OLEngineer
Hello,
I've been trying to wrap my head around our 2x25kV autotransformer system, and I would love some clarification! (Please poke holes in my knowledge!!!!) What types of auto transformer are in use in an ATFS and an ATS? As per the major feeding diagram, 400kV down to 25-0-25 at an ATFS (KAGA in my local case) through a centre tapped auto transformer. +25kV to OLE, 0v centre tap to traction return, -25kV to ATF. Then at a ATS, is there also a centre tapped auto transformer? As per Garry Keenor's diagram:
What is physically present at the ATS? Is it one centre tapped auto transformer? Are there multiple regular transformers? From his explaination of the diagram, he says that the transformers primary winding has twice the number of windings as the secondary, therefore the transformer action drives twice the current. This makes sense, but the drawing is confusing me. Why is there a transformer across +25kV OLE and the 0v Traction return, and one across the 0v Traction Return and the -25kV ATF? What is the purpose of the latter auto transformer? Or is this how he is trying to prove the transformer action driving twice the current by having half the number of windings as the primary?
Also, what kind of core is used in these auto transformers, both at the ATS and the ATFS? Is it toroidal, EI type? It would certainly help knowing what!
Is this image correct? (Im much less of an artist than I am an electrical engineer, which I am a complete layman!) Does the regular autotransformer cause the primary current to phase shift 180 degrees or is that only caused by the centre tapped autotransformer at the ATFS? How do they interact here in the primary winding?
Also, can you have centre taps across the primary and the secondary? Can you connect these centre taps together?
That should be all of my questions, I hope this is the right place to ask!
