Modern developments are fine but it must be remembered that some 80 years went into finding tried and trusted methods by the old groups, if it 'aint broke....don't fix it !!
Not sure how these new stays are constructed because no one has really stuck a drawing up to see. Anyway to basics, lets assume firebox is some 100 ft sq (10 ft x 10ft) and boiler press = 180 psi......so thats 100 x 144 x 180 = 2 592 000 lb trying to compress just the firebox.....assume 259.2 stays just around fire box and thats 10 000lb by my guess per stay.
Now old method with copper firebox meant that the outer shell of steel boiler plate supported a "soft" copper fire box and being soft it would deflect while the steel wont. Therefore any stays that were a wee bit shorter than its counterparts would take the load initially and the surrounding copper gives a wee bit until all load is distributed evenly to all stays and all stays are eventually roughly loaded the same due to the give in the copper. Im talking only a few thou here chaps, its very difficult to load all stays up evenly even using Crewe/Swindon/Doncaster practices with external nuts top & bottom and just stays run through inner/outer without any mis-alignment during running-in. Anyway if we now have a steel firebox & shell, all welded and totally rigid, there is no "give" in 'owt.....those colossal forces are still present and we have hollow stays (Monel I assume)....we have vibration...we have expansion & contraction.....but no give in anything. Therefore our "short" stays takes a huge force until it stretches a wee bit and allows its counterparts to receive some load until it too stretches and puts a bit of load back onto previous stay....but its probably gone past its yield point and the damage is done.
Cut&paste aka Wiki;
Compared to steel, Monel is very difficult to machine as it work-hardens very quickly. It needs to be turned and worked at slow speeds and low feed rates. It is resistant to corrosion and acids, and some alloys can withstand a fire in pure oxygen. It is commonly used in applications with highly corrosive conditions. Small additions of aluminium and titanium form an alloy (K-500) with the same corrosion resistance but with much greater strength due to gamma prime formation on aging. Monel is typically much more expensive than stainless steel.
Monel alloy 400 has a specific gravity of 8.83, an electrical conductivity of approximately 3.4% IACS, and (in the annealed state) a hardness of 65 Rockwell B.[3]
Hollow stays I would assume are beefed-up a wee bit due to loss of CSA from drilling but Im clueless as to how much and what thread form they use. Old 'uns typically BSW while DB must doubtless use metric (see different angle of thread & raduised root )...anyway Im rambling now...!!!
Point is gents, those boilers are not just bits a steel & stuff, some 80 + years development went into them. Sure we have steel fireboxes in all US locos, Bullied locos and almost all Beyer Garratts and they worked...sort of. But dont abandon old tried & tested methods.....the Kings new clothes....etc etc.
If Im talking bull, please correct my ignorance....
