" this train contains doors."
JB_B
27 Dec 2013
Today's 16.20 from Three Bridges to Brighton was advertised on the screens in the usual way with operator, calling points etc, but with the interesting additional information that
Is that just a test message that's escaped into the wild?
hexagon789
2 Sep 2016
Would be quite interesting if it didn't! How would one get one or off - through the windows or would there simply be open doorways? Not sure H&S would like that!
Seriously these messages are getting more and more ridiculous! :lol:
37254
27 Dec 2018
Portsmouth
Wow! Very useful information. Thameslink must be feeling ill if they are actually giving you usefully information good on them.
Jona26
2 Jan 2013
West Sussex
The platform staff at Gatwick often announce "This train has 8/16/24 doors. Please move along the platform and use all available doors."
18 Dec 2009
Saw this in Aberdeen a while back. Who knew trains had carriages.
Dr Hoo
10 Nov 2015
Hope Valley
Ah yes! Takes me back to my days as an operations manager in Kent in BR days. To help pull back a slightly delayed train at a station in the Medway Towns I would often announce (for a 12-VEP slam-door consist). "This train has 100 doors, please spread out along the platform and use as many as possible between you." 200 or so obedient commuting souls could be on and away in 25 seconds.
JB_B
27 Dec 2013
Yes - I guess it would sort of make sense to put this on passenger information screens ( although 'contains' is an odd way of putting it.)
The monitors were showing this:-
( I couldn't get a clear picture of the dot-matrix PIS on the platform but it ended with the same message.)
37254
27 Dec 2018
Portsmouth
Possibly a fault where the station staff or who ever do it didn't put in the amount and instead of coming out as this train has 40 doors it came out as this train has doors.
TFN
17 Aug 2017
We do it and it has little effect. It breaks my heart everytime I do that announcement at Gatwick.
TFN
17 Aug 2017
Out of interest, what happens if you don't do it?
Nothing. We just do it to try and spread the passengers away from the middle of the platform (escalator entrances). Usually Platforms 3/4 is the issue as on a weekday it has the 06,16,36,46 Thameslink to London, the 12,42 GatEx to London and the 27,33,57,03 Southern to London.
During delays it gets particularly busy in the middle and I've seen it so full that the escalator landing is occupied with people. When the train leaves, coaches 8-12 usually carries fresh air.
Also, GatEx trains now have loading indicators showing on the PIS screens on platforms and the main concourse.
More developments on that in the coming weeks I hear.
Dougal2345
29 Oct 2009
I always think it will delay departures even more if I take that advice literally and make a point of using all available doors...
geoffk
4 Aug 2010
Exeter
Good advice and I sometimes wish Northern and TPE would do it. I've noticed how often passengers queue to use one door rather than space themselves out along the platform. I wonder how much delay it causes.
sheff1
24 Dec 2009
Sheffield
It loses credibility when you get the likes of LU announcing it then a shorter Circle Line train rolls in and you look a prat.
Indeed. At Sheffield two favourites are
TPE to Manchester Airport - "This train has 6 carriages. The front 3 carriages will detach at Manchester Piccadilly. Please make sure you travel in the correct part of the train". Train then rolls in with 3 carriages and any punter trusting enough to move down the platform on hearing the announcement sees the train sailing past them.
XC "This train has 8 (or 9) carriages". When the train arrives it does have that number but one set is locked out of use. Whether the locked set is the front or rear one varies. Rather than moving down the platform when the announcement is made, it is much better to wait in the centre and see what the situation is when the train arrives.
noddingdonkey
2 Nov 2012
With TPE it would help considerably if they could announce which way round the set is (eg Coach C is at the front of this train").
People tend to congregate in the middle either because they have a reservation and don't know which end A or C will be until it turns up or because they are on a walk up ticket and need to avoid first class.
Bantamzen
4 Dec 2013
Cheshire
This did happen briefly at some stations, Warrington Central for one (before the Scarborough moved over to Chat Moss), and I'm sure I've seen it at least once on P16 at Leeds. Nowadays I look for the presence of the yellow bar above the coupler.... ;)
talltim
17 Jan 2010
It’s good they’ve started giving out allergy information
gimmea50anyday
8 Jan 2013
Back Cab
In contrast at Durham.and Northallerton they congregate at the LNER A B C letter signs on the platform only to find TPE services stop in a completely different area of the platform!
The excuse (and it is an excuse) is always used that they don't know which way round it is. Well, unless they're blind, the driver and the guard know which way round it is, and providing some means of getting that information on the PIS does not seem an excessively complex IT (or administrative) problem.
Indigo Soup
17 May 2018
This one always amazes me about the British rail network - many foreign railways will cheerfully tell you that your train will be in Platform 3, and has seven carriages; coaches A and B are First Class, C is the buffet, bikes and large luggage in G. In Britain, we like to keep all of that a mystery until the last possible moment, hiding behind the suggestion that the people who run the railway haven't got a clue what kind of train they're using, where it's going, or which way around it is.
DarloRich
Fenny Stratford
This is clearly a mildly silly fault, a test or a keying mistake. Is it worth such comment?
peri
23 Dec 2016
When a train pulls in I scan the carriages for space and that is where I'll board. That probably explains a scrum round one particular door.
gimmea50anyday
8 Jan 2013
Back Cab
What clearly doesnt help is the multitude of train types and the formations as a result. If only there was a more standardised way of doing things, like standardising train formations or by having certain carriage letters to always be the same type of carriage......
