Third rail - becoming a better option for electrification?
Anywhere likely to be able to switch off for several hours a day is unlikely to be worthwhile electrifying unless there are further external factors.
What fraction of the non-electrified railway doesn't shut down for several hours each night?
In addition, what fraction of the electrified railway does that, I think its quite a large portion.
But ultimately that depends on whether you believe battery trains will be fully as capable as diesel ones.
If they aren't, it is likely that any non electrified medium/long distance railway will simply close.
If the batteries fail to rescue the railway, it will be electrification or no railway.
There is unlikely to be much if any 25kV electrification beyond that already committed.
If you're switching it off for 20 minutes between a half-hourly service every hour that's a lot of potential times for the power not to come back when asked, as well as the risk of residual current unless some programme is put in place to fit automatic earthing equipment. And, as @Meerkat says, you introduce other risks as you complicate the messaging, as well as not saving too much because staff will always be required to treat the line as live until made safe.
Why would any new third rail installation not have automatic earthing equipment?
This is not the 1920s any more
Northampton
Overnight is different to in between services. A large fraction of the railway does have nothing running on it for long periods between midnight and early morning.
I believe there will need to be electrification to bridge the gaps but that battery technology will mature to cover a fair portion of the existing diesel operated lines. WoE line is a classic case in point - Electrification to Salisbury would be required, possibly even to Yeovil Junction, and then some OLE at the Exeter end (assuming Newbury-Exeter was already done), but the quiet bit in the middle would have battery trains capable of doing that section.
Longer-distance non-electric lines (wales and Scotland mainly) will either need charging stations and longish dwells or to close.
This is not the 1920s any more.
Cost?
Yes, and trespassers and staff still end up near the track at night and these people can still be electrocuted.
Turning off the power supply at night would reduce the risk to these people and given that modern SCADA would allow a power supply to be secured in seconds it seems unreasonable not to do that in a new installation.
I don't think the cost of that sort of equipment would form the significant portion of the cost of a scheme, it doesn't have to have the huge sustained current capacity of the actual traction path after all. Considering modern earthing switches, albeit still manual, are being retrofitted all over the place as it is. In a new installation it would just be one more motor operated disconnector in a hut full of other motor operated disconnectors.
Indeed, using the West of England line as the case in point, its probably feasible to actually use London Underground influenced practice since engineering work on any of it is likely to take out the entire line anyway. It's not as if you can really route around most of it without making the service pointless.
Northampton
Maybe, I wonder how much you'd actually be able to save though given many southern region trains run beyond 0100 and ECS moves start before 0500.
I'll defer to your much greater experience of the actual systems. However you've heard from previous posts that earthing straps still have to be manually applied on railway possessions.
mike57
13 Mar 2015
East coast of Yorkshire
Seems pretty dangerous to me.
Hyrdogen also causes hydrogen embrittlement of metals, which means material selection is far more difficult, and it has one of the widest explosive ranges in air, from 4% to 77% hydrogen in air, and the resulting explosions are energetic. Couple that with the input power required to create hyrdogen v power delivered at wheel, i.e conversion efficency, which is poor, and my view is hyrdogen is a blind alley for most applications.
For lightly used remote lines stay with ICE, contribution to emmisions if miniscule, elsewhere electrify with battery assistance where having small gaps makes sense.
Could a side contact 3rd rail be used, Manchester - Bury used this, and then raise voltage somewhat to reduce losses, that used 1200v if I remember correctly. Side contact is easier to protect against accidental touch. 3rd Rail seems to make sense for Urban and Suburban lines, less so for main lines where speeds are higher, but if 25kV OLHE cost are unsupportable would a (modified) 3rd solution deliver something at a cost we can afford which is better than doing nothing.
Unfortunately my understanding of this sort of complicated switchgear is from a nuclear power station!
A safety case industry, but rather a different one!
Trends in earthing in most industries have been moving away from manual application to safety grade control gear for many years though.
Only way to tell what would actually be installed would be actually to develop a new installation design.
I wonder what they are doing on new metro lines abroad with third rail supplies?
RobShipway
20 Sep 2009
I will probably be corrected and unfortunately I have not been able to find it within these forums, but I do remember someone pointing out within one of the threads, that you will not be able to get much more than 100mph on 3rd rail routes and probably 75mph on more Suburban lines if speed is possible. Hence for higher speed lines you would want 25kv OHLE, where speeds higher than 100mph are more possible.
So as it is an example already used, you could potentially use 3rd rail Salisbury to Exeter, but you have to think about where do you draw the power from? Also, the route may actually be better with OHLE even if there was a limit of 100mph on the route as this would allow where possible for faster speeds in the future.
mike57
13 Mar 2015
Which leaves a lot of urban and inter urban lines which will never need or see services above 100mph, for example everything in and around Leeds, Bradford and Manchester that is not currently electrified or in progress (TPE route) falls into this category, In fact I think 90mph capability is the most you would need, and more typically 75mph.
Realistically these lines are not going to be electrified at 25kV anytime soon, a 3rd rail solution may be more affordable and less invasive to fit, no bridge/tunnel issues. It might not be the 'best' solution, but if installation costs could be kept under control and safety issues addressed (side contact for example) it might be the only way to move away from diesel operation for a lot of lines, I suspect 3rd rail lifetime costs would be lower than diesel, but maybe higher than 25kV, but its the upfront cost and invasive work that will hold back 25kV schemes.
Bantamzen
4 Dec 2013
Cheshire
Quite a bit of the network around the North of England is wired, with more to come under TRU. Why on Earth would Network Rail then complicate the issue by adding third rail to a few selected routes, requiring TOCs to procure new stock capable of running on them as well as wired routes and others that won't see any electrification?
This one gets filed under "Very large crayola"....
stuu
2 Sep 2011
Based on what? There are currently five separate electrification projects being worked on right now. Clearly there are cost issues but lots of electrification has happened in the past decade and there is every chance it will carry on. Batteries and other innovations with switchgear and supply points etc have their part to play, but third rail is not the future
Most of these schemes are small and/or beset by schedule or cost options problems.
They also represent a small fraction of the output required for electrification to significantly advance in the time available.
There is no talk of another GWML scale scheme any time soon, and there probably won't be given the cost issues.
stuu
2 Sep 2011
Most of these schemes are small and/or beset by schedule or cost options.
And? Right now it's fair to say there are bigger priorities for government expenditure and opposition campaigning
But, there is no realistic alternative, sooner or later many routes will need electrifying. Something will need to be done about costs - closing routes for 6 months and getting them all done in one go perhaps
eldomtom2
6 Oct 2018
I know that I've mentioned my own experience on here before but this sort of stuff doesn't actually 'get real' until you personally have to attend the Inquest into the death of a nine-year-old boy who got onto a third rail line through a hole in the fence made by rail staff to create a shortcut to a depot.
And then, within few months have a very experienced Electric Track Maintenance (ETM) colleague electrocuted whilst working right next to me because of an appalling set of procedural lapses.
Believe me - third rails can be lethal. They are not 'the future'.
But if those deaths were on unelectrified line and the result of being hit by a train, you presumably wouldn't be using them to argue against the opening of new railway lines.
Trainbike46
18 Sep 2021
belfast
That's not a fair comparison at all. For starters because, the risk of being hit by a train is present whether the electrification is present or not. Secondly, the incidents described couldn't have happened on a line that didn't have third rail. Furthermore, I don't think it is right to make light of someone's experience in this way.
In addition, the railway is taking many steps to reduce the risk of collisions of a train with a person; one of them is work to reduce the number of level crossings and to increase the safety of the ones that remain.
The current size and scope of railway operations is not fixed and unchanging with time.
There is a perfectly realistic alternative - railway routes that cannot be operated with existing electrification and battery equipment cease operating.
Just because the railway has had three decades of massive political support and largely unchallenged budgets does not mean that this will be true forever.
Dr Hoo
10 Nov 2015
Hope Valley
Seeing as this is addressed to me personally, can I ask if you have ever had to attend the Inquest on a nine-year-old who was electrocuted as a result of undisciplined rail staff action; and/or (b) had a work colleague electrocuted right next to you?
Hear, hear. And, may I add, putting in a great deal of effort across the industry in identifying and intervening with vulnerable individuals on and around the railway as well as 'hardening' the overall railway estate from unauthorised access where possible. I've also done safety talks for schools both before and after the tragic incident with the nine-year-old.
eldomtom2
6 Oct 2018
But the risk of being hit by a train is not present if there is no railway.
The intent was not to make light of someone's experiences.
The assumption here is that it is impossible to increase the safety of third rail installations; I am dubious of this. In addition, would you oppose the construction of new railways if it had been determined that it was not cost effective to close any more level crossings?
Frankly the legislation should be amended to enable these extensions and infills (although it's hardly surprising that such a lack of consideration was shown in the original bill by Major's circus government).
The legislation is not railway specific. The applicable law is the Health and Safety at Work Act (half a century old, enacted in the Wilson government ). The relevant statutory regulations are the Electricity at Work Regulations (one third of a century old, laid before Parliament under the Thatcher Government). Worth a read.
There is simply no way that they are going to be amended for a railway specific purpose.
Jozhua
6 Jan 2019
Discontinuous OLE looks a lot more viable than 3rd rail and is what has been used in Wales.
Essentially, there are sections of neutral wire where clearances are too tight to allow for current to flow without risk of arching, with a small battery pack on the train to supply traction/house power.
Again, infill is common sense in the SE, but for Greenfield projects, just seems a bit silly. Even the style of top contact 3rd rail used in the UK is pretty outdated. If we were to adopt it in other areas, it would likely be the side/bottom contact seen in the US and newer metro systems.
Cheap OLE that has poor reliability and hasn't been maintained properly is the main culprit of our issues at present. In a lot of stations you can hear the crackling/fizzing of busted kit. Wirh headspans, they take out all the lines as soon as one breaks.
It seems likely to me that some batteries capable of carrying trains limited distances through neutral sections will probably be the best future solution to work around any failures that do occur.
Then since we've been laying third rail long after those acts were passed, there must be a precedent that it's permitted.
As stated upthread, the last of the main line electrification projects was confirmed shortly before the regulations became live (excuse the pun) on 1/4/90.
Northampton
The risk of electrocution from railway electrification equipment is present whether trains are there or not. The risk of being hit by a train is only present when the train is. So it's a completely different comparison.
So the regulations were introduced under the Wilson Government but only became "live" in 1990 !
Whatever happenned in 1990 is what needs to be amended.
As I said, the relevant law is the Health and Safety at Work Act 1974.
The specific regulations are the Electricity at Work Regulations, which explain how the law should be applied in relation to electrical works. These date from 1989 but came into force in 1990. I linked to them above, and I recommend you read them, they are actually quite interesting.
eldomtom2
6 Oct 2018
No it isn't.
Bikeman78
26 Apr 2018
So if it happens to derail on the correct side a 50/50 then that a short is provided to trip the system, even at a 50/50 that makes it a 25% chance. hardly reliable. Besides, as I have told you, 3rd rail is seriously dangerous kit.
There's no need to be rude is there? Can you think of an example of someone getting off a train in an emergency and getting electrocuted? I cannot. Whatever you or I think, I doubt any more routes will be electrified. On the other hand, I doubt the existing third rail network will shrink much in my lifetime. The cost and disruption isn't worth it.
Dr Hoo
10 Nov 2015
Hope Valley
It is painful to recall, but even a trained and experienced driver was electrocuted at Deal in 2006 whilst investigating a failure issue with their train.
Lurcheroo
21 Sep 2021
Wales
It was not rude, merely to the point.
There have certainly been near misses involving de-trained passengers and live 3rd rail equipment. We should not wait for something to happen to mitigate a risk. Or do you feel that’s the wrong attitude to have ? I’m sure you’d feel differently if it was one of your loved ones who had lost their life.
I feel Dr Hoo has provided more than enough examples at this point to clearly show to anyone how real the risks are.
No I don’t think it will and it may even slightly grow if any small infill projects are done. I’m not saying railways shouldn’t be electrified, just that 3rd rail isn’t the solution.
Pigeon
8 Apr 2015
The substations cost a small fraction of the cost of 25kV capable substations though. At the traffic levels prevailing on the remaining non-electrified portion of the railway network, it is unlikely that substation costs for DC would be significantly greater than they would be for AC.
You still need a substation at the points where the grid feeds each group of third-rail substations, to take the grid voltage down to 33kV (I think it is, and it makes sense) that the railway uses to take the power on to the substations themselves. The spacing of these is similar to that of the 25kV ones, so really what you end up needing is the same-ish number of medium-voltage substations and a bunch of third-rail-feeding ones as well.
Where you save is that you don't need to carry around the works of a third-rail-feeding substation on every train, whereas with 25kV you do. And you also get to keep them in a sheltered clean environment that doesn't vibrate and doesn't suffer such extremes of temperature.
Note that you do not suffer full-on third-rail levels of losses all the way from grid to train. For most of the distance the power is running from grid connection point to low-voltage substation, suffering about the same level of loss that it does over the same distance with 25kV overhead. It's only the last couple of miles from low-voltage substation to train that the heavy losses kick in.
If the sections of third rail a few hundred metres long, which at present are daisy-chained, were instead fed individually from small low-voltage bidirectional substations (with or without demand switching), the heavy losses would only apply over the last couple of hundred metres, and you could more or less ignore them. You would need more substations than the present convention, of course, but on the other hand they would only under exceptional circumstances need to handle more than one train at a time, and their duty cycle would be a lot lower in most cases, so you wouldn't need to make them so big. Essentially what you'd be doing is equivalent to taking the on-board substations off 25kV units and sticking them at the trackside instead.
A Class 345 at max draw requires something like 4.4 Megawatts
[snip]
OHLE
4400000W / 25000V = 176A
DC 3rd Rail
4400000W / 750V = 5867A
The amount of current needed by the DC system to supply the same amount of power / work as the OHLE is nearly 34x more
What you are missing is that the loss in the track conductor (overhead wire or third rail) and return is proportional to the square of the current. The current is (25k/750) = 33.33... times greater, so the transmission loss is (25k/750)^2 = 1111.11... times greater.
Hence low-voltage systems only step down to the track supply voltage for the last couple of miles, to keep it bearable. And as said, if you cut the spacing down to a few hundred metres you could more or less stop worrying about it.
If you used a four-rail system with +750V on one rail and -750V on the other, you could get down to only 277.77... times more for that last couple of hundred metres.
It's already been mentioned how this [sections of live rail going live on demand]would not be suitable for a high speed main line railway.
No, it was explained how it wouldn't work if you did it using unsuitable technology, which would have been a valid objection when that was all we had, but that was a long time ago now.
If any part of the derailed train comes to rest in contact with the third rail, or it gets shunted into the running rails, it will trip out.
Well, it might do. A lot of the time it doesn't. Random wreckage doesn't usually make a very good contact, and even if it did, the fault current can be so little greater than the maximum normal load from several trains simultaneously being in the same electrical section that the circuit breakers can't tell the difference.
This is another point in favour of having lots of substations feeding very small electrical sections - they don't have to feed several trains simultaneously so the trip current can be set lower.
But it's not the breakers operating that you want to be relying on anyway. Even when OHLE comes down it occasionally manages not to trip them out.
PS How easy is it to cut 3rd rail and get it in the back of a transit?
It's a similar weight per length to the running rails, so, not very. Unless you're planning to leave the rails there for 20 years while you dither on failing to decide whether to reopen the line or not, you probably don't need to worry.
Oh, everyone knows third rail can't do more than 100mph...
There's not much call for that round here, sir. We have hardly any third rail routes where it's even worth thinking about trying, and for most of their mileage it would need a lot more than the power supply upgrading to get them rated for over 100mph and/or the trains rarely get a chance to get up to the maximum linespeed as it is. So there's never been any point in anyone trying to develop that pickup method to the same state that overhead pickup has been developed, and it's basically frozen in the Cretaceous. But that does not mean that it can't be developed to handle higher speeds if someone did put the effort in. If overhead pickup had received the same lack of development as third rail we wouldn't be doing 100mph with that either.
But in any case, it hardly matters. Pretty well all the lines where it might be worth considering making them capable of over 100mph are in regions which have already been geographically bagsied by 25kV. The possible applications for third rail are pretty well all lines that don't call for exceeding 100mph anyway.
