Transport for Wales 769's
Wyrleybart
29 Mar 2020
South Staffordshire
The thing is TfW have nine of these contraptions and Northerm have eight. TfW seem to allocate mostly three or four a day. In the last week or so Northern manage three or four. Between those two TOCs there are significantly more units sat idle, presumably under repair, than there are in service earning their corn. But that is the point, the units have been handed over by Wabtec and Porterbrook to the TOCs. so you might assume Porterbrook are receiving lease payments for them.
I am interested to see how GWR's fleet will prove, bearing in mind they should use AC DC and diesel, whereas the TfW units are effectively DEMUs
craigybagel
25 Oct 2012
How many 197s are being released by the increased LHCS fleet? Enough to get rid of all the quirky old tat?
In theory none, as the increased LHCS fleet is being used to release 170s instead, which are no longer planned to stay with the franchise.
The 769s stay was always intended to be a temporary one anyway, released from the Rhymney Valley by the Stadler Tri-modes. LHCS shouldn't come into it - unless there's some form of cascade with whatever new stock arrives first that allows the 769s to be removed earlier than planned.
Given how TfW have shown a fair degree of flexibility in the past with their plans, I wouldn't put it past them to try and find a way to remove the need for 769s sooner than planned.
Bikeman78
26 Apr 2018
I wonder when the lease on the 170s expires? Getting rid of them before the 769s would be crazy.
To be pedantic, TfW only has eight at the moment. I think the last one is 769426 but I don't know where it is.
Caaardiff
9 Jun 2019
There's no scope for 150s to work Rhymney as they are desperately needed for the Taf lines. That being said they would only be needed for strengthening of current services which are either booked 2 car or shortformed to 2 car, but these 2 car services are very busy.
The only short term viable option is 197s displacing units to free up 153s (Chester - Liverpool and Crewe) firstly, then 153s from West Wales once clearance and crew training starts. But even that is several months away.
The next option as already suggested is 231s to work Rhymney line before the 756 arrives. They are pretty much the same traction so makes sense if times are desperate.
I doubt the 170 leases can be extended as EMR are desperate for them. TfW would need to find an alternative to cover the 170/231 work until the 756s arrive. I'm sure there will be some 175s freed up eventually once the 197s are bedded in in the North.
I cant see TfW pulling the 769 fleet completely. What I do think will happen is they will have fewer out each day and will have to deal with the failures as they arise.
Even dropping it to just 2 in use each day might help reliability.
Wyrleybart
29 Mar 2020
South Staffordshire
The whole DMU rolling stock procurement thing has gone a little sideways hasn't it. WMR class 196s parked up at Bletchley because Tyseley can't cope. Pity DfT couldn't temporarily send some WMR 196s to Northern with a quick course for some crew trained on 195s on maybe one particular route. Then cascade to send a few 150s to Cardiff on a temporary basis.
There would need to be an admission that the 769s are just not reliable enough though, which I can't say will ever happen.
Has anyone done any analysis on the TfW 769 failures becuase they all seem to occur in the same area. I am sure I read one suggestion was that high voltage power lines strung over the route may be causing issues, fsar fetched I know.
Rhydgaled
25 Nov 2010
The TfW website has/had some train specification documents somewhere listing all sorts of details like number of seats etc. One of those details is the lease end dates - all subject to haved changed since the franchise was transferred to the Operator Of Last Resort of course but here's what they were:
  • Class 175: 31/05/2022
  • Class 153: 31/10/2022
  • Class 158: 31/10/2022
  • Class 150: 31/12/2023
  • Class 197 (declassified first class): 31/12/2024
  • Class 230: 16/10/2033
  • Class 197: 16/10/2033
  • Class 170: 16/10/2033 + [REDACTED]
It appears that the class 170s actually had the longest lease of any fleet, being leased beyond the end of the KeolisAmey franchise. Perhaps the transfer of the 170s away from TfW is in fact a sublease.
197s working Conwy Valley and Manchester-Llandudno would also cascade units southwards, with Manchester-Llandudno releasing 175s which could be used to release 153s from S.W. Wales if TfW are desperate for them without needing 197 clearance or crew training in the south.
Yes, it seems to make sense, the biggest issue is probably crew trainning unless 231s and 756s are similar enough that no re-training would be needed to move from signing 231s to signing 756s. Also, what are the timescales for 231s arriving compared to 756s?
Greybeard33
18 Feb 2012
Greater Manchester
Northern is currently managing to keep three out of eight 769s in service most days. But I understand a further two units are in daily use for crew training and are available to rescue a failed unit when required (the training includes coupling exercises, hence the need for two units). Whereas TfW seems to rely on the Thunderbird 37 for rescues.
So Northern availability is perhaps a little better than TfW's, although still dire.
CardiffKid
13 Feb 2011
Cardiff
I hadn't realised the 175's lease was up so soon.
Given the unreliable nature of a lot of the stock (inc but not limited to the 769s) and the timescale involved for bring in and training drivers on new units, there must be a need to extend this lease surely? And that's not to mention the refit the 175s have barley just gone through.
Bob Price
8 Aug 2019
Think the 175's have been identified for use elsewhere so the leasing company would have been involved with their upgrade. Can't see TfW spending money on stock which they will loose a year later.
CaergwrleKen
2 Oct 2019
Caergwrle
The latest wibble doing the rounds is the use of 197s on the Wrexham Bidston line to free up 150s should the 230s fail to hit their next target date or indeed any date..
PHILIPE
14 Nov 2011
Caerphilly
It is a franchise commitment that units must have a re-paint after a certain length of time.
CardiffKid
13 Feb 2011
Cardiff
A repaint and a refit in TfW/WG Colours?
Regardless of the complexities of the franchising system you surley must agree with me that doing all this work (some of which is going on today) and then handing them back next year is a poor use of taxpayers money and a poor decision by the Welsh Govt to do it now and not (for example) five-six years ago?
These units have been in need of some TLC for a while and WG have paid above and beyond to refurbish units even back in the ATW days.
Cardiff123
10 Mar 2013
South Wales
Why is there a detailed discussion taking place about 175s in the TfW 769 thread? This thread seems to have gone wildly off-topic
craigybagel
25 Oct 2012
To be fair, the discussion was around whether the 175s could stay with TfW longer than planned so as to allow an internal cascade to see off the 769s early. If the 175s are already spoken for, this won't be possible.
However, the future for the 175s is one of the railways great mysteries.
anthony263
19 Aug 2008
South Wales
I've thought east-west rail or GWR. Apart from them too im at a loss unless Northern takes them
PHILIPE
14 Nov 2011
Caerphilly
As things are we already have a 175 Speculation thread here but overall there is no connection with the 769 disaster
www.railforums.co.uk/threads/class-175-future-speculation.218095/page-8
Mag_seven
1 Sep 2014
here to eternity
A reminder that this thread is to specifically discuss Transport for Wales 769s.
If anyone wants to discuss anything else they are welcome to use another existing thread or create a new one if needs be.
thanks
Bikeman78
26 Apr 2018
I think that if the class 175s go off lease next May then the lack of 769s will be the least of TfW's worries!
Kite159
27 Jan 2014
West of Andover
I noticed only 1 example made it out on Saturday (769002) and only 769445 made it out today [unless I missed one of the morning peak specials which goes straight to the depot after arriving at cardiff].
Not the best when a 4 coach unit is replaced by a single 150 (or a pair of 153s). Especially as things might get tighter in December when the 170s go.
Caaardiff
9 Jun 2019
The 170s aren't going in Dec.....
Bob Price
8 Aug 2019
I see nightly tweets of services cancelled due to 'resourse shortage'. And it's probably a good 18 months before they can start to get rid of them
AM9
13 May 2014
St Albans
Do these tweets say whether the shortages are train or driver 'resources'?
