The Pendolino that didn't get home for Christmas
bnsf734
15 Oct 2007
Nuneaton
Walking by Nuneaton station this Christmas morning I was surprised to see a Pendolino in platform 4. I assume it must have failed on Christmas Eve and will be there until Friday until it makes it home.
Mag_seven
1 Sep 2014
here to eternity
Looks like this was the train in question:
https://www.realtimetrains.co.uk/train/C72608/2019-12-24/detailed
1A60 1747 Liverpool Lime Street to Nuneaton
This service is partially cancelled
This service was cancelled between Nuneaton and London Euston due to a problem with the on-board safety systems (MT).
Two paths were later put in to try and get the set to either Wembley or Crewe but both of those were cancelled.
https://www.realtimetrains.co.uk/train/O74748/2019-12-24/detailed
https://www.realtimetrains.co.uk/train/O74759/2019-12-24/detailed
38Cto15E
1 Nov 2009
15E
Would this be a problem that the Rugby Thunderbird couldn't help?
FWIw I do not read of many Pendolino's being total failures.
Even if the Rugby Thunderbird is available it still has to get the Pendolino to a depot before an engineering possession starts or the staff shift ends.
bnsf734
15 Oct 2007
Nuneaton
It was still there today with a Thunderbird on the North end. I think the Thunderbird was there yesterday but wasn't 100% sure. It is stabled on the up main but as there are no trains running today its location shouldn't matter. Tomorrow will be different so they will need to shift it.
It's visible on Opentraintimes as 5A60.
bnsf734
15 Oct 2007
Nuneaton
The station is locked up although that wouldn't stop anybody determined but they would need to scale a high pallisade fence to get on the track.
Steddenm
2 Mar 2017
Clane, Co. Kildare
Still there at 1841 on Boxing Day. Green aspect towards Atherstone though.
(Image shows screenshot of Traksy website with 5A60 - a failed Avanti Pandelino in platform 4)
jamesst
4 May 2011
Merseyside
I'm not totally sure to be honest. It is just something I thought was the case. Can any staff confirm or deny?
Well at my toc most terminal ends (with buffers) has stock stabled and switched out overnight.
However any stock stabled mainline (through lines) which is normally during possessions, blockades etc must have at least lit portable tail lamps at either end.
Dren Ahmeti
17 Oct 2017
Reading
“390197 is out-stabled at Nuneaton due to technical problems whilst working 1A60 1747 LIV-EUS”.
As far as my understanding of the rule book goes, trains can be stabled on running lines (with extra precautions, such as a portable tail lamp).
Carntyne
8 Jul 2015
It was stabled on the Up Fast. Dump all the air out of the train and stick the parking brakes on. Done!
DarloRich
Fenny Stratford
It still seems to be there, everything is having to go around it on the Up Slow, it's now "become" 5H88 so presumably will head off to Longsight before too long?
It is entirely possible the train could have broken in such a way as to leave it immobilized
bnsf734
15 Oct 2007
Nuneaton
I saw it this morning just after 0900 at Nuneaton Station and it was indeed 390107 with 57308 attached to the North end. All over the holiday whilst it was parked the normal taillights were lit at the South end.
A crew was getting it ready for its journey whilst I was there. I saw somebody get into the back cab of the 390 and there was a driver in the 57. It finally left at 0940 on 5H88 to Longsight, presumably for an appointment with the big hammer!
That is certainly the longest time the up fast has been occupied by the same train for a few years!
Raul_Duke
29 Mar 2014
As long as the signaller knows it’s there, it’s screwed down, attached to something else that’s screwed down or scotched, and it’s got reds on each end then it’s all good according to the rule book. Similar to leaving a portion of a divided train “in section.” (Which is unlikely to happen nowadays.}
It’s more what your definition of “stabled,” is than “running line.”
This looks like it’s just failed but no one can be bothered to recover it until after Christmas. But it’s all irrelevant because there’s no trains. Obviously they wouldn’t let this happen on a busy Monday morning for example.
bnsf734
15 Oct 2007
Nuneaton
Postscript to this story. I was in Birmingham today waiting for a train to Birmingham International and my train was formed of 390107, so it didn't take long to fix it.
AndrewE
9 Nov 2015
I imagine some faults can be fixed in minutes but need to be done in a depot.
I don't think that follows.
If something can be done within minutes it is certain that there's not much to be done beyond plugging in a laptop. Simply undoing anything physical (with locknuts, or castellated nuts and split pins for example) and re-fixing will take a quarter of an hour. I bet even wrestling a burst brake hose off and re-fitting a new one will be a similar length of time.
All of these could be done "in the field," but the time it would take to get someone there - with the correct part - and the possession needed on the adjacent line would probably count against it on today's railway. (Apart from the laptop job of course, and even then with a slimmed-down Longsight staff I wonder whether they could afford to jeopardise their shift deliverables to do a fire-fighting/rescue job that probably isn't in their contract?)
