NLC1072
What sort of trains should I expect? Will I see double deckers? How does the ticketing work, I need a train around 15:30 on 11/08/15.
Thanks!
Thanks!
while Basel Badischer Bahnhof ('Bad Bf') is a terminus for trains from Germany, and part of the German railways.
fare from CHF 41.50
The SBB website is a bit sneaky in this regard. The "fares from" are half the price you are likely to pay! The headline fare only applies to children and railcard holders...
In this case, the normal adult fare is CHF 83.
A one way ticket from Basel to Brig starts at 41.50 swiss francs. Or 24 english pounds for little more of 2 hours of travel. For about that same amount of money 1 can visit the Netherlands with the railways for 3 complete days.
The SBB website is a bit sneaky in this regard. The "fares from" are half the price you are likely to pay! The headline fare only applies to children and railcard holders... In this case, the normal adult fare is CHF 83.
IC977: class 460 + 8 IC double deck push pull set + 4 EWIV push pull set
IC 824: 2 x EWIV (DVT leading) at front then class 460 then 9 car IC double deck set
May i use the term "*******s" for the Swiss?
I tried the link given by zuriblue and got: System interruption. Please try again later. Thank you.
Interesting consists. Do these trains split on route?
My friends in Switzerland have a demi-tarif card, and say they prefer the simplicity of the Swiss fare structure: no worrying about when to book, or what trains you can use. But it seems to me there is room for some flexibility. And although CFF do occasionally offer advance specials, they never seem to be doing it when I need tickets!
No. SBB have fixed sets but do not shirk from adding another 'segment' of vehicles. This extra segment can either be attached onto a set of coaches, or onto the loco 'pushing' a push-pull set, whereby the loco will then be in the 'middle' of the coaches.
Towards the end of the day it isn't unusual to see IC and IR trains formed of combinations of the "mini sets" with multiple driving trailers in the formation, I guess this is to get them back to their respective depots.
A minor point, but, perhaps unintentionally This makes it sound ad-hoc, but they are all diagrammed specifically, with the extra coaches diagrammed for the naturally busy times, i.e. morning peak, evening, but also at weekends on routes where weekend traffic is heavy. Also I'm not aware of more than two driving trailers being diagrammed in one trainset.
I've also only seen two - but I have seen a train (2100ish off Brig through the Loetschberg base tunnel) formed of two mini-sets i.e. 2 x [EW IV B driving trailer, EW IV B, EW IV A] which appeared to be a regular diagram.
Found it - train 1088 21.20 off Brig, although Reisezuge ch shows a 4 set plus a 2 set.
