The next station is...!
backontrack
2 Feb 2014
The UK
Layton and the points. :D
Next leg to start at, unsurprisingly, Cardiff Central.
Xenophon PCDGS
17 Apr 2011
...a couple of hours later, causing us to lose points.
Then why did no-one else bother to make a "fall-guy" posting in the interim period. I cannot be blamed for losing any points and it was someone else who was the eventual leg-winner.? What would have happened if I had not made the posting that I did, which at least moved the game along from its state of dormancy
Llanelli
Xenophon PCDGS
17 Apr 2011
Reading for today
And it came to pass that Jesus and some of the disciples were in that area called RailUK forums where the Pharisees were gathered to try a member accused of not making a posting and causing points to be lost on a leg.
Wishing to try to make Jesus answer in a way that they might cause him to be accused and brought before the Sanhedrin to answer for the matter, they told Jesus what the member had been accused of and asked him what they should do. Jesus just kept his gaze on the ground and made no reply. So they continued to put the question towards Jesus, observing the posture he had assumed and they were desirous of Jesus to make an answer so they could have the advantage of him. Jesus then straightened up his body and raised his head and turned towards his questioners and said to them...."He who is without sin amongst you, let him be the first to cast the first stone" The Pharisees were perplexed and knew not how to reply and went away and Jesus went to the member who had been accused and said to him..."You have done no wrong. Go forth and participate once more".
Here endeth the lesson for today.
