Diesel1985
Just had my invite. I've applied to Euston. Good luck everyone
Nothing yet, but still marked as submitted on Avanti careers. Just keep an eye out and hopefully you'll know within the next few days.Has anyone applying to Liverpool had the email yet…?
Same almost everywhere I've seen, though Northern wanted 45 mins on their latest ad.Avanti says you need to live an hour away from the depot? Is this a strict requirement?
The position has been closed for a while now. They only opened on the 2nd and then Manchester and Euston opened again for a bit longer on the 3rd.Is this now closed anyone know?
Damn... I missed it! I was having problems with rail forums. Only now did I manage to get back on it and saw this! Would have appliedThe position has been closed for a while now. They only opened on the 2nd and then Manchester and Euston opened again for a bit longer on the 3rd.
YesAvanti says you need to live an hour away from the depot? Is this a strict requirement?
The ones who have been successful, what's your application status on the website?
Has anyone had a rejection email?
Mine still says application submitted on the websiteThe ones who have been successful, what's your application status on the website?
I do not know/ can not remember if I did any of these tests previously so was not sure if I failed this time it would mean I can no longer be in the running for the position also do not want it to look bad to the other TOC that I am still applying for roles despite being in process still so not sure if they can see these tests there side. ThanksNo it won't affect anything g at this stage. You simply don't matter.
Thank you for confirming, it's a relief to know.
Sorry can you clarify what you mean by having your application with anyone else at risk. How do others affect you?
HiSituational Judgement Test
More about you
Preference Questions
Priorities - Driving Tasks
Priorities - Non-Technical Skills
I've been told that you would receive a rejection email or at the very least your application will say you've been rejected. That said I have sort of resigned myself to thinking that if anyone doesn't hear anything today then chances are they probably weren't successful.I'm guessing if we've not had the email, we've been unsuccessful then
Thats not the case unfortunately. Some just remain submitted and do not change in status.I've been told that you would receive a rejection email or at the very least your application will say you've been rejected. That said I have sort of resigned myself to thinking that if anyone doesn't hear anything today then chances are they probably weren't successful.
Well done. Good luckJust got my email for the OPC assessment. Fingers crossed!
Your 2 chances refer to psychometric testing, so if you've failed any of them once then that counts as a strike.Genuine question, but if I failed the OPC criteria for a Virgin Trains driver apprenticeship a few years ago, does that count as previously failing the train driver assessment process?
I mean that I did an assessment similar to the one now but didn't meet the criteria.Your 2 chances refer to psychometric testing, so if you've failed any of them once then that counts as a strike.
What do you mean by failed the OPC criteria? Do you mean you did psychometrics and passed but didn't meet the enhanced standard?
Well if it was the online assessments then no it doesn't count as a strike.I mean that I did an assessment similar to the one now but didn't meet the criteria.
Just completed tests. All standard stuff and common sense. Just done mine
Just done mine now, did you get a confirmation email once you completed it?Just completed tests. All standard stuff and common sense.
I honestly have no idea, if I were you I would contact OPC and ask them.If you've already been accepted into a TOC talent pool your OPC assessment results have been checked right? So how could failing Avanti's weird extra test that replaces MMI affect that? Do they re-check your results when offering you a course? Or do OPC contact all TOCs to tell them you've now failed? Doesn't make sense
Did mine this morning. It's not that bad - just try to relax and not rush.Just got an email from OPC test centre for Liverpool app - petrified to login now!
I was thinking the same. I’m in a talent pool for someone else. They’re not gonna check again surely!If you've already been accepted into a TOC talent pool your OPC assessment results have been checked right? So how could failing Avanti's weird extra test that replaces MMI affect that? Do they re-check your results when offering you a course? Or do OPC contact all TOCs to tell them you've now failed? Doesn't make sense
