Transport for Wales Class 231 / 756 Stadler FLIRTs
chrisjo
18 May 2024
Llanishen
Well, she was female had small hands and fingers due to biological differences between men and women and didn't obviously have the force needed to press both the buttons simultaneously with one hand!
Does this explanation pass your 'woke' filter ;)
Well it certainly clarifies your point, which is all I asked. Thanks.
MikePJ
10 Dec 2015
I seem to recall that TfW have been negotiating with the unions to allow drivers to release doors, which would speed things up a lot.
Pete_uk
28 Jan 2017
Stroud, Glos
Could there not be a 'it's safe to release the doors when we stop' button the driver can press to speed things up?
MikePJ
10 Dec 2015
It’s not a technical problem but a employer-vs-union problem. RMT are very resistant to anything that diminishes the role of guard/conductor and so everything has to be painfully negotiated, and at present the working practice is that the conductor must make the decision about opening the doors. I think that change is coming but I’m not sure exactly when.
Cardiff123
10 Mar 2013
South Wales
The 398s in future could be an even bigger battle - ideally they will be suited to Driver Only Operation. The RMT are completely opposed to that on existing routes that are guard operated.
But driver open, guard close makes much more sense for the 231s and 756s.
25 May 2023
Stuck on a 153 on the Marches
There's another Coryton/Penarth/Caerphilly set of test runs booked for Sunday, starting at the very civilised hour of 1042 from Canton, and continuing until 1821. Hopefully the issues with the overhead line have been resolved.
I have just seen 756005 (on 5Q11 1121 Coryton to Penarth) between Coryton and Whitchurch travelling at low speed with its pantograph down. It was very quiet so I assume it was on battery. Doesn't look as though the OHLE issues are sorted yet.
J663738
20 May 2025
At Penarth, 005 came alive,
A 756 on its test drive.
It beeped with delight,
But gave staff quite a fright—
When it thought it could do 95!
AdamWW
6 Nov 2012
Interesting. The pantograph was up on the previous test run.
Bikeman78
26 Apr 2018
Just because the gap fillers are a good thing doesn't mean they don't add to dwell time.
It's made worse by the fact that the whole filler-out-door-open....warning-sound-door-shut-fillter-in cycle has go be gone through twice, once for the local door and once for the rest of the train.
Shame that you can't press a door open button and have the gap filler go out at the same time as the one for the local door.
It will be lovely if the increased acceleration means that the Coryton line will be able to have a timetabled service. We will see.
As I mentioned on the 777 thread, having all the steps (on the correct side before anyone points that out!) slide out straight away when the doors are released would save valuable seconds. Most of them would be extended before the passengers pressed the open button.
I timed the time from stop to start at a number of stations while on a 231 yesterday (service was late, so not purposely held)
All were between 45 seconds and 60 seconds.
For comparison, I've timed 150s on the Coryton line, Typical dwell times are 45 seconds. It's notable that the performance has improved since the 153s have gone. I reckon a 150 will easily knock off 60 seconds from Heath to Coryton and vice versa compared to a 153. Doesn't sound much but every little helps.
AdamWW
6 Nov 2012
It doesn't seem to cause problems with wearing out door motors having them auto-close so quickly after being opened, but the step motors must be much more fragile affairs not to be exercised unnecessarily.
J663738
20 May 2025
Another 3 carriage 756 on test this afternoon, this time its # 006's turn. (previously # 001 and # 005)
If only one of them could run with passengers!
PS is there a 007 8-) I wonder?
J663738
20 May 2025
Is the launch to Coryton tomorrow still a possibility?
Suppose it could be, we'll have to wait until later this evening when RTT will show the train types etc.
Thinking about it, Monday from a publicity point of view would make much more sense (though its riskier if things go wrong) though I doubt they will make any fuss, since they missed their initial start date.
J663738
20 May 2025
I see on RTT's for today's schedule on PEN-CRY-CPH that one train throughout the day is not listed as a 150, but it does not say what train it actually is?
I wonder are TfW doing a low key Monday launch after all?
nigelsporne
20 Dec 2012
Coleshill
With the closure of the line north of Caerphilly 231s have become thin on the ground with most services in the hands of 150s. An obstruction at Queen Street disrupted services this afternoon and caused delays and cancellations. No sign yet of 756s on the Coryton line. Hopefully tomorrow!
Cardiff123
10 Mar 2013
South Wales
I guess TfW timed this closure to deliberately coincide with the school holidays, which makes sense as there will be more people travelling throughout the day, and especially to Barry Island. The perfect time to put the service back with 2 car 150s. :rolleyes:
AdamWW
6 Nov 2012
A three car off to Coryton this morning also one to Caerphilly.
The same one: Caerphilly-Penarth-Coryton-Penarth-Caerphilly and repeat.
Looks as if it's planned to go out of service at Cardiff Central at 19:19 with the remainder of the services for the evening run by 150s.
