- Joined
- 14 Jul 2011
- Messages
- 20,321
Not sure if this should be in this forum or rolling stock.
But does anyone know if there is any particular hard reason that tram-trains tend to be built with 100kph / 60mph top speeds?
Is there some change to the crash standards above this that makes 70/75 impractical, or is that the European railways where they were developed have little use for such speeds on their countryside sections?
I am wondering this because many of the places where tram trains might be useful (railways near Nottingham etc) have sections where speeds higher than 60mph are common and they might be able to significantly reduce travel times by operating at the higher speed.
After all going from 60mph to 75mph potentially reduces travel times by a quarter!
It can't be a power supply issue as heavy rail units with similar installed power reach higher speeds, so why is it? (A Citadis Dualis has up to 900kW of traction motor outputs, which makes it more powerful than a Class 317 at half the weight!)
