"The Plane Crash" - Tonight Ch4 9pm
Bungle73
19 Aug 2011
Kent
In an unprecedented event, two pilots will board a Boeing 727, fly it over a vast, empty desert, set it to crash land and parachute from the plane. Filmed for Channel 4, the resulting high-speed crash will provide scientists with invaluable information about how planes react in potentially fatal accidents.
http://www.channel4.com/programmes/the-plane-crash/articles/online-check-in
First heard about this a few weeks ago. Sounds like it could be a fascinating watch.
Oh good I heard about this on Reddit and it sounded like it would be a really interesting program, I'll stick in the Sky+ for later.
Ivo
8 Jan 2010
Bath (or Southend)
Sounds like a rather expensive experiment. 727s aren't exactly cheap pieces of machinery; they're passenger-carrying aircraft!
Still, sounds like an interesting watch.
HST Power
25 Nov 2010
You can buy a (used) 727 for five million pounds. Still, it's only a short haul aircraft, and they're in limited service these days. An A380 would set you back about $250 million!
Bungle73
19 Aug 2011
Kent
The 727 is a really ancient aircraft. Are the even being made any more?
HST Power
25 Nov 2010
Did they ever do (or consider) creating a documentary about the Air France aircraft that crashed into the Atlantic?
I seem to remember that the plane suffered a failure, and the pilots pointed the nose of the aircraft upwards, when they should have pointed it down to get wind across the plane.
deltic1989
21 Sep 2010
Yes there is a documentary about that. It's available on 4OD or Demand 5, its one of the two I'll have a look later and confirm, unless anyone can quicker than me. I won't ruin it to much for you but it seems that a mismanaged stall was what happened in that particular case.
bb21
Emeritus Moderator
4 Feb 2010
http://www.channel4.com/programmes/fatal-flight-447-chaos-in-the-cockpit/4od
Yes, the least experienced member of staff was in control of the aircraft at that time and it was claimed that the captain, after returning from his break, did not realise that the aircraft was in the nose-up position until it was too late. It is well worth watching.
CC 72100
23 Jan 2012
Yep, and of course if Air Crash programs are your thing, then you may want to give Monday 9pm on Nat Geo a watch, as we're about half way through the new series.
Class172
Quizmaster
20 Mar 2011
West Country
Me and my dad are looking forward to seeing this. Depending on whether us or my mum wins the TV argument we will either watch it tonight or put it on record. I suspect the latter... ;)
185
29 Aug 2010
Using the Facebook app, I've picked a seat just over the wing on the port side.
Central ring section where the wings are attached is strongest place in an airframe :)
You know we're all dead btw.
Ivo
8 Jan 2010
Bath (or Southend)
Can anyone explain how 4OD works? Is it just like iPlayer and ITVPlayer, or are there any strings attached to it?
Indeed. But still fascinated to see how it pans out.
It will make for a last few moments of life! If we are all doomed they won't mind anyone using a camera to take a few shots of the inside of the 727 moments before it hits the desert and sending said pictures to the BBC <D
...I realise many of you are watching said 727 instead of paying attention to the thread.
HST Power
25 Nov 2010
Thanks, I'm about to watch it just now. :)
Regarding adverts, if you are running Google Chrome then just do as Eagle says. Go onto the Chrome store and download yourself the Ad Block. It's free of charge. I don't know if similar software exists for IE and Safari, though considering that the amount of adverts have exploded these days (particuarly on YouTube) it is a very useful widget to have.
GNER 91128
13 Jan 2011
Peterborough
Not so much the program itself but the online check-in for the 'crash' to see if you would survive. Just seems terribly perverse to me. :|
Not really, at the end they showed a cross section of the plane and illustrated the G-Forces that would have been felt on impact from front to back and anywhere behind the split suffered considerably less G-Force than those right at the front and have a much greater chance of survival barring head injuries etc.
It does appear from the experiment that if the front landing gear was designed the sheer off like the rear sets, then the plane is less likely to dig in and create enough force to rip the body.
A0
19 Jan 2008
It's being repeated on 4seven (Freeview Ch47 - sorry don't know the SKY / Freesat / Virgin channel nos) tonight at 9pm for anyone who missed it / couldn't record it.
HST Power
25 Nov 2010
Just finished watching the documentary about the Air France aircraft that crashed into the Atlantic. Such a sad story, but it was interesting to learn more about the physics and the communications in air travel.
jonty14
3 Aug 2009
Rottweil Germany
*cough* AdBlock *cough*
Also when a programme goes on 4oD, it's on there forever, rather than for a week, and 4oD's library stretches back decades.
Thank alot Eagle for the tip. The AdBlock has improved my viewing! Amazing programme.
Regards
Jonty14
Rick1984
23 Aug 2012
So just to clear up your better at the back? If so this concurs with my Qi book that tells me tui sit just aft of the wings.
