Some of you may have noticed that the Working Timetable (WTT) is now in the form of an array of XL Spreadsheets. At the same time, they've done a few changes, such as changing the letter coding that appears in the middle of a timing and they seem to have omitted showing the arrival time at stations. I've had a look at the NR WTT site, and I can't find an explanatory table anywhere. Contacting NR is a waste as they rarely respond to complaints and comments. Can anyone out there help me with this? Thanks in advance.
Its in Appendix G of the National Timetable Planning Rules (nationalYYp.pdf) in the zip file you can download from the Information for Operator section of the NR website.
Appendix G – Explanation of Working Timetable References
For Passenger Operators -
Abbreviations used for Days of the Week
| M | Monday |
| T | Tuesday |
| W | Wednesday |
| TH | Thursday |
| F | Friday |
| S | Saturday |
| For the above:- | |
| (I) | The addition of the letter “O” indicates that the train will run on that day or
those days only.
The addition of the letter “X” indicates that the train will not run on that day or
those days indicated. |
| (ii) | |
| SUN | Sunday |
Arrival Time References
a
b
c
d
e
f
g
h
j
k
n | arrives 1 minute earlier.
arrives 1½ minutes earlier.
arrives 2 minutes earlier.
arrives 2½ minutes earlier.
arrives 3 minutes earlier.
arrives 3½ minutes earlier.
arrives 4 minutes earlier.
arrives 4½ minutes earlier.
arrives 5 minutes earlier.
arrives 5½ or more minutes earlier (see explanatory note in column).
see explanatory note in column. |
Abbreviations used to identify earlier departure times which are advertised in the National Rail
Timetable.
p
q
r | advertised 1-1½ minutes earlier departure.
advertised 2-2½ minutes earlier departure.
advertised 3-3½ minutes earlier departure. |
Abbreviations used to identify later arrival times which are advertised in the National Rail
Timetable.
v
w
y
z
‡ | advertised 1 minute later arrival.
advertised 2 minutes later arrival.
advertised 3 minutes later arrival
advertised 4 minutes later arrival.
advertised time in National Rail Timetable. |
| C | Stops to change train crew. |
D
(D)
ECS
| Other than in timing load - Stops to set down/detach.
Driver Only Operation applies.
Also “+” when placed intra-time - Empty coaching stock.
When not placed intra-time - Must only convey vehicles authorised to run 100mph or
more.
EMU
K/k
L |
when placed intra time at Colchester DOO London side of Colchester onlyElectric Multiple UnitSee explanatory note.Stops to change Locomotive. |
| N | Stop not advertised. |
| NA | Train not advertised. |
| NPCCS |
| Non passenger carrying coaching stock. |
| OP | Stops for other operating reasons. |
| P | Push pull operated train. |
| PR | Propelling between points shown. |
| Q | Runs when required. |
| R | Stops when required. |
| RM | Stops for reversing movement, or driver to change ends. |
| RR | Stops to run round. |
S
t
U | Stops for railway personnel only.
Stops for tablet, staff or token purposes.
Stops to take up/attach. |
| VB | Vacuum braked train. |
| X | Points at which;
(a) Trains run from one running line to another, or
(b) Trains cross on single lines.
| [5] | Indicates the number of minutes allowed for temporary speed restrictions and
engineering work.
(5)
<5>
|| | Indicates the number of minutes given for pathing requirements.
Indicates the number of minutes given for performance allowance.
Light Locomotive.
* (In arrival and departure times) Stops and shunts for other trains ahead or to pass only.
* (In departure time only) Traffic and/or shunts for other trains to pass.
Ø
← | Air-conditioned. Public address system applies on day coaches.
Indicates headcode is changed en route.
See explanatory note. (May be supplemented by reference letter n).
For continuation of train timings see subsequent column.
Train timings continued from previous column. |
