It's generally a letters-number system. There are plenty of examples here: vagonWEB
(NB this site will only be partially updated from the timetable change - the admin doesn't have the time to make all the corrections needed now)
Just go on the DB app, they normally have the numbers for most passenger trains (except some specials).
I can’t fully answer this but I do know that for example in the Netherlands some ranges of numbers are reserved for international trains. Not all of those are taken so I presume any new service must use a number that is free is any of the countries it passes through. Also, it happens that trains switch number on the border, so that’s an option when it doesn’t fit.thanks for that but i was thinking more on how the systems work, e.g. if you ran a brand new route (e.g. Berlin-Paris or Milan-Barcalona) how would you decide its number?
The European Rail Timetable lists all the numbers for the many services it shows.thanks for that but i was thinking more on how the systems work, e.g. if you ran a brand new route (e.g. Berlin-Paris or Milan-Barcalona) how would you decide its number?
Oh that's a shame as it is an incredible resource. But equally it must take a lot of time and effort to run it as well as it is so I can understand if the admin didn't have that time anymore!(NB this site will only be partially updated from the timetable change - the admin doesn't have the time to make all the corrections needed now)
That accords from what I remember of German train numbering: I recall the ICEs to Brussels having very low two-digit numbers (ICE 14 is one, if I remember right) then domestic IC/ICEs having three-digit numbers typically, four-digit for semi-fast services and five-digit for locals.For Germany it is explained in great detail here: https://de.wikipedia.org/wiki/Zugnummer
Briefly, the numbers are divided in blocks, with the lowest numbers for international trains subdivided into country pairs(so that the other country can reserve the same set)*, then long distance trains divided by line number and time of day, then there are blocks for regional, charter and cargo services. Regional trains often have 5 digit numbers, but that doesn't matter too much because there are no service-specific tickets or reservations and usually the line number(e.g. RE1) is used in preference to the service number.
Yes, it's unquestionably a huge piece of work, but of such value too.Oh that's a shame as it is an incredible resource. But equally it must take a lot of time and effort to run it as well as it is so I can understand if the admin didn't have that time anymore!
That's a kind of trick indeed: 90xx as that looks similar to the UK headcode 9Oxx. And similarly 91xx for what's 9Ixx in the UK.Eurostar reporting numbers fit into the standard pattern for each of GB/FR/BE/NL.
Not fully true, as the IC(E)s in the Netherlands have three-digit numbers. IC Berlin is 14x and 24x and ICE is I believe 12x and 10xThat accords from what I remember of German train numbering: I recall the ICEs to Brussels having very low two-digit numbers (ICE 14 is one, if I remember right) then domestic IC/ICEs having three-digit numbers typically, four-digit for semi-fast services and five-digit for locals.
Only the first tranche of Brussels services have 2-digit numbers (as do services to Vienna), the later additions are in the 300s; there are plenty of ICs and some ICEs with 4-digit numbers.That accords from what I remember of German train numbering: I recall the ICEs to Brussels having very low two-digit numbers (ICE 14 is one, if I remember right) then domestic IC/ICEs having three-digit numbers typically, four-digit for semi-fast services and five-digit for locals.
This is logical because the train describers in European signalboxes and signalling centres only show the digits and not the letters. Therefore ICE 2200 would appear on the control panel/VDU as simply '2200'.The important point is that - unlike the UK - numbers are not repeated across the country (not sure about S-bahns) and across category (so if there is an ICE 2200 there won't be an RE2200. I think this applies across Europe.
Is that how a Dutch signaller managed to put the IC Berlin service into a terminus platform at Hengelo a while back?This is logical because the train describers in European signalboxes and signalling centres only show the digits and not the letters. Therefore ICE 2200 would appear on the control panel/VDU as simply '2200'.
Don't think so, as an IC Berlin service has a 14x or 24x number, while the normal service into the bay platform in Hengelo (RB 61) is numbered 203xx.Is that how a Dutch signaller managed to put the IC Berlin service into a terminus platform at Hengelo a while back?
......and the driver took it?Is that how a Dutch signaller managed to put the IC Berlin service into a terminus platform at Hengelo a while back?
No, that was the coincidence of the IC Berlin being handed over by the German signaller to his Dutch colleague having a delay, resulting in it being mistaken for the RB61 that usually would pass the border at that specific time.Is that how a Dutch signaller managed to put the IC Berlin service into a terminus platform at Hengelo a while back?
There are exceptions however where only half of a range is used, which for example is the case in this instance mentioned by biko...so if there is an ICE 2200 there won't be an RE2200. I think this applies across Europe.
No, that's the 2035x. Being an exception with only half a range used for the RB61, the 2030x-range is used for the RE18 Maastricht - Aachen.while the normal service into the bay platform in Hengelo (RB 61) is numbered 203xx.
As the numbers for the RB61 stretch from 20350 to 20389, the last 2 digits vary, so that's why I used 203xxNo, that's the 2035x. Being an exception with only half a range used for the RB61, the 2030x-range is used for the RE18 Maastricht - Aachen.
Speed signalling, so there's no automatic expectation that the driver will be able to avoid being misrouted. There was a thread on the incident in this forum at the time.......and the driver took it?
Thanks.Speed signalling, so there's no automatic expectation that the driver will be able to avoid being misrouted. There was a thread on the incident in this forum at the time.
Thanks. Very interesting.
