Train Length Reminder
Inthewest
12 Feb 2020
The West
I'm sure I have seen a photo of a cab that has a simple slider to show the driver what length their train is but I can't find which stock it is now.
Is this a thing or have I not really seen it?
MCR247
7 Nov 2008
I think the first generation of 377s have them
samrammstein
13 Apr 2011
Capenhurst
Merseyrail 507/8s have length (3 or 6 car), service class (ECS or passenger) and stopping pattern reminders.
Until recently the only station on the ME network that was routinely skipped was Capenhurst so it had it's own reminder.
dk1
2 Oct 2009
East Anglia
C-DAS shows our train length on the TMS and a double click on the 745/755 foot pedal let’s us know when train length is clear.
furnessvale
14 Jul 2015
Unless one is already fitted, given the length of freight trains, I would have thought some sort of active length reminder would be a "must have" fitting on freight locos.
This could take the form of an odometer based distance reader, or possibly time based from the speedo. The driver could press a button at the end of a speed restriction and receive a warning when the end of the train passes the same point. Of course, the ability of the driver to enter the actual train length into the system is a must.
43096
23 Nov 2015
I seem to remember reading about such a capability on Class 66s; I think it was part of the Q-Tron system and the driver entered the number of SLUs and when activated the system then counted down on passing the end of a restriction. Can anyone confirm if my memory is correct?
martin2345uk
21 Sep 2011
Essex
That is exactly correct though I THINK you enter it in feet (been a while since I drove one now so open to correction).
Taunton
1 Aug 2013
Longstanding USA system, so inevitably in feet (even though the Class 66 were built at the GM plant in Canada). Initial value was trains there on single track entering a passing siding, so the crew were aware when the train was fully off the main line, particularly once trains started to eliminate cabooses so the conductor at the rear was no longer radioing this forward.
_toommm_
8 Jul 2017
South West London
A few of them do. They have a button you can press that beeps once, that starts the measurement. It then beeps twice when the rear of the train passes over the point at which you pressed the button. 66s have them, I’m sure 70s have them. Not sure if the 68s have them or if it’s in the TMS/onboard computer.
SuperLuke2334
23 Oct 2021
Welsh Marches
68s definitely have a physical button.
