Tickets with a * after the station name
hughesfowler
17 Nov 2009
Not sure where to ask this but its something that puzzles us. Some stations on the ticket have a * after the station name, for example Irlam* but warrington no * printed after the station name. Sorry if this seems a bit vague but only way to describde it. Does anyone know why some stations have a * on tickets and others not
telstarbox
23 Jul 2010
Wennington Crossovers
It's to stop ticket fraud by changing a short station name to another (eg Charing to Charing Cross) - the star makes it more obvious if this has happened.
neilmc
23 Oct 2011
I thought it was to denote I had free travel on the city centre portion of the Metrolink. Good job I didn't get caught, eh?
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
IIRC, any destination under 16 characters in length will have an astrix. Thinking about it, however, 14/15 character long place names may not have one either.
TP
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
Anything up to 14 characters will have one. 15 and 16 won't (because there's no space for it).
Also some ticket machines now print a full stop at the end of some stations' names, which will affect the character count.
TP
An 'asterisk' is what that symbol is.
An 'astrix' is probably a badly spelt French cartoon character... :D
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
To be more precise, they print the form of the station name intended for internal use in ticket issuing systems rather than that intended for printing on tickets. You have to wonder how they get their accreditation from ATOC, or how thorough the checks are. It has been speculated that the dot is a hackish way (and not without side-effects) for TIS operators to cut short the station name autocomplete on their systems. But it's not just the dot after the names that is different - Sandwell & Dudley to Jewellery Quarter is a particularly interesting one.
Class172
Quizmaster
20 Mar 2011
West Country
I had often wondered why Droitwich Spa had a '*' after it, but not Worcester Stns.
Paul Kelly
16 Apr 2010
Reading
Leeds always has a dot after it iirc.
True; both the "TIS version" and the "ticket version" of Leeds have a trailing dot in the fares database. I always wondered why, when you type "Leeds" into BR Fares, it doesn't auto-suggest LEEDS but instead LEEDS + BUS. Now I know why! Greenford, Luton Airport, Ashford Intl, Old Street, Moorgate, Peterborough, Doncaster are a few others with the dot affliction, and there are a few more too. Weirdly Ashford Intl doesn't have a dot in the TIS version, so on a Todler machine it would print without the dot, but on a normal machine with the dot!
But does anybody else really care about this? ;)
Muzer
3 Feb 2012
Interesting about ToDler. I know to stay away from them now, they seem like thoroughly awful machines!
RJ
25 Jun 2005
Back office
TP
The origin/destination fields contain up to 16 characters. Locations with less than 14 characters will be followed by an asterisk.
34D
9 Feb 2011
I believe the destination printed needs to be MANCHESTER CTL ZONE (or similar 16 character shortening) for you to be able to do thus.
hairyhandedfool
14 Apr 2008
Close, it needs to be to a destination of 'Manchester CTLZ', or be routed 'Metrolink (GM)', or be to a Metrolink destination, or be one of the rovers, rangers or PTE products/Season tickets that give free travel on Metrolink in the city centre.
Mojo
7 Aug 2005
Has the route of Metrolink (GM) now not been changed to METROLINK CTLZ for most (all?) tickets?
Starmill
18 May 2012
Bolton
Yes :)
And don't go pretending you found that out all by yourself, though I'd be interested if any have not been changed?
Muzer
3 Feb 2012
If a booking engine routes you on the Metrolink but the ticket in question doesn't have any of these, does it mean you have to buy a separate Metrolink ticket? (Eg for transfers from Piccadilly to Victoria and vice versa)
34D
9 Feb 2011
I'll defer to the manchester area experts, but I would have _expected_ that it would only show things valid.
Potentially it would say 'walk'? Or route you via heavy rail?
hairyhandedfool
14 Apr 2008
Some journey planners are known to show routes which include travel on Metrolink when it is not included on the ticket. The same can be said of the bus link between the Yeovil stations also. Where travel on Metrolink is not permitted by the ticket a Metrolink ticket must be purchased to use the service, regardless of what the journey planner says.
Paul Kelly
16 Apr 2010
Reading
None of the individual fares have been changed; they still use route code 00318, which hasn't been changed. It's just that what's printed on the tickets for that route code has been changed. So anything that previously printed with METROLINK (GM) will now automatically print METROLINK CTLZ instead.
OwlMan
25 Jun 2008
Paul Kelly
16 Apr 2010
Reading
Very interesting links there Owlman. Surprising how short the list of accredited systems is. I note the second document says:
TIS accreditation guide said:
As far as possible RSP aims to promote self-assessment with the minimum of
verification. This is more practical for objective criteria and thus RSP may apply an
amount of due diligence on the more subjective criteria which varies according to
the scope and complexity of the TIS.
which suggests to me that (what on the surface appears to be) a simple objective criterion such as printing the correct form of the station name is not actually likely to be checked. When they're dealing with companies with many years of experience in rail systems this is probably reasonable, but there's so many vague and unclear areas in all the specification documents that it might not be such a good idea to leave a "new entrant" supplier (such as Parkeon who make the Todler machines) to verify everything itself!
Muzer
3 Feb 2012
I tried Southampton Airport (Parkway) to Marsden on a The Train Line powered engine (SWT's) and it gave me a Metrolink leg.
If someone managed to get through to a reasonably knowledgeable person at the country, I wonder if they could get a software update written and pushed out to resolve these two bugs?
Eagle
20 Feb 2011
But it does flag up a warning saying that the cost of Metrolink is not included in the ticket.
(It also gives me itineraries going Piccadilly–Stalybridge–Marsden, out of interest.)
Muzer
3 Feb 2012
Does it? It flags up a warning that one leg is by a non-rail means of transport, but I can't see where it says that it's not included in the ticket.
Starmill
18 May 2012
Bolton
Doesn't it normally just say 'Please check operating hours for this service' ?
185
29 Aug 2010
Advertising Standards were on at ATOC not too long ago over more than one product which was not valid, despite being advertised to the contrary.
Mcr Warrior
8 Jan 2009
Generally speaking, a train ticket from somewhere in the Greater Manchester ticketing area to central Manchester (for example Piccadilly, or Victoria, or Deansgate, or Oxford Road) will have "Manchester CTLZ" as the destination (rather than "Manchester Stns") and thus will allow free use of the Metrolink trams in the Manchester City Centre zone.
Similarly, a train ticket from somewhere on the North side of the Greater Manchester ticketing area (e.g. Littleborough) to somewhere on the South side (e.g. Cheadle Hulme) which necessitates a cross-Manchester City Centre transfer will have routing as "Manchester CTLZ" and so will allow use of the Metrolink trams in the City Centre zone.
However, if one or both of the stations are outside of the Greater Manchester ticketing area, then you have to pay extra for the Metrolink cross-Manchester transfer (Adult single = £1.10).
