The next station is...!
Robinson
1 Aug 2010
Helensburgh
Heathrow Terminal 5 and victory <:D
Let's keep taking advantage of the temporary rule and stay in the South East for a bit...
We shall start at Drayton Green.
Robinson
1 Aug 2010
Helensburgh
going off the tube map, seemingly not
Which map are you using? I've checked the zoomable map on National Rail against the Train and Tube Map and the Standard Tube Map, both from TfL's website. The former 2 indicate it as same-station; the latter does not indicate any form of an interchange...
Where are we?
If I'm right and Heathrow Terminals 1, 2, 3 tube to rail is a same-station interchange (which would mean my Heathrow Terminal 5 post was a winning move) we're starting a new game at Drayton Green. If I'm wrong, we're at Heathrow waiting for a move to be made.
gnolife
4 Nov 2010
Johnstone
I was going off the standard one, I hadn't noticed the Train & TUbe one
I'm trying to get a map of heathrow airport at the moment, to confirm one way or the other
gnolife
4 Nov 2010
Johnstone
The tube can go hang as far as I'm concerned :P
Fast to ReadingSlough
and thank you very much :)
Windsor & Eaton Central, and Points?
The next round will start from Alsager
