TOPS Requests (including headcodes, allocations, traction, etc) [Instructions in Post 2]
LA50041
20 Feb 2017
Hello, does anyone know what worked the following for the dates specified
15/03 - 5V94 1313 Shields T.M.D. (E) to Yoker C.S.
26/03 - 1E97 1613 Glasgow Central to Carlisle
26/03 - 2P09 0820 Newton to Glasgow Central
26/03 - 5V82 1032 Yoker C.S. to Shields T.M.D. (E)
26/03 - 5Y00 1145 Shields T.M.D. (E) to Yoker C.S.
Thanks
15/03 - 5V94 318252
26/03 - 1E97 156433
26/03 - 2P09 320417
26/03 - 5V82 Nothing Allocated
26/03 - 5Y00 Nothing Allocated
TimboM
12 Apr 2016
I think it was 87002. Where is the 56?
87002 is at Willesden TMD currently; 86101 is also there though - unless you got a decent look at it (especially whether it had two windscreens or three) they're not easy to tell apart. Of the two, I'd say 87002 is more likely to be inside the shed at the moment.
The 56(303) is allegedly in the Wembley Loco Holding Sidings (just along from Willesden TMD).
Toad2017
10 Oct 2017
Isleworth
Thanks mate
6Gman
1 May 2012
Can anyone id the Pendolinos on the following today?
1247 Lime St - Euston
1m16 1540 Glasgow - Euston
9S85 1543 Euston - Glasgow
1S87 1657 Euston - Glasgow
1607 Euston - Lime St
1707 Euston - Lime St
TIA
6Gman
1 May 2012
What was the 156 on the 1755 Liverpool - Norwich today?
I thought it was 409, but since that is a Crown Point unit I suspect it was 408!
6Gman
1 May 2012
And finally ... some freight.
What are the two 08s at Speke? One is lettered GBRf 4 but what is its "proper" BR number?
Also what is the 66/7 parked inside with them today?
The 66/7 on biomass at Edge Hill around 1800 in "Aggregate" livery? 66711?
And finally, finally 66788 was at Edge Hill this afternoon on a rake of VTG wagons (34xx and 35xx numbers). Are these wagons for carrying scrap metals? If so, what's the flow?
Many thanks.
chrisncal54
9 Mar 2016
Garsdale Head
Many thanks.
Some answers:
08818 (GbRF) and 08502
6L48 66763 left at 14:55
66711 is the only one in that livery!
GrahamD83
5 Mar 2018
Could anyone please ID the loco hauling 4N70 this evening (27/03/18) from Drax Aes at 1754 to Tyne Coal Terminal at 2135 please? It was a Colas Class 70 (Its normally a GBRf 66)
Trust ID from RTT is 174N70CV27 if its any help.
Thanks
TimboM
12 Apr 2016
Some answers:
66724 was also at Garston this evening as the Tuesday-only extra 6X43 car train ran today. It arrived at 16:55, so depending on when you saw the 66/7 it was either 763 as per @chrisncal54 's info, or it was 724. 763 is also "old" GBRf/Europorte livery with the red/blue roundels whereas 724 is the newer version with the 'squared-off' ends.
And, yes, 66788 has been working scrap metal trains. There's one flow from EMR Swindon to take scrap metal to Liverpool docks for export, plus flows from Marple and Gillot, Attercliffe (nr Sheffield) and at least one other one from Stalybridge I believe.
TimboM
12 Apr 2016
Thanks
70814
It's being loaned to GBRf for 'evaluation' purposes (so was still a GBRf flow). It'll be on the Tyne Dock/Drax flows all week.
6Gman
1 May 2012
It was there at 13.00 so too early for 66724.
Many thanks for all the info.
sd0733
7 Nov 2012
I was on that so it was definitely 156408 the lead 156.
LA50041
20 Feb 2017
1247 Lime St - Euston 390126
1m16 1540 Glasgow - Euston 390040
9S85 1543 Euston - Glasgow 390047
1S87 1657 Euston - Glasgow 390141
1607 Euston - Lime St 390039
1707 Euston - Lime St 390008
TIA
see above
Triumph
5 Dec 2011
Good morning
Could anyone help with the following today please:
1M91 0615 EDB-MIA
1S39 0716 BHM-GLC
1S42 0730 EUS-GLC
1H18 1020 EUS-MAN
1B32 1030 BHM-EUS
Many thanks
LA50041
20 Feb 2017
Good morning
1M91 0615 EDB-MIA
1S39 0716 BHM-GLC
1S42 0730 EUS-GLC
1H18 1020 EUS-MAN
1B32 1030 BHM-EUS
Many thanks
1M91 350410
1S39 390010
1S42 390016
1H18 390039
1B32 390020
