Train Journeys That Would be Quicker by Bus
Mutant Lemming
8 Aug 2011
The journey from Wick to Inverness is over an hour shorter by bus than by rail are the any other instances where the bus is considerably quicker than the train ?
hairyhandedfool
14 Apr 2008
There have to be plenty of them (Luton-Aylesbury = 144 minutes by rail, 94 minutes by bus. Luton-Stevenage = 89 minutes by rail, 55 minutes by bus), but probably not so many where there is a direct train service.
cuccir
18 Nov 2009
There will be quite a few, particularly around branch lines.
Scarborough to Whitby takes between 4 and 5 hours by train, but 1 hour by bus....
Ah, direct journeys will make it a little more difficult,
The Middlesbrough to Whitby bus is still around 10 minutes quicker than the direct train, but doesn't compete with the Inverness-Wick example!
YorkshireBear
23 Jul 2010
Middlsborough Whitby is quicker by bus i belive. Keighley to Haworth is quicker by bus ;)
trentside
14 Aug 2010
Messroom
I believe that Grimsby and Cleethorpes to Hull is quicker by bus than by train.
The same is possibly also true for Scunthorpe, but haven't actually checked it!
maniacmartin
Fares Advisor
15 May 2012
Croydon
Are you including the time to walk from the station entrance to the platform?
If so, I'm sure there are many journeys like Pontoon Dock DLR to West Silvertown DLR, where the bus can be quicker than walking up tand down the many stairs to the platform
bicbasher
14 May 2010
While it will be quicker to catch the train, there are some instances where a pax would be better boarding a bus. Lewisham to Ladywell for example has a higher frequency of buses between the two stations than the 2tph it gets from the Cannon Street to Hayes service.
Denmark Hill to Victoria until December has 4tph (2tph evenings and Sundays) in comparison to Route 185 which runs every 12 minutes.
Ivo
8 Jan 2010
Bath (or Southend)
I haven't verified it, but I wouldn't be surprised if Liskeard to Looe qualified for this.
You could say that for almost any urban area though ;)
gnolife
4 Nov 2010
Johnstone
Pollokshields East to Pollokshields West
Manchester Airpt - Stockport.
Rochdale - Bolton
Cross Gates - Wakefield Westgate, I think
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
And for a lot of rural routes too. Leamington and Warwick get three buses per hour to Stratford, but the train is only every two hours. Leamington to Coventry during the day works out as nine buses per hour between the various routes, nine times the frequency of the train (but five times the journey time).
richw
10 Jun 2010
Liskeard
Looe is a nightmare to drive to, and I don't believe a bus is quicker.
Newquay to truro is an example though. Bus is around 30 mins, dependent on the connection at par can be 90 mins quickest up to 3 hours by train!
calc7
8 Aug 2011
Do the Stagecoach expresses no longer run? X15 and X18 iirc, at 02 and 32 minutes past the hour from Leamington I think. Those only took 15-20 minutes and were valid with the Stagecoach uni bus pass.
