Malpensa airport is served by the Malpensa Express which runs to Milano Nord Cardorna every 30 minutes and Milano Centrale every 30 minutes. The fare from the city centre to the airport is 13.00 whereas the fare between the city centre and Busto Arsizio is 4.00 and the fare between Busto Arsizio and the airport is 4.00. Most if not all trains stop at Busto Arsizio. So it looks like you can split tickets at Busto Arsizio and save 5.00. But it isn't that simple.
The Malpensa Express trains from Cardorna are 1st class only, whereas the ones from Centrale have 1st and 2nd class. But they are both run by the same stock and there is no branding anywhere on the train to show what part is 1st and what part is 2nd! This bizarre quirk does mean you can only split tickets using the ones from Centrale unless you get a 1st class ticket. Although there are other normal trains between the city centre and Busto Arsizio which you can use.
Another complication is you need to validate tickets before boarding. Could you validate a ticket between Busto Arsizio and the airport at Centrale or somewhere else en route such as Bovisa? Otherwise you could get off the train, rebook and validate at Busto Arsizio. Alternatively you could presumably get a mobile ticket, but has anyone got the Trenord app to work?
