The next station is...!
A Challenge
24 Sep 2016
That map is rather badly drawn, Blackheath is after the junction (in fact the lines use completely separate platforms at Lewisham) and only served by trains from Lewisham via Charlton/Kidbrooke not via Hither Green
St Johns
9 Oct 2020
Norwich
Ok But if you zoom in you will notice that Blackheath is slightly before the Hither green branch turns in on the map. Also, if Blackheath was on both lines then it would serve as an interchange which would mean it would be represented as a white circle with black edges, not as a dash. In adition to this I can't find any timetabled direct services between the 2 on the Southeastern timetable. It is clearer on the National Rail All Stations map.
