Time to ditch third rail? Snow pains = No trains
29 Aug 2010
Just a wonder if our country should really continue bothering with third rail electrics.
After two years of almost total stoppages on third rail routes in the south & south east, isn't it time everything went to 25kV overheads?
Switzerland and Norway seem to manage well. Even with two foot of snow most of Northern England's non electrified region was running fine.
I know third rail is obviously a lot cheaper to install and operate but in the long run, the costs they create during bad weather are likely to be more.
GB
16 Nov 2008
Somewhere
It would take a huge amount of money to convert all the lines that are DC over to AC.
MCR247
7 Nov 2008
Surely that money could be better spent to electrify lines?
Fincra5
6 Jun 2009
Whats the point for a few days of misery a year. It would increase rail fares even more then planned, all trains would have to be converted (etc).
People don't seem to understand that Switzerland and Norway have months of snow a year, not a few days, so there is a point to equiping all their trains to deal with snow.
Its just not worth it.
westcoaster
4 Dec 2006
DTOS A or B
What about the up and under 3rd rail ala docklands light rail, it has a protective casing on top and the current collected from underneath.
Fincra5
6 Jun 2009
That would still require vast modification to all trains and replacing all the normal 3rd rail, for that it would be cheaper to build ohle :D
142094
7 Nov 2009
Newcastle
Could be done on a rolling basis when the 3rd rail is up for renewal anyway.
atomicdanny
7 Mar 2010
Kent, UK
Then there is an issue for every tunnel, bridge, footbridge, as well as probably viaducts? Since most of the first three would have to have a lot of work done to them just to raise them higher or the track lower in the case of tunnels?! (and that could be very costly!)
YorkshireBear
23 Jul 2010
i know of 6 northern not electrified routes that have been cancelled over last few days
so not really a good point and the overhead has been suffereing too
MrC
20 Nov 2009
why not just attach long heaters to the 3rd rail? I think that it may be cheaper than replacing it with OHLE
There's a couple of trial stretches of heated 3rd rail in known problem areas. I don't know whether it's permanently heated via the traction current or there's a separate heating circuit - I suspect the latter to avoid summer overheating. It'll be interesting to see what difference it makes.
tbtc
16 Dec 2008
Reston City Centre
I think we should have Third Rail electrification in Yorkshire. It'd stop the little scrotes in Rotherham from pinching the copper cables (or at least act as a discouragement)!
YorkshireBear
23 Jul 2010
ive said before snipers are best bet for that :) id happily be one
They could build third rail trains which can still operate when being pulled around by diesel locos - uknow like slammers ;)
jopsuk
13 May 2008
The modifcations to fit the appropriate shoes would potentially be rather more complex than fitting the missing pantographs to the 375, 377, 450, 444 and 458 fleets. Reckon the 465s would be refittable (more work than those though) to be similar to 365s. Reckon the 455, 456, 442 fleets would be trickiest. The infrastructure upgrade would be rather cheaper than OHL admittedly.
Even the way used in other countries (such as the US) to protect from snow of having canopies over the conductor rail is not really practical with the geometry of UK stock and track.
It would be fantastic if we could have the Southern converted to OHL- but lets get all the other mainlines and major commuter networks done first.
A0
19 Jan 2008
Surely the 455s and 456s wouldn't be that difficult? They're related to the 317s & 321s after all. What about taking the 508 trailers out of some of the 455s and replacing with panto cars from 314 / 315s when they're withdrawn?
442s would be difficult as there was never a similar ac design.
142094
7 Nov 2009
Newcastle
Was more thinking of replacing the 3rd rail with the ones mentioned as used on the DLR, which would do away with the need for all of the above!
Lampshade
3 Sep 2009
South London
the bury to man victoria 1200v DC electrics kept on going in the icy conditions, due to the side contact 3rd rail.
Missing a lesson from history perhaps ?
The 504s would have kept going anyway, slammers were almost completely unaffected by snow and ice until they caught fire :shock:
O L Leigh
20 Jan 2006
In the cab with the paper
That's the problem. It's not that the slammers were necessarily more tolerant of the ice but that their replacements have more safety overload protection to ensure that the unit doesn't fail due to fried components.
O L Leigh
TGV
25 Nov 2005
320km/h Voie Libre
O L Leigh
Very true - and in common with most other stock in many system areas. Unfortunately, Joe Passenger doesn't care and Jim Newspaper still loves attacking railways especially when new stuff isn't "as good" as old stuff. Either way - we (the Railway) loses.
Still - as long as we keep the job going eh?
Matt Taylor
31 Aug 2008
Portsmouth
I think that 3rd rail electrification compares favourably to OHLE when you look at the big picture, OHLE does have a tendency to fall down rather too often in high winds.
SE and SN have not covered themselves in glory today but SWT implemented a revised revised service which has worked albeit with a few delays, 3rd rail is not necessarily a problem provided there is a robust 'Plan B'.
O L Leigh
20 Jan 2006
I don't agree.
The OLE doesn't get blown down, it gets knocked down by other things that have been blown down (e.g. trees). But if those trees hadn't ended up on the wires they'd have ended up across the tracks causing an obstruction and almost as disruption.
But such instances are isolated and do not affect the entire electrified network in the same way that freezing conditions paralyse every electrified route south of the Thames. We've had only one instance of an obstruction on the OLE this year, and that was just a branch resting on a return conductor wire. It caused some disruption during the evening peak, but it was dealt with inside two hours. I hardly see that as a poor comparison (even in the big picture).
O L Leigh
jon0844
1 Feb 2009
Yeah, but you don't work on the ECML where wires come down quite a lot. They might be caused by trains or trees, but it takes a lot longer to fix than shifting a tree off the track.
But, of course, if the ECML hadn't been wired on the cheap then it would probably be extremely reliable.
O L Leigh
20 Jan 2006
Not forgetting also that the ECML is several hundred miles in length and crosses some very exposed landscape. That counts against it, not so much because it proves that OLE is not a robust electrification system, but because a single incident can cause disruption making it seem worse than perhaps it actually is.
But my point still stands. No single type of incident can paralyse the entire OLE network for days on end in the same way that a bit of cold weather plays havoc with the 3rd rail network.
O L Leigh
TGV
25 Nov 2005
320km/h Voie Libre
Agreed - during all this harsh weather, and including last winter - the OLE on the CTRL has been absolutely fine while the 3rd rail literally running right next to it has been rendered useless.
ChampsRacing
10 Jun 2007
South west trains havent had a problem with the 3rd rail on this round of snow. The delays came from frozen points or stock/crews displaced. While southern was fully suspended thursday southwest trains for most of the day was running within 15 minutes of time.
