Triple Headed Services
E_Reeves
25 Oct 2015
West Midlands
Hi,
Just wondering, how common are triple headed freight services?
I've only seen one made up of a 90 + 2 86s.
I guess they are not that common, but I'd love to know.
Thanks! :D
Domh245
6 Apr 2013
nowhere
In a lot of cases like that, at least one or more of the locos would be Dead-in-Tow, so effectively a very heavy wagon. I would guess that triple heading would have to be defined as all 3 locomotives pulling the train.
Harbornite
7 May 2016
Hi,
Thanks! :D
They are uncommon and probably only occur in the event of a failure or to kove a loco to depot and thus saving a path.
The only triple header I recall seeing recently was at Tamwort and also consisted of two 86s and a 90.
E_Reeves
25 Oct 2015
West Midlands
That could've been the one I saw; I saw it at Nuneaton
DarloRich
Fenny Stratford
Hi,
Thanks! :D
depends if they are all under power or being shifted around the country.
apk55
7 Jul 2011
Altrincham
The Worsborough incline on the Woodhead line Wath branch used to have four engines per train. In steam days this was 4 O4 2-8-0 engines, then in electric days 4 EM1 locos.
SpacePhoenix
18 Mar 2014
I've got a feeling that prior to the introduction of the class 59's some aggregate trains were triple headed too.
The Lickey incline would have probably needed freights to be tripple headed at times before 59s and 66s were introduced
JN114
28 Jun 2005
No that's be a waste of motive power, trains would have been double headed and banked over the lickey.
JN114
28 Jun 2005
As I read this, this http://www.realtimetrains.co.uk/train/H36312/2016/08/18/advanced went past my window with 2 Class 66 and 1 Class 70 on the front.
Class 66 and Class 70 aren't compatible in multiple, so unless an additional driver was provided (highly unlikely) the train wasn't triple-headed, the additional loco(s) were Dead-in-Train.
The OP is asking whether trains are triple-headed - that is to say 3 locos leading all of which are contributing to the power output of the train.
Andyjs247
1 Jan 2011
North Oxfordshire
and similarly the Motherwell iron ores were 3x37 for part of their journey.
Yes. Around the early 80s in South Wales the heavy iron ore trains from Port Talbot to Llanwern were booked for 3x37s. Soon after 2x56s became the regular traction IIRC. And in Scotland the flow from Hunterston to Ravenscraig / Motherwell was 3x37s. I don't remember any other cases of booked triple headed traction but happy to be corrected.
These days 3 locos up front is more likely following a failure or for positioning reasons with one or more dead in train. It's very unlikely all 3 will be under power.
Harbornite
7 May 2016
As many as 4 Jinties banking in rear in Steam days.
Aye, sometimes assisted by the ex MR 2-10-0 big bertha which was replaced by a 9F. The jinties were replaced by panniers and eventually the whole lot was replaced by class 37s.
RJ21
24 Apr 2016
I seem to recall a few years back a mention in Modern Railways of a short lived freight service, I think from somewhere in East Anglia to the West Midlands, which was hauled by 3x Class 31, they could have been ex-FM locos.
sprinterguy
4 Mar 2010
Macclesfield
I thought that 3 x "heavyweight" 37s took over from 2 x 56s on the South Wales steel trains due to their superior braking capabilities, rather than the other way around? That's how RAIL magazine reported it at the time.
And I thought that the Ravenscraig steel traffic only typically used pairs of their short-lived class 37/3 fleet - The evidence of multiple forum members seems to state otherwise, though, so I've learnt something new there. :)
PHILIPE
14 Nov 2011
Caerphilly
No. The 3x37s were first while the 56s were still being built.
fowler9
29 Oct 2013
There was a period when quadruple header class 20's passed the bottom of our garden by West Allerton station pulling coal trains that had come up from Liverpools docks. 56's and occasionally 58's were more common though. I think the 56's were often double header.
30907
And if we go back far enough, triple headed steam was a summer Saturday regular from Exeter Central to Yeoford, for positioning purposes on a fairly lightweight train. And then there was the Folkestone Harbour branch with up to 4 R1s or 57xx...
ac6000cw
10 May 2014
Cambridge, UK
AFAIK, it started with 3 x 'as built' 37s, then switched to 2 x rebuilt 'heavy' 37s (which used less fuel overall), then 2 x 56s and lastly 1 x 60 (the most economical of the lot). Then Llanwern closed its blast furnaces...
The trains were always fully (air) brake fitted, so the loco brake force probably wasn't that relevant (and no UK diesels until the 68s arrived had electric/dynamic/rheostatic braking, which might have influenced the loco choice if they had).
randyrippley
21 Feb 2016
a few years back the Heysham nuclear flasks were sometimes delivered by a 20/37/20 triple header. It was around the time they stopped using barrier wagons between locomotive and flask, so part of the reason may have been to create a buffer zone for the crew.
On other occasions I've seen flasks top and tailed with a 37 at one end and 2x20 at the other
theageofthetra
27 May 2012
Beckenham
Going a bit OT -Although common abroad, particular in the US, have there ever been any trains run in the UK with an assisting locomotive(s) in the middle?
I'm not including centre powered trains like a GWR auto train with a coach either side of a loco or centre powered MU's e.g APT.
I would guess that if it ever did occur it may have been in the very early days of the railways with early low powered locomotives.
sprinterguy
4 Mar 2010
Macclesfield
Not in the scenario I'm thinking of - this was in Trainload coal days (so mid nineties, rather than eighties, to be fair), long after the 56s had been constructed. Hadn't realised that there had in fact been an earlier occurrence.
