hexagon789
Travelling from Glasgow to Lincoln and I'm slightly concerned over, firstly whether the connections are sufficiently robust to change trains and secondly what to do if any are missed or trains are cancelled.
The itinerary is:
Train 1 Glasgow to Edinburgh
Depart Glasgow Queen Street 0900
Arrive Edinburgh Waverley 0945, plat. 9
15 mins to change, MCT = 10 mins*
(*this one I'm not too worried about, as m very familiar with Waverley and consider even 10 mins is more than ample, for this change)
Train 2 Edinburgh to York
Depart Edinburgh Waverley 1000, platform 6
Arrive York 1214, platform 3
13 mins to change, MCT = 8 mins
Train 3 York to Retford
Depart York 1227, platform 7
Arrive Retford 1306, platform 1
10 mins to change, MCT = 10 mins
Train 4 Retford to Lincoln
Depart Retford 1316, platform 4
Arrive Lincoln Central 1354
Essentially, I'm asking about the connections at York and Retford.
I've been to York a few times, but never to change trains. 3 to 7 is I believe lift to Subway, then lift up on to 6 and walk around the buffers. Any estimate to how quickly that can be done? I assume the MCT accounts for going all the way from 3 by the entrance to the furthest platforms, so 3 to 7 should be a bit less than 8 mins?
Secondly, Retford, I've looked at the arrangement and it seems to be a ramped walkway off the Southern end of 1 which leads towards the low level platforms. Again I assume the MCT accounts for the furthest change, which would be 2 to 3 I think? So 1 to 4, should be doable in less than 10 mins? Again I'd appreciate an estimate of how long it might take.
Finally, I've noticed the 1000 Edinburgh to London KX, is often 5 mins or so late into York, and today it was in fact cancelled.
I presume the onus is to try and make the connection to the 1227 to London at York, unless it falls below the MCT?
If it was missed, is it an absolute must to wait two hours for the 1427 or would using the following Newcastle to London KX semi-fast, alighting at Grantham and changing to the LNER London to Lincoln at Grantham likely be allowed?
Any practical advice or thoughts would be most welcome.
I should add that I'm travelling with someone a bit slow on their feet, hence my heightened concern over connections.
Many thanks
The itinerary is:
Many thanks
