Train Journey Recording/Logging Systems
ABB125
23 Jul 2016
University of Birmingham
What train journey recording are there, other than RailMiles? I currently use a very basic spreadsheet to record everything, but it's somewhat unwieldly and obviously doesn't have most of the features of a "proper" system (such as most frequent journeys, quick and easy filtering of entries etc). I would quite like to upgrade to a better system, but not RailMiles (for a number of reasons, including cost and having lots of features I don't want/need).
Do any other systems exist? I've done a bit of searching, but haven't found anything. There seem to be quite a few different offers for planes, but not trains...
I have some potentially quite niche requirements I'd like: I'm not bothered about departure times, headcodes etc, all I care about is date, start/end/via, distance, unit/locomotive, and free text field for notes. Needs to be able to cope with international journeys/trains, and Underground/metro/tram etc, as well as UK trains, with the ability to categorise each entry appropriately. Ability to "collapse" entries into days/multi-day trips, multi-segment journeys etc (here's a hypothetical example of each of these: day 1 I travel BHM-GLC then GLQ-ABD then ABD-INV then INV-EUS on the sleeper, day 2 I travel EUS-MAN then MAN-YRK then -BHM. I want this to be viewable as individual journey segments (eg: BHM-GLC via WCML on 390xxx on 1 January, xxx miles), daily totals (BHM-GLC, GLQ-ABD-INV-EUS on 1 January, xxx miles total) and trip totals (BHM-EUS on 1 January, EUS-BHM on 2 January, xxx miles total). However, the INV-EUS sleeper is actually split into two segments: INV-EDB diesel-hauled, then EDB-EUS electric-hauled - at present, this would be recorded as two separate entries in my spreadsheet (and would also be split across two days) with a note that it's a sleeper train, but I'd like it to be treated as a single INV-EUS journey for things like "longest journey"*).
Alternatively, any suggestions for the best way to make my own, ranging from advanced spreadsheets (which I should be quite capable of doing, with the help of Google) to building my own database system (suggestions of software to do this with welcome... I dabbled with Microsoft Access in around 2018 as I happened to have access (ha ha) to it, but for various reasons that didn't work out) would be welcome. Has anyone done this themselves? Given how picky I am, I suspect a custom system is probably best, but will be quite a bit of work!
Thanks very much, if any of that doesn't make sense please let me know.
*A similar but even more niche scenario which I have concerns loco-hauled** services which split/join en-route (mainly Austrian RailJet services). Say I'm going from Munich to Vienna: between Munich and Salzburg, it's nice and simple, one RailJet set with one locomotive powering; but then, at Salzburg, it joins to another RailJet set from Innsbruck (or beyond) for the remainder of the journey - that's now two locomotives powering, but still the same journey... Note that the Caledonian sleeper doesn't fall into this category, because it swaps locomotives, rather than adding them.
**but not multiple-unit services, due to the way I record things!
30 Sep 2017
S&W of Alexander Dennis, N&E of Wrightbus
What you describe seems apt for viaduct.world, which is still in some beta stage but is how I've been recording my journeys of late. It is entirely free and while some bugs persist it is actively being improved. Also supports imports from Railmiles.
Does not yet support metros and trams, but does have some data for European systems (although it can be slightly dodgy).
A S Leib
9 Sep 2018
I'm not sure if it covers all of your requirements, but I've been using trainlog.me; I used viaduct briefly but I don't think it lets you add via points or stations, including tram / metro ones, in the system as easily as trainlog if at all.
