TPExpress Man - Scotland
xtradj
24 Jul 2006
Can anyone advise whether the tpexpress services from Manchester airport to Glasgow and Edinburgh will eventually call at Victoria?
If they do will they still call at Piccadilly?
Are they also due to go via Bolton rather than Wigan once Electrification is complete? Thanks
Muzer
3 Feb 2012
Correct me if I'm wrong, but I don't believe it is proposed for these services to call at Victoria. They would have to do quite a roundabout route to do so.
I believe it is just the East-to-West routes themselves for which this is proposed.
xtradj
24 Jul 2006
Not all east to west though
South TP is still Piccadilly isn’t it?
As is North (Hull will still be Pic and Scarborough will be Pic) with Liverpool to Middlesbrough and Liverpool to Newcastle being via Victoria
As I believe the Middlesbrough services will continue to Liverpool and swop with the Scarborough services which will now only go as far as Manchester?
Muzer
3 Feb 2012
I thought the South TransPennine ones were being altered, as currently they have to cross the entire layout at Piccadilly, and they wanted to avoid this (because it's a stupid thing to do for capacity and for delay recovery purposes). It'll call at Piccadilly AND Victoria. Or am I getting confused with another service?
As for the rest of them, I'm not sure.
xtradj
24 Jul 2006
Ah I was unaware the South TP were being changed also. It’s probably all on here somewhere I’ve just not seen it.
Muzer
3 Feb 2012
Ah, actually I think I'm really confused. You're possibly right about South TP; for some reason I'd completely forgotten they go via Stockport!
I feel like they'll want to do this with as many North TP services as practical, though, to avoid the aforementioned crossing over at Piccadilly.
xtradj
24 Jul 2006
I’m sure It’s only two of the five North ones which will go via Victoria (both from Liverpool) hopefully someone will clarify for us ha!
xtradj
24 Jul 2006
Cheers pal so it looks like Scarborough is staying with Liverpool, and Middlesbrough is staying with Manchester
One thing I’ve noticed on that map is the light blue line Manchester to Middlesbrough seems to dissapear between Leeds and York suggesting a split service? Surely an error?
Muzer
3 Feb 2012
It's possible this was changed since the map was made (May 2016), or perhaps it's an error. Looking at the times currently in RTT, in any case, it looks like the 4tph York to Leeds come from Newcastle (*2), Scarborough and Middlesborough, as of the next timetable change (the Edinburgh extension isn't due to happen yet).
1 Feb 2018
A bit off topic but for some reason the class 397 thread is all locked up. Does anyone know why tpe have only ordered 12 class 397’s? That’s nowhere near going to be enough to cover all Liverpool and Manchester-Scotland diagrams. The 10 class 350’s aren’t enough at the moment just doing Manchester to Scotland. Are they going to still use 185s to Scotland? Or use bi modes or mk5 sets? Would seem such a waste of a bi mode or a diesel to be running them fully under the wires. Why not order enough 397’s? Seems very odd to me.
xtradj
24 Jul 2006
I’d be wary of taking the map as gospel if 2016
I’m sure there was a possibility of Liverpool to Scarborough becoming Manchester to Scarborough
And Manchester to Middlesbrough becoming Liverpool to Middlesbrough although I am unaware which was finalised of or in fact it is yet to be.
MontyP
18 Nov 2015
If the map is correct, services to Newcastle are extended to Edinburgh - is this correct? When was the last time that Liverpool to Edinburgh services ran via Leeds/York? I vaguely remember that this happened in the loco-hauled days of the 1980s but might be mistaken!
Muzer
3 Feb 2012
TPE themselves say that services currently terminating at Newcastle will be extended to Edinburgh (presumably only some of them) in December 2019.
Mathew S
7 Aug 2017
No plans for them to switch to Victoria.
Yes the plan is for them to switch to Bolton rather than Wigan once electrification is complete (effectively a swap with the Northern services to Barrow/Windermere which will switch to going via Wigan).
Should be an hourly service eventually half the services? As that announcement does say Morpeth will have hourly services to Edinburgh, amongst other places...
It has happened fairly recently when the WCML was pretty much closed for engineering work (eg bank holidays).
On at least one occasion they even ran via Sheffield to reach the ECML.
I'm not sure the hourly TP electric paths (for 802s) north of Newcastle are yet approved by NR because of power supply issues.
WatcherZero
25 Feb 2010
For clarity
Class 68 and mk5 will operate Liverpool-Newcastle via Newcastle
Class 397 will operate Manchester Airport-Edinburgh/Glasgow (singly) and the Liverpool-Glasgow via Preston service (Likely 1 train diagrammed for 3 return trips per day)
driver9000
13 Jan 2008
For clarity
The 68s won't be going to Newcastle.
YorkshireBear
23 Jul 2010
Why aren’t the 185s staying on Liverpool to Newcastle??
Because they have bought 125mph IEPs for that service.
Stock plan for TPE North is
Class 185s on the Hull-Picc and Leeds - Pic Service.
Class 68s and Mk5s on the Scarbrough - Victoria - Liverpool and the Middlsborough - Victoria - Oxford Road - Piccadilly - Airport
IEPs (Class 802s) on the (Edinburgh eventually) - Newcastle - Victoria - Liverpool and the Newcastle - Victoria - Oxford Road - Piccadilly - Airport.
Then the class 397s on the North West to Scotland services and the 185s on TPE south from Cleethorpes to the Airport.
xtradj
24 Jul 2006
Where do the spare 185s go?
The IEPs can only do 125mph between York and Newcastle I’m guessing? Or can they between Liverpool and Victoria also?
Mathew S
7 Aug 2017
Elsewhere, more than likely. Several possibilities have been mentioned in various places on here, including the future Wales & Borders franchise, and Northern, amongst others.
xtradj
24 Jul 2006
Ah so still undecided
Both companies mentioned (more so wales) could do with some more modern stock
YorkshireBear
23 Jul 2010
There have been plenty of rumours but nothing at all confirmed. If I was a betting man I would look towards Wales. But Northern and even TPE keeping more than currently planned (to ensure 6 car formations permanently between Hull/Leeds and Piccadilly and Sheffield - Manchester Airport) have both been mentioned.
YorkshireBear
23 Jul 2010
Yes they can only do 125mph on that stretch but they will also be going up to Edinburgh where there is more 125mph running avaliable. So on the Liverpool - Edinburgh via Newcastle route York to Edinburgh is a big proportion of the route.
Philip
27 May 2007
Manchester
I can't see all of the semi-fast/stopping services on the North TPE being formed of 6-coach trains. I suspect there'll be at least one diagram which runs in single formation all day, logically the one which avoid peak time hotspots the most. First priority for doubling up formations will be for the Manchester-Sheffield section, then whatever is left for the rest. I suspect some 185s may still be needed to boost the capacity on Fri-Sat-Sun Scotland services too.
Bovverboy
1 Dec 2013
A few extra journeys have been added to the TPE Scottish services in recent months, but as far as I'm aware the scheduled turnout for 350s is still eight units on Tuesdays to Thursdays and nine on Fridays to Mondays. Assuming that a double 397 will replace a double 350, a single 397 will replace a single 350 or a single or double 185, there will (at any one time) be one unit operating Liverpool - Scotland, and there will always be at least one unit not scheduled for service (as now, with the 350s) then I would expect the 397 turnout to be nine units Tuesdays and Wednesdays, nine/ten units Thursdays, ten units Mondays, and ten/eleven units Fridays to Sundays. There would be no more than one remaining 185 duty, and, even then, probably only on a Sunday.
In the circumstances I think that twelve 397s is the most which could realistically be ordered at this stage.
