TPE Nova 3 (Class 68 + Mk5s) updates and withdrawal from service
170UTD
14 Mar 2022
Lincolnshire
So I know that it's probably too early to tell, but I'll ask anyway, does anyone know if 1U47 definitely won't be a 68 on Thursday 9th (e.g the driver no longer signs them?) Thinking of doing Leeds to Scarborough for a last bash and there's no point of it's going to be a 185. Thanks in advance.
Peter Sarf
Croydon
From my records it looks like 1U47 has run nearly every day in the last couple of weeks as Mk5s. It is one of two diagrams that start from Manchester and seems to be the favoured one of the two. It starts at Longsight doing :-
5U23 to Manchester Piccadilly
1U23 to Scarborough
1U36 to Manchester Piccadilly
1U47 to Scarborough
1U60 to Manchester Piccadilly
1U71 to scarborough
5U71 to Scarborough Depot.
There is a lot of risk because it relies heavily on crew who sign 68s+Mk5s across the Pennines so a 185 might take over.
You will find the Scarborough-York stretch less likely to have crew problems so a diagram spending more of the day there is less likely to end up 185 on the day.
Also the sets do sometimes get swapped mid diagram with another set - that wont bother you.
170UTD
14 Mar 2022
Lincolnshire
1U23 to Scarborough
1U47 to Scarborough
1U71 to scarborough
That's what I thought already. I have next week as well to go to York and wait for one if things go wrong on Thursday.
68011
8 Oct 2016
Tuesday 7th November 2023
LO601
68026/TP05
1U29 06.27 MAN - YRK
5U29 08.24 YRK - SCA then onto LO605
68029/TP12
5U64 15:30 SCA TMD - SCA
1U64 15.48 SCA - YRK
1U67 18.03 YRK - SCA then onto LO602
68024/TP04
5U78 20.23 SCA - YRK
1U83 22.03 YRK - SCA
LO602
68024/TP04
1U28 06.48 SCA - MAN
1U39 09.35 MAN - SCA
1U52 12.48 SCA - MAN
1U63 15.35 MAN - SCA
5U63 18:06 SCA - SCA TMD
5K42 19:56 SCA TMD - SCA then onto LO601
68029/TP12
1K42 20.43 SCA - MCV
LO603
68023/TP09
1U23 05.35 MAN - SCA
1U36 08.45 SCA - MAN
1U47 11.35 MAN - SCA
1U60 14.48 SCA - MAN
1U71 17.30 MAN - SCA
5U71 22.30 SCA - SCA TMD
LO604
68021/TP10
1U72 17.48 SCA - LDS (via Castleford)
1U75 19.34 LDS - SCA
1U88 21.48 SCA - YRK
1U87 23.03 YRK - SCA
LO605
68029/TP12
1U24 05.46 SCA - LDS
1U27 07.19 LDS - SCA (via Castleford)
5U29 09:25 SCA - SCA TMD for fuel then onto LO601
Not allocated as of 09:30 but confirmed as being
68026/TP05
1U40 09.48 SCA - YRK
1U43 12.03 YRK - SCA
1U56 13.48 SCA - YRK
1U59 16.04 YRK - SCA
1U80 19.48 SCA - MAN
87electric
27 Jan 2010
LO601
68026/TP05
68029/TP04
68024/TP12
LO602
68024/TP12
68029/TP04
LO603
68023/TP09
LO604
68021/TP10
LO605
68029/TP04
Not allocated as of 09:30 but should be
68026/TP05
Is this correct that 68029 is with TP04 today? RTT has 024 with TP04. I’m planning my photo opportunities for the day.
Peter Sarf
Croydon
LO601
68026/TP05
68029/TP12
68024/TP04
LO602
68024/TP04
68029/TP12
LO603
68023/TP09
LO604
68021/TP10
LO605
68029/TP12
68026/TP05
Thanks for researching and posting. I notice the sets are swapping diagrams during the day quite a bit. I also notice all five diagrams are in use !.
Plenty of opportunities for a last bash of them before the cold hand of the Winter time table comes down.
68011
8 Oct 2016
Wednesday 8th November 2023
LO601
68029/TP12
LO602
68024/TP04
LO603
68028/TP07
1U47 11.35 MAN - SCA then onto LO604
68021/TP10
LO604
68028/TP07
LO605
68029/TP12
68025/TP02 5N32 12:02 Scarborough TMD to Longsight TMD
https://www.realtimetrains.co.uk/.../2023-11-08/detailed
68032 0B42 09:19 Crewe GB to Crewe South Yard
68032/TP03 5Q32 11:10 Crewe South Yard to Longsight TMD
Peter Sarf
Croydon
LO601
68029/TP12
LO602
68024/TP04
LO603
68028/TP07
68021/TP10
LO604
68028/TP07
LO605
68029/TP12
Thanks for your info.
I notice LO603 has again swapped sets midday !. I think, from memory, it is not totally unusual !. I wonder if there is a common factor that makes this predictable ?.
Jamesrob637
12 Aug 2016
A 68 left Manchester last night at 17:30 so there was at least one out over the Pennines yesterday.
Jamesrob637
12 Aug 2016
Yesterdays workings were posted above in post 2105. As you can see there were multiple cross-pennine trains.
You and I both know TPE, and especially the 68s, are to be taken with a massive pinch of Saxo.
Peter Sarf
Croydon
I have in the past been checking RTT at the end of the day or the next day. There can be variance but generally what is planned in the morning to run day-by-day does actually run. That has been three or four sets out every weekday that have ACTUALLY run. Very recently looks like all five potential diagrams have been covered by 68s+Mk5s but I have not been checking this week too thoroughly. Remarkably healthy given the headwind against them and the shortage of qualified crew East of Leeds.
sjpowermac
26 May 2018
The diagrams yesterday were placed there by a highly reliable poster.
To confirm, all five Class 68/Mk5A diagrams ran yesterday, with all of the booked passenger workings covered.
The one you saw at Piccadilly was 68023/TP09.
Hope that helps:)
Peter Sarf
Croydon
Hope that helps:)
Indeed from my checking of what is actually running it seems the information is fairly reliable. Things do change during the day but not so that less runs, more likely some swaps amongst what is out on the day. Just recently Longsight seem to be putting more out. So good that it is hard to believe the 68s+Mk5s are supposed to be retired in December.
Peter Mugridge
8 Apr 2010
Oakham
The timings between the retreat into the depot and it re-emerging suggest fuelling?
68011
8 Oct 2016
There could be changes as the Up Huddersfield line is currently blocked in the Dewsbury area due to an earth slip so anything towards Manchester has to run via Wakefield Kirkgate ex Leeds subject to train crew knowledge.
1U36 08:45 SCA-MAN got as far as Signal L3625 just past Leeds West Jn before returning to Leeds station Platform 15 then left again running via Wakefield Kirkgate eventually arriving into MAN at 12:06hrs 64 minutes late, the return 1U47 11:35 MAN-SCA departed MAN at 12:18 43 minutes late.
Update 13:30 - 1U47 terminating at York then ECS 5U47 to SCA
Update 14:40 - 1U60 14:48 SCA-MAN cancelled throughout
Jamesrob637
12 Aug 2016
Hope that helps:)
Thanks. It was LOUD. I was in a double-glazed Virgin train and I could hear the thing even above the hubble and bubble of fellow passengers, several platforms away.
68011
8 Oct 2016
The reason for the swaps today is so that 68021 ends up on the depot tonight has it requires fuel, it couldn't get on the depot earlier has it would have blocked 68025/TP02 from being able to exit.
Peter Sarf
Croydon
Thanks for that, I saw TP02 was ECS back to Longsight. Must not forget that Scarborough is a one (long) road deport just for light servicing.
68011
8 Oct 2016
68021/TP10 now working LO604.
After 22:20hrs this evening the route through Dewsbury is blocked until tomorrow morning due to a landslip, the Down line towards Leeds will be open tomorrow however the Up line towards Huddersfield is expected to remain shut until Monday morning, obviously things can change at anytime.
TPE services towards Manchester will be diverting via Wakefield Kirkgate so it remains to be seen if any 68’s will be out across the Pennines, plenty of delays today so it’s very likely the same for the next few days.
170UTD
14 Mar 2022
Lincolnshire
edit 19:25hrs - 68's are only planned to be in use SCA-YRK-SCA tomorrow.
Typical. When I'm booked on 1U47 tomorrow. Oh well. It can't be helped. The main thing is that the trains keep running.
Looks like all services from Scarborough are only running to York tomorrow, apart from a few to Leeds.
8 Oct 2016
61653 HTAFC
18 Dec 2012
With regard to this landslip near Dewsbury, is there a thread discussing this issue, even as part of other weather-related disruption? Had a quick search but couldn't find anything.
Where exactly is the location of the slip? I did notice a MK5a set crossing Batley viaduct westbound on Tuesday evening around 5pm. I didn't get a good look as I was driving, but it was moving at a very slow speed. Would this have been related to the landslip?
Freightmaster
Verified Rep
7 Jul 2009
Here you go:
MARK
68011
8 Oct 2016
Thursday 9th November
Amended diagrams due to the landslip in the Dewsbury area
Allocations are subject to change
68021/TP10
5U29 09:25 SCA-SCA TMD
5U72 17:30 SCA TMD-SCA
1U72 17:48 SCA-LDS
1U75 19:34 LDS-SCA
5U71 22:30 SCA-SCA TMD
68028/TP07
1U28 06:48 SCA-YRK
1U31 09:03 YRK-SCA
1U48 11:48 SCA-YRK
1U47 13:03 YRK-SCA
1U60 14:48 SCA-YRK
1U63 17:03 YRK-SCA
1U88 21:48 SCA-YRK
1U87 23:03 YRK-SCA
68029/TP12
1U24 05:48 SCA-LDS
1U27 07:20 LDS-SCA
1U40 09:48 SCA-YRK
1U43 12:03 YRK-SCA
1U56 13:48 SCA-YRK
1U59 16:04 YRK-SCA
5U63 18:06 SCA-SCA TMD
5K42 19:56 SCA TMD-SCA
1K42 20:43 SCA-YRK
1U83 22:03 YRK-SCA
68032/TP03
1U29 06:27 MAN-YRK
5U29 08:24 YRK-SCA
1U64 15:48 SCA-YRK
1U67 18:03 YRK-SCA
1U80 19:48 SCA-YRK
1U79 21:04 YRK-SCA (185 LDS-YRK)
61653 HTAFC
18 Dec 2012
Here you go:
MARK
Much appreciated, thanks- I was looking in the Infrastructure section only, like an idiot!
