Buttsy
It is, the question is if there is anything that doesn't stop there which does stop at the other two. If there is then I beleive you have won.
Not that I can see checking Scotrail's timetable
HOLD HOLD HOLD I believe the previous game is still on unless anything runs fast between Armadale and Caldercruix.
But that would be void if there are no services from Armadale that don't stop at Blackridge. In this case you would not have been able to move from Caldercruix to Blackridge and I believe the last valid post would be Armadale although it's possible that your Blackridge could be taken as though it was a response to Armadale. HOLDING for claifircation of the situation.This was used on posting # 29151
HOLDING for clarification of the situation.
I can see nothing in table 226 which does Armadale to Caldercruix non-stop, it appears that everything on this stretch is either all stations or fast from Bathgate to Drumgelloch. Therefore, from the most recent valid submission of Armadale, I will say Blackridge.Caldercruix
That's done, Airdrie.If Zoe was therefore to re-instate her posting # 29166 of Caldercruix
