Top and Tail 67s on Vtec
24 Oct 2015
67012 working top and Tail with one of the Royal 67s has today worked 1D19 1505 Kings Cross - Leeds, and 1A48 1845 Leeds - Kings Cross.
Longer journey time as limited to 100mph but better than cancelling a service.
Jonny
10 Feb 2011
Maybe even get them to talk to each other - they could then hit 110 mph without bother. Better still, sort out the relevant issues to enable 125 mph running.
Kieran1990
29 Feb 2016
Assume Class 91 faults are high after last weeks big freeze- hence to TnT of a MK4 set on KGX-LDS trip.
Is this the first time MK4 have been hauled by anything apart from Class 91/90?
221129
21 Mar 2011
Sunny Scotland
No... 67s do it a fair bit as did HSTs back a long I believe
800001
24 Oct 2015
I would say this is the 1st time that I am aware where there has been no class 91 attached and just a 67 hauling in public use?
Failed Unit
26 Jan 2009
Central Belt
Class 31s and 47s did back in the early 1990s. The “wrong kind of snow” caused chaos fairly soon after they were introduced. They changed the grills if i recall. I think BR used anything they could find to keep the service going.
Forgot as well class 89 was a regular on GNER.
0705 London kx - Leeds
1005 Leeds - London.
1305 London - Leeds
1605 Leeds - London
Was its prefered Daigram.
Kite159
27 Jan 2014
West of Andover
There probably has been times when a 91 has had to be removed from a set due to a fault with a 67 going on the front to drag the coaches to complete the journey or to the next major station.
Although scheduled 67+Mk4s in public service probably is quite rare.
Although fair play to VTEC for attempting to run the service with a shortage of locos, other operators probably would have thrown in the towel and cancelled the service.
43096
23 Nov 2015
Quoted elsewhere as 20 91s available for 26 diagrams, hence use of two Class 90s, Class 67s and HST hire-ins from EMT.
DarloRich
Fenny Stratford
I understand VTEC have had a really bad week reliability/availability wise. The snow and ice issues really hit them hard.
Adam0984
18 Feb 2014
Yes the DVT was still tucked behind the 67 when I saw it at Doncaster yesterday
43096
23 Nov 2015
Have to say they Class 67 suit the MK4s well!!
Wish I had been able to get down to Leeds to see this.. was Class 82 attached still at the other end?
Class 82???? Only one of those in existence is preserved.
randyrippley
21 Feb 2016
he means the DVT, which are all numbered 82xxx in the coach sequence
to quote from Wikidmedia
  • British Rail Mk3 (82101–82152)
  • British Rail Mk4 (82200–82231)
  • British Rail Mk3 (82301–82309)
43096
23 Nov 2015
Sometimes i wonder if people feel good about this kind of point scoring post. We all knew what was meant here so what were you trying to get out of this post?
Factual accuracy.
Are you feeling all smug and satisfied, too, about your post?
Failed Unit
26 Jan 2009
Central Belt
Factual accuracy.
Why should i be? Unnecessary pendent posts like yours their adds no value to the forum, but i glad you got your “I know more that you buzz”. If you want to inform fair enough - but don’t do it in such a belittling way. I will leave it there - don’t want to upset the moderators as i have probably already overstepped the line.
Rob F
17 Dec 2015
Notts
Why should i be? Unnecessary pendent posts like yours their adds no value to the forum, but i glad you got your “I know more that you buzz”. I will leave it there - don’t want to upset the moderators as i have probably already overstepped the line.
Accuracy is never to be sneezed at. Hopefully, the OP knows a little bit more now than he did previously.
Rob
Temple Meads
2 Sep 2010
Devon
Rob
Nothing wrong with correcting someone, but the example above came across as needlessly rude.
