Track diagram sources
drmvy
19 Mar 2026
Exeter
Hi,
Does anyone know if track diagrams are publicly available online?
Related shared a pdf in https://www.railforums.co.uk/threads/signalling-map-of-the-uk.219123/post-5253821 and there are some resources in that same thread.
There is the NESA (National Electronic Sectional Appendix), but subscription seems to be locked behind requesting access, and through some corporate email. Loads of simulation tools seem to have them, so clearly they should be available somewhere?
Anyone knows how this work?
Hi,
You don't need a subscription for the sectional appendix. You can just download them on the Network Rail website.
DelW
15 Jan 2015
As well as online sources, there are physical atlases of track diagrams available from Trackmaps, including the detailed regional ones originally published under the Quail name.
I find them very useful, and often more convenient than maps on screen.
TRACKmaps publishes books and maps that provide in-depth insights into the UK’s current rail infrastructure, serving both Rail Industry professionals and railway enthusiasts. Known for its popular and highly regarded Quail Track Diagram series, TRACKmaps offers comprehensive details on Britain’s rail network. Additionally, TRACKmaps provides custom rail mapping services to industry clients and contributes editorial expertise to the TRACKatlas, published by Platform 5 Publishing.
Hi,
If you’ve been to the NESA page they don’t make it immediately obvious that you need to scroll right down to the bottom of the page. The pdfs aren’t updated in real time, but they’re amended quickly enough for most purposes. Another point is that it’s the date in the top right hand corner of each page that’s the important one, the one at the bottom left doesn’t seem to change unless the whole ‘book’ is reissued.
drmvy
19 Mar 2026
Exeter
Oh I did not realise, I got roped into their initial bit about subscribing and did not see further.
I've now looked at the sectional appendices, they do have a plethora of maps and diagrams. I still do not find any that shows track diagram including signalling equipment, like the one found in the above mentioned thread.
I'll have a closer look at trackmaps to see if they would have this level of detail.
You won't find signalling diagrams if thats what you are after.
WTT Gremlin
1 Apr 2025
Northampton
Your best chance to try and get those would be to ask (FOI) Network Rail. I don't know of 'official' sets that are in public domain.
drmvy
19 Mar 2026
Exeter
That's a shame, such documents seems to exist, but so hard to find.
I've Google a bit around FOI and found https://www.whatdotheyknow.com/requ...e/2393135/attach/html/3/FOI202301002.pdf.html
It clearly state that (in there case) it could amount to very high cost to get those documents. Though I'm surprise if there wouldn't be a central document that collects all this information for a given region. But I might be too optimistic.
I assume some of the signalling info could be found in the open data feed, as Western Sunset says, traksy and open train times have this information. So I might try to dig on that front, but it will definitely be time consuming,
Freightmaster
Verified Rep
7 Jul 2009
Out of curiosity, what is your use case for this data?
If it helps, I develop my own 'realtime maps' similar to OTT and Traksy and whenever I am
unsure about the precise location and numbering of specific signals, my go to source of info
are the numerous 'drivers eye view' videos on Youtube, believe it or not!
MARK
drmvy
19 Mar 2026
Exeter
No specific use case at the moment, it's mostly sheer curiosity and rabbit holery. Though I do want to work of my own simulator as a pet project (part for my own knowledge and teach myself some UI skills, and also be able to add my own algorithm into them), so I was looking for good sources
Oh, I did not even know something like this exist, I'll have to check it out!
Freightmaster
Verified Rep
7 Jul 2009
Here are a few that I use:
...and a playlist which contains many others:
MARK
