Transport for Wales Class 230
david1212
9 Apr 2020
Midlands
It is interesting reading these responses.
I presumed that as a new design the alternators would be matched to the speed at which the engines developed maximum power hence running 'full throttle' a combined constant power of ~600kW less the losses in the alternators, drives and motors would be delivered unlike mechanical transmission as first generation DMU's.
I did ponder the weight of the gensets and batteries compared to the engines and transmissions of 150 and 165/6 sets. After 50+ years of development I would expect a better power to weight ratio than for a 20x DEMU power pack which would offset the weight of the batteries. Also the D-Stock to be lighter construction.
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
I did ponder the weight of the gensets and batteries compared to the engines and transmissions of 150 and 165/6 sets. After 50+ years of development I would expect a better power to weight ratio than for a 20x DEMU power pack which would offset the weight of the batteries. Also the D-Stock to be lighter coconstruction.
There is a better power to weight ratio. Even a 2 car 20x is best part of 85tons not 55 quoted (that's the power car alone).
Invincible
23 Apr 2022
Quick check on RTT and 007 and 008 plus one 197 seemed to work today
'full throttle' will only be needed when climbing a hill
But from starting from a station the diesel engines will be in tickover (or switched off!), so batteries will be proving power.
Has the problems preventing charge or switching off diesel engines in stations been identified and fixed?
WirralLine
4 Jun 2024
Wirral
On the 230s they seem to just rev high 90% of the time, deafeningly loud with the fans on when hot too. They didnt used to do this, they used to tickover and only rev up when required (usually when accelerating), 008 had some mods done last year to the point where a staff notice went up advising that it would sound different but is normal for the mods it had - the different sound being it seems to sit revving high most of the time.
Invincible
23 Apr 2022
Perhaps to ensure the hybrid mode trickle charge with the higher capacity batteries is enough when outside the stations and gradients?
Presumably they have some monitoring on this?
390112A
7 May 2017
It appears that yesterday (Sunday 18th May 2025) every service was operated by a class 230 and was successfully on time.
Is this the first day of 230 only operations on the line? previously mixed working with 150s then 197s. Unsure if 197s took over 150s or if they were brought in to cover for 230s previous issues.
Sheridan
11 Jan 2012
I don’t think it’s as simple as that but ever since it went to 3-train operation on a 45-minute frequency it was always planned for 3 230s. I think it started with one 230 and two 197s, then went to two 230s and one 197, and now at the May timetable change it’s finally gone to full 230 operation on all three diagrams.
On a Sunday most (but not all) trains shunt out at Bidston before returning to form the next service around 15 minutes later. This does add some resilience.
WirralLine
4 Jun 2024
Wirral
And predictably at least one of them has failed and there's hours of delay minutes and cancellations.
A passcom was pulled apparently and couldn't be reset. Train empty to Birkenhead depot with safety system isolated. The further delays and cancellations were caused by some sort of signalling cockup which resulted in the the depot bound 230 blocking the other one.
Peter Sarf
Croydon
Of course we haven't had any properly hot weather yet...
I'll get my coat!
Sooner or later you will not be needing (wanting) your WARM coat :oops:.
I do wonder how the hot weather coupled with pollen will affect the 230s after their last modifications.
Should be some improvement, hopefully enough.
Let us not forget that the Wrexham/Bidston line does have a punishing schedule for any DMU.
Phillipimo
5 Jan 2013
Portsmouth
Zontar
10 Oct 2018
2 units failed today. 1 taken out of service and another had to have it's gen sets replaced.
Steve B
23 Sep 2011
I also noticed on the National Rail "arrivals and departure" pages yesterday evening that there were some delays due to a train hitting an obstruction. Sounds like they had an "interesting" day yesterday...
