The GCR derailment thread reminded me of something I saw at Marchwood.
https://dl.dropbox.com/s/l2d8pfz0v1cabe8/WP_20130419_011.jpg
From what I've seen, the right hand line is bidirectional, with the left hand track used for passing.
I'm assuming that the points going from the right hand track to nowhere are traps to protect the single line.
Wouldn't something derailed there have a fair risk of hitting the signalling equipment? Not as bad as the infamous footbridge one, but still?
Only noticed when digging up this photo that the points on the left line are pointing up the dead track. I'm guessing that these then are also acting as a trap to protect the single line from the passing loop?
I don't know if there was anything at Fawley.
If the entire branch was clear, ie nothing beyond Totton, would these points be set this way out of habit ("These are usually set this way, so I will set them this way now"), by default (Signal is at danger, therefore points automatically set) or by a rule ("Points MUST be set to protect a line if X, Y and Z")
Edit: That's a big image, I'll do it as a link rather than inline
