Train into Cleethorpes early hours Monday 29th July
grah2702
2 Aug 2010
Grimsby
Has anybody any idea what this train is that is on Realtime Trains due to arrive Cleethorpes 0055 and depart 0155.
Ind Plan Arr Origin ID TOC Destination Plan dep
STP 0055 York Thrall Europa 1 FRGT ZZ York Thrall Europa 0155
Boothby97
24 Apr 2011
Cleethorpes
Probably won't be up for that one, but cheers for the headsup grah2702.
As it starts and terminates at Thrall Works, it sounds like a weedkiller.
Sam
21 Feb 2011
Doncaster
Based on experience, that is the Rail Grinder running from and to York Thrall Europa. A monstrous several yellow vehicle contraption, with a lot of lights. Quite something to see if you come across it.
grah2702
2 Aug 2010
Grimsby
I was going to go down to my local station Stallingborough to see it but glad I didn't as it was an hour late (0129) and I was well away in the land of nod by then.
DarloRich
Fenny Stratford
It wont be in this case - it will be a weed spraying MPV, especially with the "York Thrall Europa" in the destination/origin details.
That also sounds like a description of the Loram C21 rail grinder - that does run from York where it is stabled at Leeman Road but doesnt run from York Thrall Europa - it is, however, a very impressive bit of kit if you see it in action at night!
Boothby97
24 Apr 2011
Cleethorpes
It was delayed to a power cut at Wrawby Jn. It was a weedkiller, I wasn't out for it, but my uncle did see it pass his house.
Thanks, Sam
