Transport for Wales Class 230
DLAYKEGER
21 Mar 2023
Heswall
Anybody got a clue what happenned to the replacement 230 out of Birkenheas North this afternoon. Wondeting if this was caused by the 6 trians per hour to the Open at Hoylake. Pats coaches out again. If this is the reason, then TFW swap plan is a non starter until next Monday
Caaardiff
9 Jun 2019
The replacement unit failed.
Dan G
12 May 2021
Exeter
There has been far fewer posts on this thread than the previous one; am I to presume reliability has improved? Noting that people only post on the days the units fail.
Lewisham2221
23 Jun 2005
Staffordshire
According to RTT, there does seem to have been far fewer cancellations over the last week. There do seem to have been a few occasions where the 230 has maintained time for a few trips, lost around 30 minutes on one trip, but then continued to maintain time (albeit remaining 30 late). Would be interesting to know what's going on there.
pokemonsuper9
20 Dec 2022
Greater Manchester
Could it have been a fixable fault, so the train waited a bit to be fixed then moved?
Kite159
27 Jan 2014
West of Andover
Well it seems services have gone back to 1x 230 & 1x 150 out looking at RTT. Unless that has been the plan
CaergwrleKen
2 Oct 2019
Caergwrle
The 150 is still doing its full diagram very reliably (0620-midnight) and has been for a number of weeks.
The 230s are still only doing several trips a day between them (one does 0735-1535, another does 1745, 1850), the departure times have been altered to reduce the delays and not make them look as bad.
There have been no actual failures this week so far (last week was a disaster) but they still constantly run late and do the odd miss out of Central or skip the whole route to catch up time. The performance will likely improve this next couple of weeks as they are having weekends off due to engineering so have time to cool down but we are still absolutely miles away from getting them into regular reliable service.
So to answer any queries no they aren’t doing any better but i’m sure the experts will be along now to tell us how great they are.
L401CJF
16 Oct 2019
Wirral
I've not looked into it as I've not got time at the moment, but as Ken says a 230 has been swapped earlier on than usual. Quite possibly if a 230 failed this morning it could delay the 150. No idea if that's the case.
Edit - 230 gone AWOL again this eve for its final return trip.
Woods
3 Sep 2021
Guildford
In this month's Modern Railways magazine (August 2023), the New Train Reliability league table is published in Roger Ford's column, for Railway Period 1 2023-24. I believe in the normal world this means April 2023.
Of note is that the TfW 230s are not bottom of the league in terms of Miles per 701D. In fact, by that metric, they are currently doing slightly better than TfW's Class 231s (Stadler), and almost twice as well as Merseyrail's Class 777 (also Stadler). Both of which are brand new trains from the Swiss, famed for their supposed legendary reliability.
Miles per 701D is a measure of reliability and replaced 'MTIN' as the metric for measuring fleet performance in 2022, as explained here: https://www.modernrailways.com/article/new-measure-fleet-reliability
But the table quotes both 701D and MTIN figures. The article says that Miles per 701D, "....better reflects the impact of fleet failures on the fare-paying passenger."
In fact, in a paragraph accompanying the article, Roger Ford makes the observation:
"Appropriately, having described the trials and tribulations of TfW Rail's Vivarail Class 230 hybrid units, the five-strong fleet makes its debut in this month's New Train TIN-watch table. And, in relative terms, it's quite an impressive first showing, not only above the 2000 MTIN MAA mark, but with clear blue water between the fleet and Stadler's debutants at TfW Rail and Merseyrail. And also better than TfW Rail's longer-established CAF Class 197 DMUs. Of course, new fleets can flatter to deceive before the cold rolling averages take their toll. But, for the moment, chapeau to all those at Vivarail and TfW who, despite the turmoil, have finally got the trains into service, and six places off the bottom of the table to boot."
The statistics therefore suggest that performance is not as bad, relative to other much newer train fleets, as the naysayers, haters and gap year experts in this thread would have you believe.
Here is the table:
DLAYKEGER
21 Mar 2023
Heswall
When you look at the total milage something does not seem to ring true in terms of in service passengrr miles. If it is April i don't think we had more than a two hour service for part of the day and just on weekdays. Can someone confirm the training runs have not been included. Total milage would suggest about 8 return journeys per day which I doubt occurred as evenings back then seemed to be bustitutions, if I remember correctly. And for a fleet of 5 trains that have been with TFW for several years, this does seens not seem a very efficient use of resources.
Caaardiff
9 Jun 2019
The 231s are diagrammed in service all day. The 230s are only diagramed for half a days work then swap out with a different unit so they can go off and cool down or whatever needs doing to them. So not a true representation.
Steve B
23 Sep 2011
It is also worth noting that these figures are for April, before the hay fever season and hot weather (which won't have helped the overheating problems). If, as suggested above, the data also includes the training runs, then that will affect the figures - some of the delays have been down to problems with the doors, including the passenger controls. I haven't observed any of the training runs doing anything more than stopping at a station, the guard opens and shuts his/her door, and the train departs. No test of the passenger/train interface.
The reality is that when you have trains regularly running 20-30 mins late on a total journey time of 1hr then something isn't right.
It should, in fairness, perhaps be mentioned that not all delays have been down to the 230s themselves. There have been a medical emergency, tresspass incidents, and also delays/cancellations due to crew availability issues.
Zontar
10 Oct 2018
The fine art of deception. The 230s have been failing daily, but this helpful set of figures is only for April which they will stick to like glue.
Manipulation of data won't bring back customers or stop the units failing daily.
Invincible
23 Apr 2022
Looking quickly at Realtime trains website 230007 was working with a 150 yesterday.
Guess there were also some 230 training runs this week.
I understand from previous posts Stadler (or some other 3rd party?) are now maintaining the 230s for TFW, so guess they are aiming to get all 230s in regular service (including 230006?).
One major problem (Thanks @tomuk and @Woods) is getting radiators fixed to prevent overheating?. Also to restore engine stops and starts in stations.
Looks like bus replacement service this weekend due to trackwork to improve the service.
Woods
3 Sep 2021
Guildford
Hardly deception. Just quoting some stats, you know - a bit of science - but hey facts aren't as exciting as opinion and anecdotes are they? Thought it wouldn't be long until someone came along with some conspiracy theory that the stats are a stitch-up by dark forces. I'm sorry the facts don't quite fit the standard narrative that these trains are the most hopeless trains ever built.
And yes ok it's just for April, alright then let's wait and see what the stats are for May, June, July and onwards. Perhaps they will be better, perhaps they will be worse. We will see.
"They" is an independent journalist from an independent and highly respected trade magazine - hardly the mouthpiece of TfW.
What does a 701D incident indicate? (Not a subscriber to MR)
Not 100% sure myself but the best explanation I could find was here: https://www.modernrailways.com/article/new-measure-fleet-reliability
It's a TfW team looking after the 230s at Birkenhead North which is a Stadler depot. But Stadler aren't actually doing the maintenance. That might be where the confusion has come about.
Invincible
23 Apr 2022
Thanks
Wonder if they, and perhaps the SWR team at IoW (where the trains now seem reliable), are in touch with the former Vivarail employees at GWR about maintenance, now GWR have brought the Vivarail info and spares? There may be some commercial value for GWR giving assistance? Although the main aim is to get a 230 running at West Ealing.
Zontar
10 Oct 2018
Not sure which conspiracy you think I'm chasing.
They fail daily. Fact.
The data doesn't represent that fact.
Steve B
23 Sep 2011
Seems to have been a pretty good day on the Borderlands line today. Worst delay was 6 minutes, and time subsequently made up.
L401CJF
16 Oct 2019
Wirral
Ive been told they've had a few fault free days, presumably as its cooled down a bit. A quick glance through RTT for yesterday (31/07) shows the 230 running around 20L by the time they swapped over at 1630 ish.
Ive just had a look through todays RTT data, and its very odd to see such a small number of red departures and zero cancellations!
CaergwrleKen
2 Oct 2019
Caergwrle
The 230s aren’t working weekends at the moment so have time for a rest, they’re still only doing half a diagram each per day Mon-Fri so let’s not get too carried away. If they went onto daily all day diagrams the failures would soon return so they obviously still haven’t got confidence in them. No doubt the politicians and the experts will be on soon telling us what a success they are and how they’ve been worth all the millions spent.
L401CJF
16 Oct 2019
Wirral
Oh absolutely I agree 100%, but seeing a near perfect service today is a real breath of fresh air. No doubt when it warms up again over the next few weeks it"ll be back to square one..
Zontar
10 Oct 2018
TFW have now launched a map to track services in real time. I know most of us are aware of RTT but i doubt the avarage traveller would be aware of it, so may prove useful.
It's quite amusing to see them give a huge pat on the back for innovative (and more useful) way to see how late the trains are running.
Just not buying/running unreliable trains would have been a lot more easier
Western 52
19 Jun 2020
Burry Port
The app seems quite good and covers more than just TfW lines and services. It looks rather busy at major stations! It shows headcodes too, useful for some of us. Now if they could add freight trains.....
