MichaelAMW
- Joined
- 18 Jun 2010
- Messages
- 1,021
Hello All,
I am travelling from Beeston to Exeter on Sat 28 May, which is the Bank Holiday weekend. Using the normal timetable I would go:
Beeston 06.43, Derby 07.01/07.25, Exeter 10.46.
However, on that day the line is closed between Derby and Tamworth. When I checked the times, the 07.25 from Derby (06.08 Leeds - Paignton) was retimed to depart at 06.53, with the connection from Beeston being the 06.03, an XC Nottingham - Cardiff service running as advertised, at least on the Nottingham - Derby section. On the strength of this information, which was backed up by a call to XC customer services, I booked a Derby - Exeter Advance ticket. No through Advance tickets were available from Beeston.
Problem is that the 06.03 service has apparently been pulled, leaving the first train to Derby at 06.24, arriving 06.48, which is 1 minute less than Derby's minimum connection time. What do think my position is, should I miss my connection, given that my planned train has been cancelled after booking my ticket?
If you wish to respond along the lines of "if you miss the first train for any reason..." etc relating to Advance tickets then that will be no help - that topic is a stalemate on this forum and the question I am asking is something else. The crucial issue is that I cannot go any earlier, as the 06.03 is usually the first train, in order to avoid the effects of the engineering alterations and thus I feel a bit left 'high and dry'.
