Through running in Tokyo - how does this work?
Transilien
10 Mar 2024
Ayrshire
I’m quite curious about how through running between the subway suburban lines in Tokyo actually works. Can trains from both systems do the interlining? Or is it only say the suburban trains that can run on the metro and vice versa. Also, is interlining something that happens all the time or is it only say during peak times?
eldomtom2
6 Oct 2018
Normally trains from both systems through-run, and indeed rail companies will pretty much always have their own stock regardless of how short the line or who actually operates it - e.g. the 2.5 mile-long Yokohama Minatomirai line, effectively an extension of the Tokyu Toyoko line and operated by Tokyu crews, still has its own fleet of EMUs. However some classes of train may be barred from metro or suburban lines due to lacking required safety systems etc.; an example would be the Tokyo Metro Tozai line, which connects to the JR East Chuo-Sobu line at its western end and to the Toyo Rapid line at its eastern end - Tokyo Metro stock can run on all three lines, but JR East stock can't run on Toyo Rapid metals and Toyo Rapid stock can't run on JR East metals as they use different safety systems.
In most cases through-running is something that happens all-day, and indeed on some suburban lines all trains through-run. Peak-only extensions are not uncommon, though, and indeed some outer suburban stations see one through-running train a day.
An additional point worth noting about Japanese through-running is that with the exception of lines owned by companies that don't employ their own train crews at all, crews are always changed at company borders, the process usually being done in less than a minute. Crews operating onto "foreign" territory used to be somewhat more common, but it was clamped down on in the aftermath of the 1991 Shigaraki crash where a JR West through service onto the Shigaraki Kogen line collided with a train travelling the opposite direction (though I can't find anything saying that the train crew's actions caused the crash in any way, which was primarily caused by dispatchers allowing a train to enter a single-track block without confirming it was clear).
Route115?
26 Jun 2021
Ruislip
I'm not an expert I but visited Japan earlier this year.
Yes trains from both systems run through and lines will generally have trains from both (I'm not sure if there are sections with three) operators. These generally operate all day.
They always change crews at the border station between operators. From experience this can cause problems where there is late running (which does indeed happen, even in Japan). This is similar to the RER B in Paris a few years ago - crews now run through - but with SNCF & RATP operating different designs (and liveries) of stock.
I'm sure that others will know more.
Gag Halfrunt
23 Jul 2019
IIRC the planners of the RER studied through-running in Tokyo and adopted the policy of changing crews at border stations.
Beebman
17 Feb 2011
Twyford
This may be of interest, it's a YouTube front view (with station names also shown in the Roman alphabet) from a Japanese railfan channel of a 2-hour through journey from Haneda to Narita Airport using the tracks of 3 differently owned (standard gauge) lines, the Keikyu, the Toei Asakusa and the Keisei Electric:
There's two changeover 'border' stations in the video - Sengakuji (26:35-27:40) and Oshiage (51:00-52:17). At both places the new driver can be seen waiting at the front end of the platform. (the actual crew changeovers in the cab have been edited for privacy reasons but the second one at Oshiage is reasonably visible)
