. If Moorfields was to count, you could say Bank, which would be daft.
It appears that the Heathrow T4 stations are separate. If so, then the LU station would count.
PHILIPE
14 Nov 2011
Caerphilly
Re the original post, I've seen two sets of replies here. Did the OP mean busy re population or busy in intensity of train service.
thenorthern
27 May 2013
I know its part of a larger station and I know its one directional but the most passengers and most trains on a single platformed station is most likely to be Liverpool Lime Street low level.
61653 HTAFC
18 Dec 2012
Having worked Ormskirk and Kirkby mentioned earlier they are 2 of the busiest Merseyrail stations, absolutely mental sometimes with queues out the door all day!
Though whether they should be classed as single platform stations is open to interpretation. I'd argue that they have two platforms from an operational point of view. The same would apply to Penrhyn in Cornwall in my opinion.
Strathclyder
12 Jun 2013
Clydebank
If it counts, East Kilbride must be in with a shout, with 1,153,648 passengers passing through in the 2014/15 period (up from 1,079,528 in the 2013/14 period) on a daily 2tph service.
thenorthern
27 May 2013
London Underground wise Heathrow Airport Terminal 4 is the busiest single platformed station but Mill Hill East is the busiest single platformed tube station that has trains that go both ways on the one platform.
At well over a million has anyone mentioned Cardiff Bay yet.
MickH
5 Jun 2017
AFAIK the busiest single track station according to ORR station usage is Chafford Hundred which depending on how busy is defined must be on one of the busiest single track sections which is oddly ignored when it comes to plans for doubling
ChiefPlanner
6 Sep 2011
Herts
In terms of trains , or route capacity utilisation indicator (CUI) , the single line at the top of the Rhondda Valley has to be up there , was about 96% in use in a standard hour for 2 tph each way. (as I recall from previous studies) - Treherbert - Ystrad Rhondda - Porth.
Geeves
6 Jan 2009
Rochdale
I guess Glossop and Hadfield must be up there with the busy single line stations. Glossop I believe is the second busiest station in Derbyshire after Derby station its self. 876 thousand for Glossop down from a 956 thousand a few years ago.
ag51ruk
29 Oct 2014
Chesterfield has about double that number of people (but obviously doesn't count for the original question)
InOban
12 Mar 2017
Looking at Google, it's not just the section to Bearsden, it's also between Hillfoot and Milngavie. But you're right that it's double through and between both stations.
Ianno87
3 May 2015
Newmarket doesn't weigh in too badly - c. 300k entries and exits.
Parallel
9 Dec 2013
The Avocet line (Exmouth branch) must do quite well too - Single track from Exmouth Junction to Exmouth with only one passing loop at Topsham - No extra paths available most of the day M-S and Exmouth itself is close to breaking the million (entries and exits) barrier. (You also have Digby & Sowton which is up there too)
