TPE services allocated for Double units
plugwash
29 May 2015
So this one - the 0808 departure from Sheffield - was indeed a double 185.
However, there was confusion about what would happen at Manchester Piccadilly. (AIUI the train has to split at Piccadilly as there isn't the platform space at Manchester Airport for a full 6 car set at that point). The announcement at Sheffield was that the front 3 coaches would continue to Manchester Airport while the rear 3 coaches would terminate at Manchester Piccadilly, and this was backed up by the seat reservations being on the front set. But the conductor on the back set (where I was - it was pretty lightly loaded, which was lovely, though I suspect the front set was much busier!) was saying that in fact the rear set would continue to the Airport and the front set would terminate at Piccadilly. I didn't hang around to see what actually happened but if that's right, and nothing changes, there's going to be a lot of confused and frustrated passengers wanting the Airport but ending up in the wrong half of the train.
The service reverses at Piccadilly, so the front of the train going into Piccadilly will become the rear of the train (or the bit left behind if they do a split) when it heads out to the airport. I would guess someone or some computer system did not take account of this leading to the confusion.
Jamesrob637
12 Aug 2016
Nothing on Journey Check today so far. Hopefully all runs smoothly despite no 802s out today.
Jamesrob637
12 Aug 2016
Slightly late on the update but I can confirm that the 06:26 Cleethorpes to Airport was only 3-car this morning and nothing on Journey Check.
yrreb
6 Aug 2016
Manchester
I believe it's subject to whether there's Class 802s out in service, in which case we should find out for sure very soon
Killingworth
30 May 2018
Sheffield
After the excited anticipation of more twin 185s on South Pennine it's gone a bit flat.
On Monday the 8.11 from Sheffield was indeed 6 coaches - but the 7.11 had been sent out as 3, so more pain for the busier early service for the relief later. Situation normal since, 6 cars on the 7.11 and 3 on the 8.11.
Jamesrob637
12 Aug 2016
Talk about robbing Peter to pay Paul! My shifts won't allow me to see the 08:11 from Sheffield until at least next Wednesday but I'm optimistic about TPE sorting everything out between now and then!
Jamesrob637
12 Aug 2016
06:26 Cleethorpes to Airport only 3-car today and nothing on Journey Check.
Jamesrob637
12 Aug 2016
Both morning services to Manchester Airport are 3-car today but at least there's something on Journey Check.
Killingworth
30 May 2018
Sheffield
Good to see they're supposed to be 6, but not much consolation for the sardines aboard only 3. TPE have been promising 6 for at least 2 years and it's amazing that so many still make the journey every day.
The obvious answer for many is to relocate and that's what some are doing, crowded trains being the final straw.
Failed Unit
26 Jan 2009
Central Belt
Are EMT as bad at that time? 4 car 158 has more capacity I understand then a 6 car 185 (seating in standard)
naverag
10 Dec 2018
JourneyCheck also reporting that the 1553 Manchester Airport - Cleethorpes and the 1753 Manchester Airport - Cleethorpes will be 3 coaches instead of 6, despite the fact that AFAIK neither of them has ever been 6 coaches.
BHXDMT
18 Feb 2011
England
The 15:53 should be 6 between Piccadilly and Cleethorpes as of last week (but no spare units of course), and I assume the 1753 has been entered incorrectly by Control as the 1653 is not listed on Journey Check and that is supposed to be 6.
Jamesrob637
12 Aug 2016
And on a side note one of the Anglo-Scottish services is 3 vice 4. Either a 185 or a 350 with one coach out of service.
Jozhua
6 Jan 2019
Only two diagrammed 802's on a daily basis and MK5A's are out of service yet again, so really not suprised if 3-car formations will continue to be the norm for a while. My guess is by about February/March next year we'll see 6-car formations on most services.
I used to do the journey quite a lot back to my old town from Manchester across the pennines but it's just not really worth it anymore. It's just ridiculously overpriced, uncomfortable and often delayed. The amount of stress for just a weekend is too much!
Why would they take the 4th coach out of service? Is it broken or purely out of spite for passengers?
hooky3
10 Nov 2010
there was a 185 on the 16:12 from Edinburgh but it seems to have been swapped for a 350 again in Manchester for the 20:26 back.
Killingworth
30 May 2018
Sheffield
Jamesrob637
12 Aug 2016
Yet again the 06:26 Cleethorpes to Airport is 3-car and nothing on Journey Check. Has it actually been 6 since 21/10? The three or four times I've seen it, it's been only 3.
Killingworth
30 May 2018
Sheffield
Given that train has been 6 car for a couple of years, in theory, it is particularly disappointing that it's been cut, although recent observation at Dore suggests the Friday load is half that on Mondays. Word on the platform suggests that's because it was regularly turned out with 3 cars on Fridays so commuters planned to work from home on that day. Chicken and egg, they've helped create a 4 day demand. It was 6 cars last Friday.
Jamesrob637
12 Aug 2016
I've managed to evade that issue by working either very locally or from home since December 2017 which is incidentally when all these issues started to occur. The only reason I can give live updates on some services is by my walking/jogging route being near the tracks at Stockport!
Killingworth
30 May 2018
Sheffield
Apparently the latest reason is all Nova 3 trains being withdrawn until a software issue is resolved. That requires development, testing and validation by CAF and they'll be back "shortly". Shortly is a technical term to mean God only knows when! We can but hope it's only a few days, more likely weeks, and not months.
Jamesrob637
12 Aug 2016
Seeing as nova means "no go" in Spanish and Italian it seems appropriate at the moment!
CHAPS2034
13 Mar 2018
Reported on another thread that the Nova 3s will be back in service on Monday, so we'll see what happens.
Jamesrob637
12 Aug 2016
The 5 o'clock Cleethorpes to Airport is 3-car but noted on Journey Check. Who knows how the hour later one will be?! Case of robbing Peter to pay Paul?
LittleAH
24 Oct 2018
They are now back in service. So shortly did mean shortly.
68001
9 Jan 2019
Noticed habrough is to retain a full hourly servive to manchester airport from the start of the winter time table
OrangeJuice
4 Jun 2018
Does that mean they've got those ASDO (Automatic Selective Door Opening) beacons working that are currently in the 4 foot?
BHXDMT
18 Feb 2011
England
Hopefully that may allow early redeployment of some 185's to other routes, particularly South Pennine, very shortly - like tomorrow!
Unlikely as there are currently no 6 car services scheduled back to Cleethorpes this evening, which means no 6 cars tomorrow morning.
CASDO should be in use from early December, currently an additional Conductor assists if a scheduled 6 car calls there.
