TOPS Requests (including headcodes, allocations, traction, etc) [Instructions in Post 2]
Freightmaster
Verified Rep
7 Jul 2009
Real Headcode was 6T44, Stobart Operated tamper machine...
Stobart have their fingers in quite a few pies, but they don't operate OTP (yet!)
SB Rail is Swietelsky Babcock
...unforunately I dont have a number.
DR73915 William Arrol:
D.K.TAYLOR
28 Apr 2014
WCR charter to Portsmouth 12/10/16 1Z76 any quotes on traction please cheers
trainmania100
8 Nov 2015
Newhaven
Hi all
Anyone able to identify the following for me please. I was sat in the waiting room at Skipton and a unit was blocking it so I couldn't see. Thanks!
http://www.realtimetrains.co.uk/train/U31761/2016/10/10/advanced
Anthony
VOLKER rail DR73946 headcode 6J74
Wcr class 47\57 we won't know until the night before at earliest ;)
59102 which then failed at Lewes
One from Saturday please anyone, 1A29 Bristol TM to Paddington 43179 on front, which one was on their back? thanks in advance
Thank you. Another loco rescued it which was also a 59/1. Which took it from Lewes to new haven for runaround then did double head back to Acton.
I saw it leave Newhaven through the trees missing a good shot by seconds
postye
7 Feb 2013
59102 which then failed at lewes
one from saturday please anyone, 1a29 bristol tm to paddington 43179 on front, which one was on their back? Thanks in advance
43164
Curiousity has got the better of me today, I'd love to know which 166s I could have got if I had gone bashing today. So:
Anyone know which ones were on the 0821 London Paddington to Hereford today, 10th October 2016? I'm aware one is normally removed in Worcester.
166207 + 166212 with 207 continuing to Hereford
thanks for the 91, couldn't get a chance to get it when it rolled in at darlington as i was in coach m, and didn't fancy going against the crowd to spy it at kings cross.
Any idea on that lm 153? :)
153366
03_179
13 Aug 2008
At my desk
Little help if possible please:
Monday 10th October 2016.
Derby @13:00 the 1220 Derby R.T.C.(Network Rail) to Barrow Hill L.I.P. 37608, 37611. Can anyone supply the Train ID 0???
Derby RTC:
I have written down 37582 but there doesn't appear to be that number anyone got an idea what it could be please?
Also there is a 'Peak' stabled in the RTC area. Anyone know the number as it was obscured.
Also there is a cl.73 in a grey livery with the word LORAM on the side, what is its number.
Mountsorrel sidings @: 14:18 There was a Industrial Shunter there (along with 66475). Can anyone ID it please?
Leicester:
There are a number of class 56s there. Also I noted a couple of 37s and a Class 50 (?) in the yard Can anyone ID these please?
Thanks in advance.
AidanCroft
28 May 2014
Hello all,
Does anyone know if any of these 350s are out and which way they're going? 401, 408, 409, 410. That would be for today and tomorrow ideally although I presume tomorrow wouldn't be known until the day itself.
Kind regards,
Aidan.
Peter Mugridge
8 Apr 2010
Epsom
Hello all,
Kind regards,
Aidan.
Don't know if this helps you work it out, but 408 was the late evening arrival ( 21.37 ) at Edinburgh last night. That runs ecs to Craigentinny, so it was probably the first Edinburgh - Manchester this morning; you may be able to work it out from RTT where it should be now.
LordCreed
28 May 2014
Hello all,
Kind regards,
Aidan.
For today (11/10/2016):
Unit: 350401
Code:
No allocations
Unit: 350408
Code:
1M91 Edinbur MncirIAp
1S46 MncrIap Edinbur
1M99 Edinbur MncrIAp
1S83 MncrIAp Edinbur
5S83 Edinbur Crgntny
Unit: 350409
Code:
5S32 Ardwtmd MncrIAp
1S35 MncrIAp GlgC
1M96 GlgC MncrIAp
1S71 MncrIAp GlgC
5S71 GlgC CkhlCsd
Unit: 350410
Code:
5M93 Crgntny Edinbur
1M93 Edinbur MncrIAp
1S56 MncrIAp Edinbur
1M91 Edinbur MncrIAp
5W91 MncrIAp Ardwtmd
AidanCroft
28 May 2014
Unit: 350401
Code:
No allocations
Unit: 350408
Code:
Unit: 350409
Code:
1S35 MncrIAp GlgC
1M96 GlgC MncrIAp
1S71 MncrIAp GlgC
5S71 GlgC CkhlCsd
Unit: 350410
Code:
Cracking, thank you. Do you by any chance have the same for today?
LordCreed
28 May 2014
For today (12/10/2016):
Unit: 350401
Code:
1S32 MncrIAp Edinbur
1M95 Edinbur MncrIAp
1S66 MncrIAp Edinbur
5W93 MncrIAp Ardwtmd
Unit: 350408
Code:
Unit: 350409
Code:
5M90 CkhlCsd GlgC
1M90 GlgC MncrIAp
1S40 MncrIAp GlgC
1M98 GlgC MncrIAp
1S81 MncrIAp GlgC
5S81 GlgC CkhlCsd
Unit: 350410
Code:
No allocations found
DasLunatic
11 May 2015
Two things:
1) I saw a Network Rail test train in Colchester Goods Loop. What locos were on it, and where is it going?
2) 156415 has been leased to GA, according to ABRail. When does/did it return, and if it's still in Anglia, what services will it operate tomorrow (13/10)?
marky7890
7 Dec 2009
Nr Penryn, Cornwall
Any help with these for today please?
GWR
1C77 1006 London Paddington to Penzance
XC
1M41 1007 Paignton to Manchester Piccadilly
1S47 0828 Penzance to Glasgow Central
1S49 1125 Plymouth to Dundee
1M49 0935 Penzance to Manchester Piccadilly
1V47 0807 Manchester Piccadilly to Paignton
1V52 0601 Glasgow Central to Plymouth
As well as this from Tuesday (11th):
1E67 1625 Plymouth to Leeds
Thanks
trainmania100
8 Nov 2015
Newhaven
Two things:
37601 XHNC COLCHRREC COLCHRREC L N
37610 XHNC COLCHRREC COLCHRREC L N
Which terminated the 1Q89 Ferme Park - Colchester Recep line on Wednesday
And Initiated the 1Z01 Colchester to Derby this morning at 0038.
A number of test trains passed Colchester during the day. I can only assume those above were the ones you want as they were in the goods loop
Edit start
>>>THIS WAS 0Z37<<<
Derby RTC:
>>>I CAN ASSUME IT WAS 37682 XHSS DERBY RTC DERBY RTC F D <<<
no idea what peak is but it might be 45041 if thats a peak
Honestly not sure these are the NR locos on TOPS
08417 QADD DERBY RTC DERBY RTC L N 562H A
31105 QADD DERBY RTC DERBY RTC L B 5707H A
31233 QADD DERBY RTC DERBY RTC F N 1490H C
73138 QADD DERBY RTC DERBY RTC F N 3933H A
73951 QADD WEYMOUTH WEYMOUTH F N 22H A
73952 QADD DERBY RTC DERBY RTC F N 55H A
86901 QACL DERBY RTC RHAM GBRF F B -22H A
86902 QACL DERBY RTC RHAM GBRF F B 44H A
73107 GBED TONBGES13 TONB11&12 N 14D A
73109 GBED TONB11&12 TONB11&12 F N 16D A
73119 GBED TONB11&12 893W90C311 D * TONB11&12 N 18D A
73128 GBED TONB11&12 TONB11&12 F N 11D A
73134 GBBR BURTON WS BURTON WS F B -1H A
73136 GBED EASTLGHYD ELGHARLTN X 27D A
73141 GBED TONB11&12 TONB11&12 F N 26D A
73201 GBED EASTLGHYD ELGHARLTN X 4D A
73212 GBED TONB11&12 TONB11&12 D N 14D A
73213 GBED TONB11&12 893W90C311 D * TONB11&12 N 20D A
73961 GBNR LOUGBO HS LOUGBO HS F X 26D A
73962 GBNR TONB11&12 TONB11&12 L N 20D A
73963 GBNR TONB11&12 TONB11&12 L N 18D A
73964 GBNR STLNGBR STLNGBR F X 8D A
73965 GBNR STLNGBR STLNGBR F X 26D A
73966 GBCS EDINBURGH 041Y11M411 X * FTWILIAM N 26D A
73967 GBCS INVERNESS 015S25ME11 E * INVERNESS N 17D A
73968 GBCS ABERDEEN 025A25MC11 E * ABDN CLAY N 12D A
73969 GBCS EDINBURGH CRAIGNTNY F X 11D A
73970 GBCS CRAIGNTNY CRAIGNTNY F X 30D A
73971 GBCS STLNGBR LOUGBO HS W 16D A
Cant get industrials
Leicester:
Can only find:
56105 COFS LESTER SD LESTER SD F X
37905 UKRM LESTER SD LESTER SD E B 1H A
37906 UKRM LESTER SD LESTER SD F B -43H A
56007 UKRS LESTER SD LESTER SD F B -8H A
56018 UKRS LESTER SD LESTER SD D 98H A
56031 UKRS LESTER SD LESTER SD F B -1H A
56032 UKRS LESTER SD LESTER SD F B 0H A
56038 UKRS LESTER SD LESTER SD D B 0H A
56065 UKRS LESTER SD LESTER SD D T 96H A
56069 UKRS LESTER SD LESTER SD F B -1H A
56081 UKRL LESTER SD LESTER SD F N 71H A
56098 UKRL LESTER SD LESTER SD E N 33H A
56104 UKRL LESTER SD LESTER SD F N 57H A
56106 UKRS LESTER SD LESTER SD D B -1H A
56301 UKRL LESTER SD LESTER SD F N 56H A
58016 UKRS LESTER SD LESTER SD T 1H A
37503 EPUK LESTER SD LESTER SD C B 2D A
37510 EPUK LESTER SD LESTER SD F T 33H
37670 EPUK LESTER SD LESTER SD B 1H A
37800 GROG LESTER SD LESTER SD F N 36H A
47843 GROG LESTER SD LESTER SD F D 48H A
47847 GROG LESTER SD LESTER SD F X 44H A
50008 HTLX LESTER SD LESTER SD F B -6H B
Thanks in advance.
I can only assume lester is leicester
Townsend Hook
3 Aug 2011
GB
Can anyone help me with the power cars on 1F83 2225 St Pancras - Sheffield yesterday (12/10)?
Thanks in advance.
postye
7 Feb 2013
GWR
XC
1M41 1007 Paignton to Manchester Piccadilly 221120
1S47 0828 Penzance to Glasgow Central 221121
1S49 1125 Plymouth to Dundee 220003 PLY-BRI then 220003& 220008 to NCL, then 220003 to DEE
1M49 0935 Penzance to Manchester Piccadilly 220016 ass far as BRI, then 220023
1V47 0807 Manchester Piccadilly to Paignton 220001
1V52 0601 Glasgow Central to Plymouth 220013
1E67 1625 Plymouth to Leeds 220012
Thanks
see in RED
can anyone help me with the power cars on 1f83 2225 st pancras - sheffield yesterday (12/10)?
Thanks in advance.
43083 & 43066
sluf
15 Aug 2016
Hi guys
wonder if anyone knows what the 2 Colas class 56's were stabled at Carlisle kingmoor last saturday (8th October)?
There was also a consist of 3 x class 156 at glasgow queen street on the mallaig train at lunchtime on the same day - anybody help with them - sorry i dont know the train reporting number.
cheers if anyone can help
trainmania100
8 Nov 2015
Newhaven
Hi guys
I can only find this at carlisle
56087 COFS CSLE YD CSLE YD F N 23H A
These were all COLAS 56 on saturday 8/10 at 11am
56049 COLS WASHWDHAC WASHWDHAC F D 0H A
56051 COLS WASHWDHAC WASHWDHAC 1 B 60H A
56078 COFS HORTONRDJ HORTONRDJ F N 60H A
56090 COLS WASHWDHAC WASHWDHAC F D 0H A
56094 COLS WASHWDHAC WASHWDHAC F X 8H A
56096 COLS WASHWDHAC WASHWDHAC 1 X 54H A
56105 COFS LESTER SD LESTER SD F X 32H A
56113 COFS MARSHGATE MARSHGATE F N 57H A
56302 COFS HORTON RD HORTON RD D N 48H A
There were DRS locos there but too many to list
postye
7 Feb 2013
Bumping this! :D
1L11 1700 Edinburgh to Dundee 170418
2N60 1828 Alloa to Glasgow Queen Street 158735 & 170472
Anyone know what the DB Cargo Class 90 on hire to VTEC is working? Does it run on Saturdays?
did the 0735 KGX-LDS and return, looks like next working is 1408 KGX-NNG & return.
Dont know about Saturdays
trainmania100
8 Nov 2015
Newhaven
Can anyone tell me where the MPV which worked 3S93 Horsham Up tc circular rhtt CURRENTLY is?
The rhtt service was CANCELLED at brighton due to a problem but not sure if it went back to Horsham off the radar or if it's still at brighton
Maybe something somewhere thanks :)
