To replicate an Mk3...
Clansman
4 Jan 2016
I think Mk5s are the most likely for us to see out of any coaching stock going forwards, especially with the potential for DVTs, now the kinks look close to being worked out for TPE's fleet...
Is this purely because they are LHCS, or is it because you hold them in the same high regard as the travelling environment of the Mk3s? Personally I don't find that, having travlled on them with CS. It makes me wonder what the way forward is for the bench mark in quality, rather than simply using the benchmark on the type of train. For starters, the Mk5 production line isn't nearly as big as that of the Mk3s, and a key difference is that they were simply adapted from the Sleeper design, so it's not as if they are or were intended to be a fully fledged IC LHCS from the get go like the Mk3s - which were bespokely designed for the purpose rather than the adaptation we are seeing from TPE's order (if that makes sense?).
Edit: Misread what you had written and were merely making the assumption that Mk5s are the most we'll see in terms of LHCS going forward - which I agree with.
Though for clarity in general, I created the thread to gain an insight as to how Mk3s compare with the standards required for new rolling stock, and whether or not these standards can be achieved in todays climate (which they haven't with any rolling stock since).
dubscottie
4 Apr 2010
If the DFT specified a van on the IEP, a van could have been provided.
I think the existance of an MLV probably demonstrates that quite well.
As I said, the 444 is the absolute pinnacle of the modern intercity customer experience
Why do you call it an experience? I hate that term.
Its being overused to describe everything because people cant be bothered to use proper words to describe things anymore.
The Enterprise stock on the Dublin to Belfast run is probably a good standard to set for a new Mk3.
The passenger comfort, catering, lighting level and other facilities make a journey very enjoyable. A good solid coach with more metal than plastic. Yes the brakes squeal but thats a minor complaint.
I like 444s, but the 80x isn't really much different, being a long, relatively narrow box on wheels. Sort the rubbish seats and really I doubt I'd prefer one over the other.
