TM Psychometrics
MJN11
12 Jan 2019
I’ve recently applied for Avanti as a TM and heard that some TOCs accept successful psychometrics as long as it’s done in a certain timescale. If this is true, how long are they valid for and does it matter if it was with another TOC? I applied with EMR for a TM in late 2021 and passed the tests so would like to know
NSEWonderer
5 Dec 2020
I assume 5 years but im going off how long Depot Drivers at SWR had to apply for Mainline/ Trainee Driver roles. Is TM I assume Train Manager?
Lmc1976
2 Aug 2017
GWR conductor/TM is valid for 3 years.
Also for GWR when you apply you can enter when, where and who you did previous psychometrics with and then they check with the OPC so assuming they use the same tests as Avanti/EMR this should mean you won’t have to do them again.
